New owner, a few questions
Discussion in 'Gen 2 Prius Main Forum' started by phillijp, Jan 22, 2014.
  1. phillijp
    phillijp New Member
    Background:
    My wife (just married) and I swapped cars (Prius/Subaru) because I drive a lot more than she does and she loves the Outback. Somewhere along the way the manual for the Prius turned up missing. I've been perusing the forum for a few days trying to get a grasp on this car. We live in Ohio and it's been quite cold the last few days. My apologies if these questions should have been posted elsewhere. 2009 Prius with about 54k miles.
    Questions:
    It seems like this little car never really makes enough heat to warm the cabin when the outside air is in the teens or less. This morning it was -4 and it took a very long time to get heat going. Is there a solution to assist in getting the engine warmed up sooner such as a grill cover?
    Is there a way to disable traction control? I prefer to drive the car myself, I don't want traction control limiting wheel spin in the snow. Sometimes wheel spin is a good thing.
    So far I've learned from reading posts/articles here that I've been driving this car all wrong and have modified my driving style to maximize fuel efficiency. Thanks for the good tips so far.
  2. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    Welcome!
    The Pri can have a hard time producing cabin heat, especially when outside temperatures are very cold. The power train doesn't produce much waste heat compared with a conventional, gasoline power train. Grill-blocking is sometimes used in cold climates but its recommended to use a Scangauge or similar instrument capable of reading engine temperatures.
    I've found it works pretty well to drive the car for a few minutes with the climate control off to help the drive train warm up a bit before introducing the heat demand. Also, it seems to be more effective at lower fan speeds. I don't go higher than the third fan speed. I think it's too difficult to transfer enough warmth at high fan speeds.
    The traction control on the Prius is very important in order to protect the electric drive from damage. There is a way to disable it via a hack, but it is strongly discouraged. A rapidly-accelerating drive wheel on a slippery surface can easily overspin one of the electric motors and permanently damage it.
    When driving a Pri on slippery surfaces, I find it most effective to modulate the go pedal and keep the traction control system from activating. It takes a little practice, but it ultimately enables better propulsion on slippery surfaces. It will even let you power the tires slightly faster than the surface without traction control activating if you don't give it too much pedal.
    Enjoy the Pri!
    51,017
    welcome to priuschat! search gen II grill blocking, we do it with half inch copper pipe foam insulation stuffed into the lower grill. start your car on cold mornings, turn the heat all the way up and let it sit until warm enough to drive. all the best!(y)
  4. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    If you set your heater temp to MAX HOT or 86°F, there is a electric heating element in the heater box that supplies heat to the cabin until the gas engine warms up. But it only works at the MAX HEAT setting. What I do if it's really cold is set the temp to MAX HOT and then set the fan to the maximum or next to max setting to get some heat quickly. It will drain the traction battery a little so be sure you start the gas engine before turning on the heater.
  5. phillijp
    phillijp New Member
    Thanks for the responses. It sounds like I'm doing all I can to make heat except for blocking of the grill which I will investigate as time permits.
    As for the traction control, I don't want to do damage and I don't fully understand how power gets from the powertrain to the wheels but I'm quite certain there is an open differential that would mitigate any shock to the drive train as a result of wheel slippage. Here in SW Ohio we have hills a plenty and I was squarely suck in a driveway the other day simply because the wheels would spin then stop then spin then stop. There was never enough spinning to work through the inch of snow to get me down to pavement. Fortunately I had access to a shovel but it took about 15 minutes to get the car up the drive.
  6. Patrick Wong
    18,200
    6,491
    Have you installed four winter tires on the Prius? If not I suggest you do so if the car must be driven in snow.
    As you've already learned, the Prius traction control will restrict wheelspin so that particular driving technique needs to be abandoned when using that car.
    MG2 is directly tied to the transaxle output shaft. This is the motor that can be damaged due to excessive wheelspin and traction control will protect that MG, which is capable of producing ~300 ft.-lb torque at 0 rpm. That can do damage if its rotational speed is not controlled.
    As you probably know, gasoline engines produce very little torque at idle speed (which is why they require transmissions with multiple gears.) So this is not an issue for a traditional drivetrain.
  7. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    I've read about that electric heating element in the heater box somewhere, but I'm kinda curious - do ALL 2nd Gen Prii have this device spirited within their heaters, or is it only restricted to certain models sold in countries deemed "really cold" by Toyota?
    Nexus 7 ?
  8. Patrick Wong
    18,200
    6,491
    The Toyota repair manual indicates that this is limited to "Cold Area Models". All North American Prius have the electric heater.
    To check your car, open the relay box mounted on the cowl above the engine. Look for two relays: PTC Heater Relay #1 and PTC Heater Relay #2. If you do not see those relays then you definitely do not have the two PTC heaters installed.
    If you see the relays then you probably have the heaters.
    Data Daedalus likes this.
  9. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    I'm afraid we do not get the PTC heaters in the UK or EU Prius. So along with Scandinavia we do not come under Toyota's definition of cold.
    We also do not get heated outside rear view mirrors although they are fitted in Florida along with the PTC heaters "work that one out".
    The heated mirror glasses are available "after market" and it is an easy modification. No extra switches required on the dash as the heated mirrors come on with the rear screen heater as OEM. I have done this modification so if you want details let me know.
    Fitting PTC heaters would be a major job as not only are the relays missing the wiring and heaters themselves are not there. To fit them would require the removal of the heater along with disconnecting the AC lines. A major task, and I doubt you can order the parts in the UK as they are not listed in the parts manual in the UK/EU.
    John (Britprius)
  10. phillijp
    phillijp New Member
    Our snow season is limited to about 4 or 5 events a year in which I'd benefit from snow tires so I don't think I'm going that route. I've decided that if traction control is a must on this car I'll learn to live within its confines, try to remember that this car is not AWD and carry a bucket of sand when I forget this car is not AWD.
    Thanks again
  11. Patrick Wong
    18,200
    6,491
    "...try to remember that this car is not AWD and carry a bucket of sand when I forget this car is not AWD."
    That seems like a reasonable policy. Not many AWD cars or SUVs can claim 50 mpg fuel economy, so keep that in mind when you are lamenting that the Prius does not behave like a Jeep in the snow.
  12. PriusGuy32
    1,417
    513
    Harrison Township, Michigan
    I agree with everything everybody has said so far.... the trifecta of winter gas mileage helpers:
    1.) Grille blocking (search the site or google it)
    2.) Engine block heater
    3.) Tire pressures
    I have my grille blocked 100% and use a block heater, on a timer. Without those two, I cant imagine what my mileage would be :eek:
    I also use 0w-20 synthetic oil and have my tires inflated to 44psi in the front, 42psi in the rear. (y)
  13. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    On your next tire replacement, you could consider an all-season with strong winter performance, such as the Hankook Optimo H727, Pirelli P4 Four Seasons, Goodyear Assurance TripleTred or similar. We have the H727 on two Prii in the family--they never cease to amaze in winter conditions. The Trac and ABS very rarely activate any more and they just scoot around just about everywhere in the snow now, even in the mountains. One of them has a set of cable chains in the trunk for skiing trips but they've never been needed. I've been taking the insurance off the 4wd trucklet over the winter and leaving it parked.
    PriusGuy32 likes this.
  14. phillijp
    phillijp New Member
    I had the Triple Treds on my old Subaru, horrible tires overall. I would not recommend them and I believe they may have been discontinued. The Prius just got a set of Cooper CS4 about 10k ago. They are better in actual snow but a typical Cincinnati snow event usually includes heavy, wet snow which is asking a lot of any all season tire.
    In early December I took this car to the UP to check on our vacation home. The car muddled it's way through 5" of fresh snow but I wouldn't want to push my luck beyond that.
  15. JerryCS
    JerryCS Prius camper with trailer hitch
    77
    Elk Rapids, MI
    Thanks! Six years that I haven't known that. I do plug the block heater in for an hour or two before I drive on cold days-- which we're having plenty of this year.
    We used Nokian WR2's for a short while, good in snow but they don't last long enough. Now on our second set of Goodyear Assurance Comfortreds, an outstanding tire all around and especially in snow. We have snow events every week.
