New owner of '05 with only 200 miles
Discussion in 'Gen 2 Prius Main Forum' started by 2005, Sep 14, 2016.
  1. 2005
    2005 New Member
    29
    New Jersey
    I sort of inherited an '05 Prius the other day, the car has been sitting in a garage unused, untouched for the last 9 years, and before that it was only used for one trip per year. They new the car was going to sit so they disconnected the 12v battery, removed the tires and stored them in plastic bags on a shelf. The car sat in a heated garage dormant since at least 2007.
    The car is in mint condition physically, not so much as a fingerprint on the thing but both batteries are stone dead. I bought a new 12v battery, got it started but have no clue as to whether or not the hybrid battery has survived or not. I've got some warnings on the dash, and its been run for about four hours just sitting. I called the selling dealer and they told me to just let it run and see what happens?
    Is there a way to properly charge or attempt to charge the main battery?
    What are the chances a battery that's been sitting dead for 5 years or more will recover?
    My usual vehicles are diesel powered and much larger, I'm more than capable of working on large trucks but I have no experience with a hybrid.
    m.wynn likes this.
  2. prius_noob
    prius_noob Member
    151
    56
    United Kingdom
    Could you take a picture of the warning lights on your dash?
    Do they resemble any of these icons maybe (That way you don't have to take a picture)
    http://www.mytoyo.com/images/pages/2/page.h43.jpg
    I'm not sure what help I can be, but I'm fairly certain that with more detail with regards to specific warnings, someone might be able to help a bit better :)
  3. dolj
    dolj Senior Member
    8,108
    4,124
    Wellington, New Zealand
    Hello and welcome to PriusChat.
    You said:
    Then said:
    The fact that you got the car started, means the HV is not dead. Would be interested to know what the Energy Monitor screen showed the state of the battery to be. Any chance you took a photo of it or at least viewed that screen.
    Put the emergency parking brake (foot operated) firmly on, then also press firmly on the foot brake. Select 'D' with the gear selector and the press the go pedal (accelerator) firmly to the floor and hold it there. This will "force charge" the HV battery to 80%. Observe the battery on the Energy Monitor screen–see if the battery will charge up to 8 (green) bars (80%). If the battery is good it could take some time; if the battery is not so good, it will charge quickly.
    Possibly good, I have read that NiMH batteries can sit for a long time. They will just slowly self discharge, but will not damage. But to be honest, I have not heard of this situation before, so would be keen to hear of the outcome.
    We have some good battery guys contributing here who know a lot more than me, so hopefully some of them will chime in.
    In terms of wrenching, these cars are easy to maintain, so your experience should see you in good stead.
    Keep us posted.
    #3 dolj, Sep 14, 2016
    prius_noob likes this.
  4. prius_noob
    prius_noob Member
    151
    56
    United Kingdom
    With regards to Ni-Mh, another battery manufacturer, Panasonic, uses them and their batteries go from 100% to around 70% after 5 years
    That could just be a bit of a red herring however
  5. dolj
    dolj Senior Member
    8,108
    4,124
    That will be with use. This Prius has had few charge cycles over the years.
  6. prius_noob
    prius_noob Member
    151
    56
    United Kingdom
  7. dolj
    dolj Senior Member
    8,108
    4,124
    Let's see what the OP (original poster) reports.
  8. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    This is so cool! A new 11 year old car. Keep us posted, and best wishes from Nashville
    kenoarto, prius_noob and Mendel Leisk like this.
  9. EZDog
    EZDog New Member
    27
    17
    STL
    Wow!
    I snagged an 05 with 4k a month ago and it had been great so far!
    I thought that might be the low mileage winner but.......
    Good Luck
    iPhone don't expect too much
    kenoarto and Aaron Vitolins like this.
  10. wjtracy
    wjtracy Senior Member
    11,357
    3,604
    Northern VA (NoVA)
    As dolj from NZ says, Gen2 can be self-charged by the method suggested (put on brakes and give it a little gas)...
  11. fotomoto
    fotomoto Senior Member
    5,626
    3,802
    So. Texas
    LOL, yeah I was thinking about you when I saw this thread. Makes yours sound like high miles and my 06 with only 44k miles sound like I should take it to the junk yard! WOW!
    It will be truly amazing if that HV battery comes back to life. The big thing in its favor was storage in a cool environment and heated when needed. If it were me, I would seek out an independent hybrid shop that knows about battery reconditioning.
  12. prius_noob
    prius_noob Member
    151
    56
    United Kingdom
    Yeah when I first saw the thread, I thought OP meant 200K miles but nah it's...200 miles :D
    Blizzard_Persona likes this.
  13. 2005
    2005 New Member
    29
    New Jersey
    The 12v battery in the trunk was dead, I couldn't get more than a volt or two out of it after charging it out of the car. I was going to buy an Optima replacement but found a local shop that had a new OEM battery they had ordered and never used last month. I got the OEM battery for $125 cash. I installed the 12v battery and then was able to start the car.
    There is only one bar showing on the charge indicator on the screen and I've got a battery shaped indicator showing.
    The car starts every time but the engine runs almost 100% of the time, I've not yet been able to run on electric power that I can tell.
    (I drove a newer model some time ago once and on a short drive around the neighborhood, the engine never started on that car, it ran almost silent on the battery power).
    I called a local Toyota dealer and was told that there's just about zero chance that the HV battery survived sitting for so long, and that I'd be looking at just under $5,000 to replace it. If that's the case, the car isn't really worth fixing to me.
    If I can get the original battery to work again, that would be the best solution, if not, I'd probably spend up to a grand to get this going, after all it is basically a new car.
    The ordeal of getting the car moving again was more than just changing a battery. We couldn't find the wheels and tires for the car! He had them stored five miles away sealed in heavy vinyl bags stored in a garage behind his other house. The keys were in the main house, and the fuel tank was drained completely dry.
    There was also a snap lock type connector behind the one side panel that was unlatched, apparently this connects the car harness to the main battery? The 12v battery was also disconnected.
    The car was sitting under a cloth cover that he had custom made for the car and the car was up on jack stands about 20" off the ground.
    Is there some easy way to check to see if the HV battery is up to snuff? Can it be directly charged without running the car?
  14. wjtracy
    11,357
    3,604
    Northern VA (NoVA)
    Did you see above posts? you can put your foot on brakes in DRIVE and gently rev engine to force a charge on the battery do this I do not know 30 minutes or until you start to see the bars filling up to the Blue. Be careful and search on older posts for more details.
    Other than that you gotta buy a balancer/charger available here. Also you can hook up Techstream with mini VCI to the car to view battery cells, but I'd be tempted to try to force charge it.
    You can buy a new batt maybe $2000 DIY.
    #14 wjtracy, Sep 14, 2016
  15. JC91006
    16,632
    8,492
    There really is a ZERO chance that HV battery is good. The engine running 100% of the time is letting you know the HV battery has already failed.
    I would try and call Toyota and see if they will replace it under a good will warranty. Tell them it's a 2005 with 200 miles on it......that shock alone should get you a new battery.
    orenji likes this.
  16. bisco
    50,803
    congrats and welcome! i would leave it in the garage for another generation.:p
  17. wjtracy
    11,357
    3,604
    Northern VA (NoVA)
    Or they might give a decent price...not the dealer though, Toyota.
  18. Britprius
    Britprius Senior Member
    5,194
    1,917
    Herefordshire England
    As dolj say's the HV battery cannot be dead if the car starts, and shows 1 bar on the battery screen. One bar is a charge level of about 45%, and you also state it has started a number of times.
    Now about NmHi batteries. If you read the information on them correctly you will find the recommended method of long term storage is to discharge the cells before storing. This does not harm them unlike lead acid batteries. All batteries have a self discharge rate that will gradually discharge them. Again this doe no harm to NiMh cells.
    The car will run 100% of the time with a charge level of one bar, and every time you start the car more charge is removed, and has to be replaced.
    What does the battery level charge screen show in drive with one foot on the brake and the other on the accelerator. It should show arrows going from the engine to the generator then to the battery. If this is happening "something you have not answered" the battery is charging. Patience is required when doing this. I once discharge the HV battery on a long clime towing a caravan so that no bars were showing and I was alarmed at how long it took to get back to 3 blue bars coming down the other side of the mountain with full regen braking for 5 miles with the caravan pushing the car.
    John
    Data Daedalus likes this.
  19. JC91006
    16,632
    8,492
    Hi John,
    From your explanation, what do you think causes batteries that sit for extended periods to fail? We read lots of people that let their cars sit for extended periods to find P0A80 when they restart the car. Wouldn't that be caused by self discharge and then reverse charge?
  20. Britprius
    5,194
    1,917
    Self discharge does not cause reverse charging. Self discharge is discharging within each cell across the plates.
    Reverse charging is cause when a number of cells in series connection are discharging current into a load. Then if one cell reaches zero charge "before all the others" this cell then goes into a reverse charge state being charged in reverse by the other cells through the load.
    In series each cells + terminal is connected to the next cells - terminal and if a cell cannot contribute to the output you will see it is like a battery connected to a charger in reverse. The current through all the cells is the same, and in the same direction.
    John.
    #20 Britprius, Sep 14, 2016
    Data Daedalus, jeff652 and bisco like this.
