New Prius owner - ran out of gas!
Discussion in 'Gen 2 Prius Main Forum' started by pwalta, Sep 4, 2007.
  1. pwalta
    pwalta New Member
    We decided to take our 4 week old Prius on a road trip to Houston this weekend. We filled up the tank as we left Stillwater, Oklahoma. Coming into Huntsville the tank showed two bars. It went to one bar as we passed Conroe. I assumed from the mpg shown and the miles shown (48 mpg and 440 miles) that we could easily make it another 60 miles. Our 19 year old was driving and apparently the last bar started blinking. I don't know how long it had been blinking, but the triangle with the exclamation point came on as well as the check engine light. We pulled over on the side of the road (we were on the Hardy Toll Road by now), pulled out the owner's manual and determined that this was probably the result of low fuel. We then attempted to make it to the next exit to get fuel when the car died. We spent the next hour and a half waiting on a tow service to come and give us gasoline. After putting in two gallons of gas, the lights were still on and I was getting very concerned (my husband said I "lost it"-- I am sure he was wrong!). The tow truck driver led us to a gas station where we put another 9.8 gallons of gas in the car and traveled on to our daughter's house, two hours late. On the way home, we filled up with only half a tank gone. I felt really stupid about running out of gas but we learned that when it says add fuel, it really means right then.
  2. prius2go
    prius2go Member
    312
    interesting
    how far do you think you managed to go with no gas?
  3. Ari
    Ari New Member
    165
    <div class='quotetop'>QUOTE(Tula @ Sep 4 2007, 04:43 PM) [snapback]506941[/snapback]</div>
    The best way to estimate the true range is to remember how much gas you put in at the last fillup and then multiply by that by the current MPG you're getting. If you put in 10 gals and you're getting 50 MPG, then you should expect 500 miles and be careful about driving any further than that.
    In your case you were able to put in an exceptionally large amount after it went dry. The theoretical size of the tank is 12 Gals, but most people only get 8-11 gals depending on the weather, the gas pump shutoff point etc. I'll bet you only put in ~9 gals at your last fillup.
    Thanks for the story anyway. Once you get used to the "guess gauge" and your car breaks in a little more, you'll be getting 450-500 miles per tank no problem.
  4. darlenegalik
    darlenegalik New Member
    30
    I also ran out of gas with my Prius, when I had it about 6 months. It was so good on gas, I guess I thougt it could go on forever. But eventually it needs some gas. I saw the blinking block coming home from work and drove the remaining 5 miles home, no problem. But the next morning, I was late, and decided I could drive to work without getting gas.... it's 55 miles to my job.
    I got almost 50 miles, and got the red triangle and exclamation mark - I realized it must be out of gas. But it was still on electric. So I drove to the next rest stop (this is the NJ Garden State Parkway) going slower, and slower. So I stopped about 100 yards from the gas station at the Asbury Park station and turned the car off. Waited about 5 minutes, started it up, and stepped on the gas (electric here) - It went to the gas pump, and I filled it up. Started it up, no red triangle or any other warning light, and ran fine to work. But I fill it up now on the last block. And no obvious repercussions.
    Also, I get 55 MPG consistantly in the summer. About 50 MPG in the winter.
  5. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    I ran out of gas after only having about 850 miles on the car, the first time I got gas I still had a half tank because I filled up to take it on vacation, and since I topped it up on that tank I assumed there was 12 gallons in the tank. I hadn't experienced being empty with a flashing pip and then only being able to add 9 - 10 gallons before, so I did the same thing current MPG says 50 MPG I was at 515 or so started flashing, I was out at about 525. I was able to call the inlaws to bring me gas and I added a little less then a gallon from their can they brought me and when I got to the gas station was shocked when I struggled to just put in 9.5 gallons of gas. So not knowing about the bladder at the time I was like they need to correct that misprint to 10 gallon fuel tank.
    Long story short I have learned to expect only 10 times MPG on the MFD (give or take about 25 miles).
  6. pwalta
    pwalta New Member
    <div class='quotetop'>QUOTE(prius2go @ Sep 4 2007, 04:53 PM) [snapback]506942[/snapback]</div>
    Not very long -- I was concerned about running on the battery.
    <div class='quotetop'>QUOTE(Ari @ Sep 4 2007, 04:58 PM) [snapback]506944[/snapback]</div>
    I think you're right --we obviously didn't get a full tank in when we filled up.
    <div class='quotetop'>QUOTE(PriusGirlNJ @ Sep 4 2007, 05:02 PM) [snapback]506946[/snapback]</div>
    I remembered the threads on here about not driving on the battery after running out of gas so we immediately pulled over and just waited for help. Plus, the triangle with the exclamation point definitely got my attention. Didn't want to do something to void the warranty. I have had one tank at 50mpg so far, but hopefully that will improve with time.
  7. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    619
    26
    The problem is not always with the bladder...every pump is different. We just notice it more because we have the MFD staring us in the face with the number of miles we've gone on the tank!
  8. patsparks
    10,664
    567
    Adelaide South Australia
    What is the advantage of squeezing every last mile out of a tank of petrol? What is wrong with filling up when you are down to 2 blocks on the fuel gauge?
  9. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Now we have proof that running the Prius to empty is not just a "guy thing". The Guess Gauge is accurate in only one place--EMPTY. It is perfectly acceptable to buy gas before the last pip flashes.
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    It takes about three gallons before the added gas registers.
    Tom
  11. pwalta
    pwalta New Member
    <div class='quotetop'>QUOTE(patsparks @ Sep 4 2007, 07:32 PM) [snapback]507017[/snapback]</div>
    This is the first time I have run out of gas in almost 20 years. I don't routinely try to "squeeze" the last bit of gas from the tank, however, our previous cars did not have such a limited amount of fuel left when they reached the "red" mark. It was late, we had been on the road for over 8 hours and we honestly believed that we had plenty of gas to make it to my daughter's house.
  12. kosmach
    kosmach New Member
    thought i'd post this here.
    we had a lot of rain in chicago last week. i work in a 4 story building in the suburbs overlooking a street that flooded. car after car entered this area not realizing how deep the water was (or for that matter it was so dark people may not have realized they were in water until it was too late). once the car muffler submerged the cars would stall. people in the car would eventually get out and push it to a parking lot and wait until they could start there car. as soon as this would happen, another car would come around the corner and hit this area repeating the stalling process. then all of a sudden here comes this prius. the car slams on it's breaks about 20 feet into the water, and then proceeds to just plow through the water some more getting much further than any of the cars. at this point the driver realizes it's only getting deeper and starts to turn around. they make it back and take off.
    i guess it's kind of cool when you don't need your gas engine sometimes!
  13. Miss_Taz
    Miss_Taz New Member
    153
    Pittsburgh, PA
    <div class='quotetop'>QUOTE(DrTivoL @ Sep 5 2007, 01:27 AM) [snapback]507171[/snapback]</div>
    Too bad it was so dark -- that would have made a great YOUTUBE video.... Pro-Prius, of course!
    LOL
    Very cool!
    -Vikki
  14. PriuStorm
    PriuStorm Senior Member
    2,239
    149
    Davis, CA
    <div class='quotetop'>QUOTE(DrTivoL @ Sep 5 2007, 12:27 AM) [snapback]507171[/snapback]</div>
    Hmm... wouldn't this be incredibly dangerous?? I mean, high voltage batteries/electric circuits and water.... <_< :blink: :huh:
  15. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    I would not trust the MFD to display a 100% accurate MPG, for example, my last tank of gas said I was averaging 61.3 MPG when I finally filled up and the last bar on the gauge had just started flashing. I was only able to add 9.45 gallons when the pump shut off which is how I always fill and that calculated to 57.94 MPG (I had driven 548 miles). So, don't rely 100% on the MPG on the display. If the "Add Fuel" banner pops up on the screen with a quick "beep beep" as the last bar on the gauge begins flashing, you better stop and fill up (I would give it a safety margin of about 20 miles at that point IF you just happen to see the flash on the screen and have the radio low enough to hear the beeps or even notice the bar flashing). Enjoy your new Prius!
  16. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    <div class='quotetop'>QUOTE(PriuStorm @ Sep 5 2007, 11:29 AM) [snapback]507320[/snapback]</div>
    could be one Electrifying video B)
  17. Peter7307
    Peter7307 New Member
    Same question from me.
    Why wait until the last bar is showing? It isn't like the requirement to refill is going to vanish.
    Besides all that ALL gas has some rubbish in it.
    Grit , dust , minute particles of dirt and the like which are all filtered out by the fuel filters when the fuel is sent though the engine.
    Those that sink to the bottom of the tank slosh around in the remaining fuel and stay there until you start running in the last gallon or so. Then they get sucked up.
    Pete.
  18. patsparks
    10,664
    567
    I treat the last bar as no fuel at all, so I refill as soon as pratical after the gauge is down to 2 bars or sometimes just before.
    I never express disapointment at not being able to fit much fuel in the tank, that's why I bought the car.
    800km from a refill is plenty good and if that means I'm filling when there are 2 bars left on the gauge then so be it. I'm still getting 200km more than from a tank in my old camry and putting much less fuel in.
  19. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Actually, the high-voltage parts are pretty well sealed up. Battery
    cables are shielded running under the car, the inverter is mounted
    high, the motor cables from there are also shielded, and the whole
    transaxle is not only well-sealed but actually is so well enough to
    develop negative pressure inside over *several* heat/cool cycles.
    I'd worry most about the position-resolver connectors on the front
    of the transaxle, and various low-mounted engine sensors like the
    crank and second O2. But they generally have water-resistant wiring.
    _H*
  20. patsparks
    10,664
    567
    Most submarines are hybrids aren't they?
