New To Me HybridSD S3/S4 Condition
Discussion in 'Gen 2 Prius Technical Discussion' started by Rokeby, May 13, 2008.
  1. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    This morning I saw something in the HSD that I don't understand.
    Base line conditions.: Air temp ~48 deg F. I had entered S4, verified with an
    "idle check," and easily finding/holding no arrows glide above 42 MPH. I
    then stopped for ~2 min. to debark passenger. Put the car in park, but did
    not turn off ICE -- I do this because I believe it "preserves" S4 over the stop.
    Resumed trip, but had difficulty finding/holding no arrows glide. Then it
    happened... Speed 47 MPH, 6 blue bars, roadway level/very slight down
    grade, can't find glide. Scan Gauge shows: 990 RPM, IGN 5 -- or maybe
    switching between 5 and 10 -- coolant temp 170 deg F. Mimic shows yellow
    arrows, battery assisted glide. 99.9 MPG
    The weird thing is this went on for over a mile with speed remaining at
    47 MPH, and the six blue bars never changed. I was just agog, and going
    over a bump in the road I lost it. I motored up a slight rise with no arrows
    to/from the HV battery, and then went into a half mile long no arrows
    glide/regen as the expressway transitioned onto surface roads. Usually I
    arrive here with six blue bars. But today I had eight green bars.
    Can anyone help me understand what was going on -- the really low RPMs
    and IGN, (S3 perhaps?) the HV battery seemingly not discharging despite
    the extended yellow arrow "assisted glide," and the final full-up HV battery?
    Is it possible that the HV battery was being charged (MG1?) and discharged
    (MG2?) at the same time with the net charge increasing but staying in the
    sixth blue bar display range?
  2. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    If you went to eight green without doing a whole lotta regen,
    you might have seen one of those very rare battery recalibration
    events. They do happen, but they don't plague the Prius nearly
    as much as they do the Insights.
    _H*
  3. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Hobbit,
    What is a "battery recalibration event?" Did a quick Google search with no
    results.
    Is it a good thing? Just CPU/ECU housekeeping?
    There was some regen as the highway transitioned on a slight down slope to
    surface roads, regen roll-down from say 40 MPH to 10 MPH. I wouldn't call it
    a lot. I see this every day and it contributes to the typical six blue bars at this
    location.
    I'm gonna have to get off my butt and program the HV SOC, amps, and voltage
    XGauges into the SG. I suppose that readouts from the first, and one of the later
    two would be helpful investigative tools in a case like this.
