New TV
Discussion in 'Fred's House of Pancakes' started by Proco, Oct 20, 2010.
  1. Proco
    Proco Senior Member
    2,570
    172
    28
    The Beautiful NJ Shore
    Much like my long-delayed move to digital photography last year, I'm finally getting myself on the whole flat panel HD TV bandwagon. I'm trying to decide between LCD and LED.
    My living room is quite small (about 8' x 8'), so the largest I'd probably want to go is 37".
    So, what are your thoughts on LED vs LCD? Is there anything else I should be looking for (internet connectible, etc)?
    Thanks!
  2. daniel
    14,487
    1,519
    Spokane, WA
    Why in the world would you want to contaminate your home with a television???
  3. Proco
    Proco Senior Member
    2,570
    172
    28
    Tell you what, Daniel. I won't force my views on you if you don't force yours on me. Deal?
  4. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I'm curious as to which is better, too.
    While we don't have "television", that is, cable or broadcast TV, we do use our TV to watch movies from Netflix (and our own DVD library).
  5. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    I usually watch stuff on the computer. Big comfy chair, clear, detailed screen right up close, and awesome sound from aftermarket speakers. :)
  6. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    deceptive marketing: they're both LCDs and differ by back or sidelighting
    Unless the TV is OLED or AMOLED (there are none in large sizes on the mass market), a "LED" TV is actually a LCD with LED side or backlighting. It's stupid deceptive marketing started a few years ago by Samsung.
    If you wanted to call TVs by their lighting, then non-LED lit LCD TVs should be called fluorescent TVs or CCFL TVs.
    LED TVs: 10 things you need to know | Fully Equipped - CNET Reviews and many other places talk about this.
    An OLED TV (does not use any LCDs at all) was Sony kills XEL-1 OLED TV production in Japan, cites 'sluggish demand' -- Engadget. Problem was, it was almost $2000 for an 11 inch.
    edit: At least Samsung admits to this confusing naming via http://www.samsung.com/us/article/lcd-led-or-plasma-
    2 people like this.
  7. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    I moved up from an old CRT to a Samsung "LED" over the summer. Been very happy with it. I went for the 46" in the Ultraslim series. There were two main reasons: 1. Very low power usage. 2. It sits extremely close to the wall and where I have it mounted that makes a difference.
    Vidiophiles complain about the picture a bit, something to do with the blacks, but for my untrained eyes it looks great. Baseball playoffs in HD have been awesome, Go Giants.
    Jeff
  8. daniel
    14,487
    1,519
    Spokane, WA
    Where would be the fun in that? ;) Anyhow, I wasn't forcing. Just asking. Hard to force anybody to do anything over the internet.
  9. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Now if there was only something good to watch on TV.
    Get a plasma dude!
  10. Mark57
    2,945
    2,738
    OK
    If your room is very bright or has windows behind where you will be sitting to watch the TV, I'd stay away from plasma. The reflections in the screen can bother some people. (you see the reflections and not the picture) Plasma looks awesome in a dim room though. LCD/LED does a much better job at reducing screen glare for other light sources around the TV. Check this out by going to a store that has both plasma and LCD next to each other and walk side to side and watch for reflections in the screen. You'll see what I mean.
    Spend some time reading at the AVS Forum site. Don't let it overwhelm you though. There are some seriously smart people there regarding everything audio visual but don't expect an answer to "what's the best TV?" Do some leg work, use the screen size calculator and enjoy you new TV.
  11. davesrose
    davesrose Active Member
    767
    164
    Atlanta
    Plasma tends to give better color rendition at a cheaper price then LCD, but it also tends to be a technology for larger screens. If you're looking at 36" TVs, then I think it's only LCD at this size. LCD, OLED, LED are all technologies for adding improved contrast ranges. Instead of focusing on technology, the best thing to do is demo TVs. Go to your local Best Buy or TV store, and see if you can adjust the color of the TVs they have (sometimes, TVs are defaulty set at "vivid"...which cuts down on the contrast range to give oversaturated colors). For reliability, I'd rate Panasonic and Samsung as being high. Sony, IMO, is overhyped: my dad once got a Sony Wega TV that only lasted 2 years. My pany plasma is going strong, as well as all the Samsung plasma/LCDs that my family has.
  12. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    I have both a plasma and a LCD, and honestly can't tell a difference in picture quality (they're in different rooms, so can't compare side-by-side). The plasma does use more electricity, depending on brightness setting and what's on the screen. The Samsung 46" LCD actually uses less energy than our old 29" CRT, but that can vary from model to model - we also have a Best Buy store brand LCD model (32" I think) that uses more electricity than the 46" Samsung. (More electricity = more heat = more A/C usage in the summer). Plasmas are also heavier and harder to hang on a wall if that's your intention.
    But I'd say go for the 3D TV, and skip the whole 2D flat TV stage. Then you'd be the coolest people on the block and could laugh at the early adopters stuck with an old TV.
  13. nerfer
    2,507
    237
    28
    BTW - a 46" wide-screen TV will fit flat in the back of the Prius with the back seats down. A 50" TV probably fits, but would be the hairy edge, depending on speaker placement, etc. Go bigger than that and you need to carry it propped up in the back seat or something, a little scarier on the bumps and any sudden stops.
  14. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    I would recommend against the "dynamic" LED backgrounds that allow bragging about a higher contrast ratio vs the LED TVs that just have a constant backlight. The dynamic LED versions have a very mottled background that looks ugly once your brain starts detecting it. Go to a store, find a TV with dynamic backlighting, defocus your gaze on the screen and look for the "splotches" moving around. Also, if you are actually looking at any LCD TV, have them turn off the over saturated "display" mode. That's the TV version of selling stereos with the bass too loud.
  15. Proco
    Proco Senior Member
    2,570
    172
    28
    That was a thought, but all I have is this 13-inch laptop. Eventually I'll get a new computer, too. But that's not as big a priority.
    Thanks for the links. I'll check them out. I had read that "LED" is actually LCD. Obviously that's what I'm talking about. I'm not dropping 2K for an 11-inch TV!
    I'm the farthest thing from a videophile, so this is good to know. I'm not going to be creating a whole "home theater". I just want a good TV.
    The slimness of the "LED"s is one of the things that appeals to me. My living room (if you can call it that) is only 8-ft by 8-ft, so the slimmer the better.
    And I think you have a typo up there. I'm sure you meant to say "Go Phillies". :)
    It wouldn't be any fun at all. And, really, I should have expected that answer from you. That'll teach me to take such a long hiatus from PC.
    Thanks for the tip on what to look for as far as reflections go. And for the link to the forum. Fortunately my room doesn't have any windows behind where I'm sitting. Hell, it barely has any windows at all. But it's a well-lit room.
    There's good stuff. You just have to look for it. I'm not really interested in a plasma because of the power consumption. I want to balance the tv price & the power usage.
    I probably won't be hanging it on the wall, but that might change. Less heavy is good. I'm not a big guy & I'm not very strong.
    Thanks for these tips, too. I think I'm going to have to print this thread before I head to Best Buy!
  16. bisco
    50,804
    i have my heart set on a new led. 1/2" thick. i'm going to cut out the plaster and mount it flush on the wall. fantastic! who care about the picture?
  17. Proco
    Proco Senior Member
    2,570
    172
    28
    That's a great idea! Sadly, I'm renting and can't steal it.
  18. bisco
    50,804
    and you will have to pony up for an HD converter box to enjoy it. cost me and extra $8./mo. but my wife loves the redsox when they were playing.:(
  19. daniel
    14,487
    1,519
    Spokane, WA
    :D :D :D
    Enjoy your new TV.
  20. Proco
    Proco Senior Member
    2,570
    172
    28
    It'll be an extra 4/month for me. But I think I can afford it ... I've gone from a 2000/mo mortgage to 1100/mo rent. :)
