New VW Golf 62 mpg (US), 99 g/km CO2
Discussion in 'Diesels' started by clett, Sep 8, 2008.
  1. clett
    clett New Member
    537
    Scotland
  2. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    Concept? So this isn't going into production any time soon? If you read further, they are offering:
    At market launch, Volkswagen will offer two 2.0 liter TDI engines on the Golf, delivering 81 kW (108 hp) and 103 kW (138 hp). The 81 kW diesel has a fuel consumption rating of 4.5 L/100km (52 mpg US) and emissions of 119 g CO2/km—a reduction of 0.6 liter compared to the previous generation. The 103 kW diesel has a fuel consumption rating of 4.9 L/100km (48 mpg US) and 129 g CO2/km —also 0.6 liter less than the on the previous generation.
    Reminds me of the Jetta TDI that VW claimed would get around 70 MPG, then only got around 40 when it arrived in the US this year. I hope these Golfs will actually make something close to the numbers in the article
  3. Ogo
    Ogo Prius Owner since 2008
    220
    44
    Ilirska Bistrica, Slovenia
    Bluemotions from VW are almost undriveable. At least versions sold in Europe. They are made just to claim low consumption, yet they are expensive and full of compromises. From reduced soundproofing (take into consideration that VW diesels are still one of the loudest diesels around) to lower weight and tweaked gear ratios in manual transmission. At least in Europe Prius is way more driveable than VW Golf Bluemotion. Basically I was considering VW Golf, but ended up ordering Prius instead. ;)
    Ogo
  4. ken1784
    ken1784 SuperMID designer
    2,943
    1,380
    67
    Yokohama, JAPAN
    Is it the US T2B5 compliant?
    Ken@Japan
  5. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    I'm confused. What is the point of their telling us they could get it down to 3.8L/100km if they wanted to, but are actually going to sell it at 4.5L/100km and 4.9L/km?
    Rob
  6. Ogo
    220
    44
    It is called marketing mumbo jumbo. :)
    Ogo
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Very misleading. The title should include "BlueMotion" concept car.
  8. rpg51
    rpg51 Member
    200
    Vermont
    I'm probably biased - but it would take a lot to make me buy something other than a Toyota. It would take a REAL LOT to get me to buy another VW. I owned several in my day - seems like every one I owned was in the shop quite a bit.
  9. Alric
    Alric New Member
    1,526
    87
    VWs spend time at the shop but they sure are fun to drive.
    Keep in mind that diesel is just concentrated gasoline. In terms of oil consumption it about a little about half the mileage. So in gasoline terms it is only about 35 mpg.
  10. clett
    clett New Member
    537
    Scotland
    They drive just the same as the ordinary Polos/Passats etc if you can handle a manual gearbox.
    @Alric, "In terms of oil consumption it about a little about half the mileage. So in gasoline terms it is only about 35 mpg. "
    This is total rubbish. Diesel contains between 13% and 18% more energy per gallon (depending on season and locality) compared to gasoline. The fact that the CO2 emissions of the bluemotion Golf are less than 100 g/km confirms it is using less carbon and hence fossil fuel overall than any available gasoline car since the Honda Insight.
  11. Flying White Dutchman
    4,374
    313
    and still putting out a lot NOx compared to a same small size car and engine based on petrol.
  12. Flying White Dutchman
    4,374
    313
    the 3.8 is for the 1.6-liter TDI and the 4.5 and 4.9 is for the 2.0
