Newbie w/2015 Prius IV, 48500 mi. Advice?
Discussion in 'Gen 3 Prius Main Forum' started by BamRam, Jun 24, 2025.
  1. BamRam
    BamRam New Member
    Houston North
    I purchased an off-lease 2015 Prius 4 with 30,000 miles back in 2018. Car was in like-new condition. Still shod with serviceable original tires. Routinely got 50-55mpg for 5yrs. Changed tires to cheapo Chinese ($75/ea vs $185/ea for OEM). Mileage immediately dropped to 45mpg. I get it, softer compound/more rolling resistance, no biggee. Fast forward to present day; car now has 48,500mi and now only gets 35-37mpg. I have had local Toyota “stealership” where I had purchased it perform all recommended services at proper intervals. Any ideas as to what’s going on?
    Thanks!
  2. bettergolf
    bettergolf Active Member
    489
    368
    Sanford NC
    I have a 2015 with now 110k miles and still get 52-56 mpg in warm season. Overinflate the tires to about 40 for starters. Next you will hear from all the EGR zealots that will tell you to clean that system which has nothing to do with gas mileage.
    With that low yearly mileage, possibly your battery has been affected...it likes to be used and not sit around.
  3. BamRam
    BamRam New Member
    Houston North
    Thanks for the input. That’s troubling, but makes sense. I’m a classic auto collector with 8 vehicles, so the Prius certainly doesn’t get enough drive-time, nor do any of the others!
    I bought the Prius as an off-lease 2015 back in 2018, and have only put 18k miles on it. Recommended service has been done per Toyota recommendations at the “stealership” I bought it from, but I REALLY dislike that place. I’ve sat in the service waiting room and witnessed those oily commissioned service writers take advantage of little old ladies (yes, I’m old and grey but NOT an easy target! ), and nothing makes me madder!!!
    Anyway, I’ve been searching for the best OBD II scanner that will tell me about battery life…any input?
    Thanks!
    51,901
    tough one if you don't have any trouble lights.
    sticking brake maybe? dirty air filter? weak 12 volt?
    i'm assuming the dealer hasn't done anything but the recommended maintenance? are they following the time or mileage recommendations?
  5. rjparker
    rjparker Tu Humilde Sirviente
    10,139
    6,300
    Texas Hill Country
    You can't drive 70-75 mph on the freeways as the majority of your driving, you can't let it idle in Ready with the ac on for long periods and you can't have a weak hv battery.
    You do want to clean the maf sensor and throttle body.
    If the car burns oil a clogged catalytic converter is possible but this is unlikely at your mileage.
    Dragging brakes is an equally unlikely but easily checked.
    On very rare occasions a really bad 12v battery has been known to impact mpg due to excessive charging amps for long periods. Have it load checked.
