Newbie
Discussion in 'Newbie Forum' started by rkp, May 15, 2011.
  1. rkp
    rkp New Member
    Rochester
    Hello, just got my first Prius. A gen 3 model 3. Whats with the windshield glare from the display at night? Any fixes, and does anybody know how to shut off the center overhead counsel light at night? Other than that its a great car.
  2. john1701a
    john1701a Prius Guru
    12,793
    5,275
    57
    There's a dimmer and night mode. Rotate the vertical roller switch, on the dashboard to the left of the steering wheel.
    Enjoy your new Prius.
  3. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    Congrats and welcome to PC!
  4. rehillini
    rehillini Senior Member
    49
    Urbana, Illinois
    As said above, use the dimmer switch (find it in the owner's manual). Black tape (thanks to Car Talk) will turn off the down light. :cool: Too bad they did not make it blue.
  5. rkp
    rkp New Member
    Rochester
    Thanks, yeah I tried the dimmer but its either blacked out of reflecting off the windshield,
  6. rehillini
    49
    Urbana, Illinois
    After you back it out of the "Click" position, it should gradually dim down to "out". If not, see your dealer.
  7. bisco
    50,806
    if you leave the switch in the 'door' position, it will go out shortly after you exit the car. probably 30-90 seconds.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Welcome aboard and enjoy the ride. You could also us some chewed gum to block the shift LED. :)
  9. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    Congrats on your new Prius and welcome to PriusChat:welcome:
    My eye level is at a position where I've never noticed the display/windshield glare. In addition to adjusting the dash brightness switch, try adjusting your seat height and see if that reduces glare.
  10. cap160
    cap160 Older Member
    78
    Michigan
    Welcome:rockon:
  11. rehillini
    49
    Urbana, Illinois
    I think he was talking about the down light that illuminates the shifter while you are driving.
  12. rkp
    rkp New Member
    Rochester
    Thanks, I can try that, although I'm 6ft. 2in tall. The glare shows up on the windshield. The brightness I can adjust but even with it dimmed it's annoying having the reflection in your line of sight on the windshield.
  13. bisco
    50,806
    thanks, having a gen II, i didn't realize what a 'center overhead counsel light' was.
