Nickel Metal Hydride chemistry is very stable!
Discussion in 'Generation 1 Prius Discussion' started by bernie3015, Nov 6, 2014.
  1. bernie3015
    bernie3015 Member
    53
    36
    Los Angles
    I recently repaired a hybrid pack from an 2002 Prius. When I saw it, the check engine light was light and the master warning light (red triangle of death) was displaying and the following ODB II codes: P3000,P3006, P3020, P3023, P3024. It has been driven after the the warning were displayed. Probably very extensively. (recent change of ownership so missing data) All of the modules were within a tenth of a volt except two. The two modules were reading about 1 volt low. When I pulled them out I saw that one cell in each module had exploded and and emitted a black substance. However there was no obvious deterioration to the surrounding cells even the other cells in the same module. They were just blackened.
    For pictures on see the paragraph below. On the same page I have a picture that explains ODB II codes: P3011, p3012 etc. These are the codes that indicate out of spec differences in internal resistance in parts of the pack.
    I think you will like the pictures just go to: http://www.elearnaid.com/reyouhythivo.html and scroll down to see them. If you click on them you will get more detail.
    #1 bernie3015, Nov 6, 2014
  2. lylechill
    lylechill Junior Member
    NorCal
    2002 Prius
    I have a 2002 prius generating block two p3012 codes on dealership replaced battery 6 years ago. Also I get Cyl. 2 misfire codes. What would you recommend I do at this point at 200k miles. We feel it's better to put a couple thousand into our paid for used car rather than buy another car, if spending two grand with carry us through another few years. Are you still repairing cells, if so what does that run? thanks, Lyle Humboldt, CA
    50,827
    dictionaries and hybrid repair?(n)
