No sound
Discussion in 'Gen 3 Prius Audio and Electronics' started by AndrewGuffy, Nov 27, 2016.
  1. AndrewGuffy
    AndrewGuffy New Member
    Oakland
    No sound from speakers, but OEM display lights up as usual when I click on the power for radio, CD, AUX. Mystified. Two times before when this happened, I powered down the car and restarted, which 'fixed' it, but now it seems that trick doesn't work anymore. My dash looks just like this. Any tips would be greatly appreciated!!
  2. shadyahmad
    shadyahmad New Member
    Jordan
    Kindly check the Amplifier fuse...you will find it in the fuse box under the hood....my friend is currently having the same problem, still not solved.. he might have problem in the amplifier itself..if he find a solution I will post it here.
