1. FishinGeorge
    FishinGeorge New Member
    Muncie Indiana
    I'll change the hardware battery and the inverter I still can't get it to start what can I do to make my 05 second gen start
    50,800
    replace the 12 volt battery that is under the rear right hatch floor.
  3. Hayslayer
    Hayslayer Member
    162
    89
    George, you need to provide just a bit more information if you'd like an accurate answer that may help you.
    Your post is like saying..I woke up this morning. Can you tell me what time I went to sleep?
  4. MAX2
    MAX2 Senior Member
    1,333
    415
    101
    Third planet from the Sun
    Are you using any diagnostic tool, scanner?
    Are there any lights on the dashboard indicating system malfunctions?
  5. dolj
    dolj Senior Member
    8,108
    4,122
    Wellington, New Zealand
    Why will you change these items?
    What diagnostic process did you follow that led you to suspect that these items have failed?
    Brian1954 likes this.
