no water pump, yet must drive!
Discussion in 'Gen 2 Prius Main Forum' started by 100MPG, Jul 24, 2007.
  1. 100MPG
    100MPG New Member
    24
    shop told me that best and pulley for water pump bad on my '06. have been driving several days with the odd behavior, so am thinking that one more probably will not be catastrophic -- thoughts?
    the triangle of death comes on occasionally, but goes off again , too. the coolant has never boiled over, leading me to believe that the engine is not getting hot enough for morbidity or mortality. i guess since i am driving at sub maximum horse power, and in relatively cool climate (SF), that it's still within operating limits. (spits codes P0117 and P1121)
    so the question is, drive it home again tonight, to bring back in morning once shop has parts? or suffer horrible transportation problems.
  2. brick
    brick Active Member
    1,083
    79
    Upstate NY
    Risk ruining engine vs. inconvenience. I really don't want to sound condescending, but why are you even asking this question? All of the things under that hood that are cooled need to be cooled for a good reason. Cylinder heads warp and inverters crap out, and either way you're talking a lot of money and down time.
  3. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    There's gotta be a way for you to get around that's cheaper than a new engine.
  4. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    the horrible transportation problems would be risking having your engine crap out on you.
  5. 100MPG
    100MPG New Member
    24
    ouch! OK, i give.
    i'll admit i have been stupid. i guess i figured that as long as it didn't boil over, and since it was not always on, that it was so hot it would damage the engine, but perhaps that was naive. these engines are precision instruments, aren't they.
    i will suffer now, for future security and solvency...
    thanks for the sanity and forthrightness!
    <div class='quotetop'>QUOTE(brick @ Jul 24 2007, 04:24 PM) [snapback]484331[/snapback]</div>
  6. brick
    brick Active Member
    1,083
    79
    Upstate NY
    Don't take it personally. We just hate to see a good Prius go bad, and a happy Prius owner head to the GMC dealership. Hope you're back on the road soon!
  7. KTPhil
    KTPhil Active Member
    1,379
    SF has a great public transportation system--just use it instead!
  8. 1fixitman
    1fixitman Member
    182
    Augusta, GA
    <div class='quotetop'>QUOTE(100MPG @ Jul 24 2007, 05:20 PM) [snapback]484324[/snapback]</div>
    I agree on the public transport thing.....on the other hand....how many miles are on your prius and has it ever been involved in a accident on the front end?
    D Rock
  9. 100MPG
    100MPG New Member
    24
    how'd you know? indeed, it has been in a fairly serious frontal-offset collision. 15K miles.
    previously, it had a weird, subtle problem that confounded everyone, including the dealer; turned out to be a *hairline* crack (non-structural) in the intake manifold -- which i fixed by cleaning with brake cleaner then applying a bead of high-temp RTV. worked like a charm, $5 insteat of $500, tho i guess a little kludgy to some aethetic tastes, a bit like fixing something with baling wire and duct tape, but hey...
    <div class='quotetop'>QUOTE(D Rock @ Jul 24 2007, 09:46 PM) [snapback]484483[/snapback]</div>
  10. richard schumacher
    7,664
    1,042
    United States
  11. 100MPG
    100MPG New Member
    24
    JTDKB20U753089377
    why?
    <div class='quotetop'>QUOTE(richard schumacher @ Jul 25 2007, 04:28 PM) [snapback]484984[/snapback]</div>
  12. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    <div class='quotetop'>QUOTE(100MPG @ Jul 27 2007, 06:54 PM) [snapback]486405[/snapback]</div>
    So he knows what pre-owned Prius to avoid, why else?
    Previous accident damage is always the likely suspect when unusual malfunctions occur. Why wouldn't insurance cover the damaged manifold, even if post repair claim.
  13. pEEf
    pEEf Engineer - EV nut
    720
    579
    Berkeley, CA
    Yeah, the shock of an accident can put stress on the water pump bearings, which will fail much sooner than normal.
    FYI, see my post about increasing water pump longevity: PriusChat Forums
  14. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    Just to add a bit of tech info to the mix, while the engine may not -boil- the coolant, it can boil in small locations if the coolant isn't flowing. Probably didn't happen to you, but I've seen it on other engines with subsequent ring failure due to overheating (they soften and don't seal any more). You can actually get away without a radiator as long as the coolant -flows- through the engine, as long as you aren't producing a lot of power (highway) and/or the ambient temp is not very high.
  15. pEEf
    720
    579
    Berkeley, CA
    As another aside, Long before I got my Prius, I heard from a 2004 Prius owner that had a pump start to seize up at around 140k. He was driving from Saline valley (in the middle of nowhere) so he decided to cut the belt off and try to keep driving. It was not hot outside, and he simply kept the heater on max and drove slowly out (which you have to do on that trail anyway). Combined with the low temps, The electric heater pump must have circulated enough coolant to avoid an overheat.
    Not saying that this is recommended by any means, but he did it and his car is still on the road!
    I suspect the pump failure, especially in this manner, was due to the belt being too tight, which is why mine is loose now! (see post linked in my above post for more info)
