Noise Control (Sound Vibration Damping)
Discussion in 'Gen 3 Prius Audio and Electronics' started by Gwest, Jan 13, 2010.
  1. Gwest
    Gwest Member
    97
    Redwood City
    Hi this is my first post. I picked up a 2010 V last week. After spending a few day's in the car I have come up with, "my Prius is pretty loud inside"
    I drove for 3 hrs in my wife's Lexus IS 350 this weekend and got used to how quite it was. I then jumped in the Prius and quickly found out how tinny sounding and how much road noise comes threw the car.
    I have always wanted to do a sound project like this so I guess this will be my first one.
    I plan to do the project in 3 stages.
    Stage 1. Doors
    Stage 2. Floor
    Stage 3. Roof
    The Company I’m getting the stuff from is called Cascade audio they sell an assortment of sound product's
    I will list all the products I use and take pictures along the way.
    I also have a DB meter so I can take sound measurements with each part of the project. With each stage I pan on taking a sound reading to see how much sound is dampened.
    Disclamer: Im no sound engineer or guy in a white lab coat. Just a DIY'r that's gonna try and make the ride in my car a bit more quite. Thanks
    2 people like this.
  2. Radiant
    Radiant New Member
    148
    17
    NE
    If you look into rust-proofing the under carriage, it also has the effect of damping road noise.
    I must have gotten a good one as the only time I heard a rattle was when it was
    -15 F, and the console kinda squeeked.
    I am hoping for the best and I am interested in knowing how you sound proofing turns out.
  3. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Please post info about your suppliers and costs. Some folks have stated that roofing membrane (Home Depot stuff) works as well as the hyped sound deadening products.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    :welcome:,
    And looking forward to the results!
  5. Gwest
    Gwest Member
    97
    Redwood City
    Go to cascadeaudio dot.com check out the products they sell.
    IMO they are the real deal when it comes to sound damping. Some friends that have Car audio install shops have been using the cascade products for some time and are very happy with them. My door kit to do all 4 door gets here on Friday. Im planning on starting Stage 1 this weekend.
  6. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    I looked into this a while back - these guys have by far the best range of product (and the cost is *much* lower than the "audio" stores). You can get varied thicknesses depending on the room you have...http://www.soundproofing.org/sales/prices.html
    Also, just FYI - removing the roof is *not* an easy task - it entails removing most of the interior trim. There's a post somewhere on this.
  7. MikeDS
    MikeDS Member
    298
    Los Angeles
    Awesome...can't wait to see it. I also can't wait to see the dB numbers. I've considered doing this myself, but I'm not sure how much impact it will have. If you can pull a couple db of noise out of the cabin, that'd be great...
  8. capek
    capek New Member
    78
    Houston, Tx
    Ya, very interested too. Glad a guinea pig has come forward, because I would never try this stuff on my own!:)
  9. Gwest
    Gwest Member
    97
    Redwood City
    [FONT=&quot]OK: My material didn't get here in time for this weekends project. But I did take some sound readings. Here is what I came up with. My Prius has the leather interior. My friend with a Gen 2 reports that people have said the cloth interior cars seem to be a bit more quite than the leather cars.
    Sitting with car with everything turned off (not running) = Low to 49 db
    In car with motor running= 60.1 to 63.6
    City driving 35 mph= 84.6
    Freeway driving =88.9
    How I came up with these readings
    I held the sound meter in my hand. About chest height in the center of the car. Each reading was recorded for a 10 seconds. I will take all my readings on the same stretch of road for the same 10 seconds.
    I’m using a Extech 407727 (I would post a link but I’m not allowed)
    I drove for over 200 miles yesterday with the sound meter in the car. Road surface has everything to do with how loud or how quite the car is. Roads that have a surface that is very aggregate or exposed like very open concrete make a loud rumble generating from the tires and going threw the whole car. This sound makes the sound meter and my ears spike in sound level. I haven’t taken any readings on road surfaces that Im taking about yet. But Im guessing its gonna be over 90 DB @65 mph.
    One last thing I think most of the noise is comming form the floor. When I held the sound meter down by the floor the same road surface would make the DB jump up by 8 to 10.
    [/FONT]
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Interesting readings... they seem high to me for some reason. Anyway, will be great to see the reduction after the material is applied. Thanks!
  11. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    I used about 125 sq. ft. of b-quiet in my Prius II. It is the thinnest and lights of the all the sound damping material I could fine. That added about 85lbs to the car. The only part I did not get to is the roof. I still have about 25 sq. ft left and I will tackle the roof when I have a moon roof installed. The Doors are not that hard but I would suggest you take your time with the front doors. that metal is really sharp and really tight spaces to get thru. Just a note, the speakers are mounted with rivets. You will need to find screws to replace if you decide to dismount the speakers when applying the damping material.
  12. Gwest
    Gwest Member
    97
    Redwood City
    Banshee: Thanks for the heads up. I will be sure to wear glove when installing and working on the inside of the door. Yes I will have to drill and then re install the speakers if they are riveted in again thanks 4 the Heads Up. I’m planning on using V-block. Its a dyna matt style sticky backed rubber with a metal top sheet on in Inside of the outer door skin. I plan to cover as much of the inside door skin as I can get to. Then I plan to cover the door skin (the part the door panel sits against) with the DK-1 material it’s a rubber/metal insulator sheet that sort of shrink wraps to the door skin. The Vblock is to stop the metal from resonating and the rubber/metal sheet is to stop what ever noise coming threw the door panel. I have a pretty good feeling im going to notice most of the sound coming threw the floor.
    I will keep track of all the material that I install in the car as to keep track of the Sq footage and the weight.
    Banshee you did the Doors and the floor all with the same material??
    As far as my number being high with the meter I’m sure all meters are a bit different. I plan on doing the same test a few different times on the same stretch to see if the numbers are the same again.
  13. Gwest
    Gwest Member
    97
    Redwood City
    So I started my little project today
    I took the Door panel off. Pretty easy. Simple clips all around the door panel. A screw behind the door handle and a screw in the cup of the side panel.
    Once I made a map of where all the wires go I took off all the wires from the door.
    I then put the V block. This material is much like the popular Dyna matt. I coverd as much of the inside of the door as I could. I used 2 sheets of V block for the drivers door. This is what the coverd inside of the door looks like.
    Then I coverd the door panel with the DK-1 Door kit. I used 2 Sheets out of the DK1 kit the kit comes with 4 Sheets and some foam for around the speaker.
    9 people like this.
  14. Gwest
    Gwest Member
    97
    Redwood City
    It took about 3 hrs to do one door, I could tell as soon as I was finished and I closed the door that it was a much more solid and tight feeling. I sat in the car and closed and opened the door and again it sounded and felt much more solid. I opened and closed the unfinished passenger door and I was blown away how you could hear a big difference in how the car/door sounds with finished Vs an unfinished door. Tapping on the out side of the door again you can hear a huge difference. The stock door sounds so tinny and cheep you would laugh if I took a video with audio
  15. Gwest
    Gwest Member
    97
    Redwood City
    9 people like this.
  16. MikeDS
    MikeDS Member
    298
    Los Angeles
    Awesome! Thanks for the pics! How did you get the stuff inside the door? Just cramming your hand through the hole? It doesn't seem like you could get that much in there. It'd be great if you could shoot some video of the process when you do the other door....hopefully this one won't take as long! :-D Can't wait to see the db numbers...
    Thanks!
  17. ScottG10
    ScottG10 Member
    132
    Bothell Wa.
    I cant wait to find out what the difference in dB's is with this mod. The only down side I can see is that your hard work will get all torn up if the window ever has to be replaced, but thats probably not very likely.
    Looking forward to more!
  18. Gwest
    Gwest Member
    97
    Redwood City
    The weather out here in Ca has been real bad. I havent been able to take any DB readings because I think the wet roads are going to give me high numbers. I wanna take DB reading under the same conditions.
    A dry non windy day.
    After doing this to the doors you notice all the other panels on the car that need this fix, "Like the hatch" I plan on doing the hatch and the inside of the quarter panels as well.
  19. jdenenberg
    jdenenberg EE Professor
    3,910
    1,908
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Most Sound Meters can measure dBa and dBc. The difference being that dBa tends to ignore low frequency noise. Which one did you measure in the BEFORE test? Can you take both readings in the AFTER test?
    JeffD
  20. ScottG10
    ScottG10 Member
    132
    Bothell Wa.
    Any more news on your project Gwest?
    Your fans are anxious to hear from you!
