Non-operation
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Lynne, Jun 3, 2007.
  1. Lynne
    Lynne New Member
    I'll be leaving town for about 6 weeks, and wonder if it's OK to let the car sit for that long without charging the battery?
  2. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    <div class='quotetop'>QUOTE(NCowner @ Jun 3 2007, 05:22 PM) [snapback]454596[/snapback]</div>
    The only thing that you should do is to disable the Smart Key System. This is done by pushing the little button under the steering wheel labeled "Key." It is thought that, if you leave it on, it could run down the 12V battery (i.e. not the big battery that powers the electric motor, but the small battery that powers the lights, radio, etc.). Some have left it on with no problems, but since it's just a push of a button, it's worth taking the precaution.
    Of course, with the SKS off, you'll have to insert the FOB into the slot in order to start the car, so you should make sure you turn it back on as soon as you get back so you won't have to suffer through that hardship :)
  3. Lynne
    Lynne New Member
    <div class='quotetop'>QUOTE(Betelgeuse @ Jun 3 2007, 05:30 PM) [snapback]454646[/snapback]</div>
    Thank you. I'll do that.
  4. Rest
    Rest Active Member
    1,210
    CA
    How long do you think they sit from the factory in Japan until someone in the States buys one?
  5. richard schumacher
    7,664
    1,045
    United States
    No time at all. It takes about a month to ship them, and then they get prepped, and then they sit for, what, a few days on the dealer's lot? And unless someone screwed up the SKS is turned off most of this time.
