Not in Park; Won't Start
Discussion in 'Gen 2 Prius Technical Discussion' started by pamprius04, Jun 17, 2009.
  1. pamprius04
    pamprius04 New Member
    Georgia
    Getting message on display when trying to start car that "Car not in park....." Usually let sit for a few minutes/hours then it will start; however, this morning after sitting over 12 hours it would not start. 12 volt battery has been replaced. This just started again with 2 of these instances since Sunday. Also difficult to get car to turn off when this message is displayed. This is driving me crazy. Car has 95K miles. Help.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    When was the 12V battery replaced? Are you getting good voltage on the 12V bus? Have you checked grounds?
    Tom
  3. pamprius04
    Georgia
    12 volt replaced less than 2 months ago and appeared to have solved problem. I am not good with batteries so I really don't know where to check.
  4. daniel
    14,487
    1,519
    Spokane, WA
    Post your question in the car forum and you'll get a lot of useful advice. This is the forum for questions about the web site itself. Lots if folks never look in here.
  5. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    I didn't even notice. Thanks, daniel. I'll move it.
  6. Patrick Wong
    18,210
    6,510
    Next time this happens, please look at the dashboard shift indicator, and see what "gear" the transaxle is in. Does this show P, or some other range?
    Who replaced the battery?
    If the battery is suspect, the tightness of the battery cable connections needs to be checked. Also, the voltage of the battery needs to be measured after the car has been sitting IG-OFF for a few hours.
  7. spitinuri
    spitinuri Member
    317
    The 12v battery is the most likely cause. Check the connections. If the battery is new it probably has been discharged. The question is what is causing it to discharge? I'd start with a diagnostic from a Toyota Certified Mechanic. Who changed your battery?
  8. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    If the battery really is new, was it fully charged - as recommended - before installation, or just dropped in?
