Not starting - HV battery one bar
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jama707, Mar 3, 2024.
  1. Jama707
    Jama707 Junior Member
    53
    SACRAMENTO, CA
    I’ve 2011 prius that showed hybrid battery problem while I was on freeway and didn’t start after that with p0a80. Towed it to home and put it on prolong charger and it had 180v initially and now it’s 215V but still not starting. When I push the start button while keeping foot on the brake it goes into ready mode and shows only one bar of battery and can’t start the car no noise nothing… just one clunking noise as if it tried to start but could not. What could be problems? I don’t have any code. Previously I just saw p0a80 but after reading with xtools, I see C0200 and c0205 front left & right speed sensor
    Now it doesn’t have any code
    - I tried starting the car’s 12v with a jump box at 35amp. But no luck.
    - Tried to put into to maint mode but still the same.
    starting video:
    https://youtube.com/shorts/dm2_2igoXmQ?feature=shared
    #1 Jama707, Mar 3, 2024
  2. Jama707
    53
    SACRAMENTO, CA
    Closing: the engine was seized and swapped the engine.
