Now, Ain't That A Dande-lion
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by El Dobro, Feb 19, 2013.
  1. El Dobro
    El Dobro A Member
    7,071
    3,258
    F8L likes this.
  2. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I've had orange peel tires and sunflower seed tires but never dandelion tires. :)
  3. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Just saw a news report about rabbits chewing on automotive electrical wires with soy based insulation. Seems to be quite a problem at Denver International's long term lot.
  4. JamesBurke
    1,222
    493
    27
    Morgantown, WV
    I heard there are trees in the South Pacific that have rubber for sap. Maybe we should use these as trees are a renewable resource. Maybe they would also grow someplace like Brazil. Worth looking into?
  5. Trollbait
    12,312
    Ford tried a rubber tree plantation back in the'20s or '30s. Turns out rubber trees aren't suitable for orchard planting. A certain disease could readily spread through the entire grove. Wild trees are only found individually because of this. Don't think this has changed.
    The discovery of synthetic rubber made the expensive natural rubber obsolete.
  6. austingreen
    austingreen Senior Member
    13,635
    4,177
    Austin, TX, USA
    It was shortages from war that caused the switch to synthetic. WWI caused rubber shortages and high prices. The US even created a rubber cartel in the 1920s. The Russians built the first plant in the 1930s. The Japanese controlled the rubber supply in WWII so the US needed to use Synthetic rubber for its needs. This pushed better processes and much lower prices, and during WWII the US had the raw material oil. The Allies even targeted bombings of Nazi synthetic rubber plants at the end of the war. After the war the cost of the synthetic was so much cheaper than natural rubber. Dandelions may also be less expensive, idk;)
    Renewable does not necessarily mean environmental. You are right, Ford attempted to do Rubber plantations in brazil in 1928-1945, but ran into cultural problems and leaf fungus. Cutting down rain forests to plant crop trees may not be the best for the environment. A crop is more prone to blights and parasites. After WWII with inexpensive synthetic rubber available for cars, Ford stopped the experiment. The Malaysians do have the rubber plantation agriculture worked out now
    Rubber Cultivation in Malaysia
    mrbigh likes this.
  7. strongbad
    strongbad Member
    170
    47
    Driggs, ID
    Great. Just what we need: genetically modified dandelions with larger roots and herbicide resistance. And these are supposed to stay where they're wanted and not spread to where they're unwanted.:rolleyes:
    austingreen likes this.
  8. El Dobro
    El Dobro A Member
    7,071
    3,258
    I'll gladly donate the dandelions that pop up on my lawn in the Summer.
  9. Scorpion
    Scorpion Active Member
    440
    162
    Lincoln, NE
  10. El Dobro
    El Dobro A Member
    7,071
    3,258
    If they can also use crabgrass, it'll be a win/win situation.
  11. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    They need to figure out a way to use non-genetically modified weed species. This would be a win-win for landowners and City managers who have to deal with weed management. Turn a field full of starthistle or kudzu into tires! That would save on management costs. :)
  12. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    This is interesting as it sounds like they are trying to find a way to use dandelion roots to create "rubber" as a whole.
    I own a set of Yokohama Avid Ascends, that employ the use of "Orange Oil". But in the case of these tires, the "Orange" additive is a fraction of a fraction of an additive used to manipulate the characteristics of the rubber.
    This sounds more like an attempt to create a new source of the rubber itself.
