I am experiencing some confusion about the number of cells in the several generations of HV battery packs. Seems some have 38 modules and some have 28 modules. Could someone in the know please clarify which generation has 38 modules and which generation has 28 modules? Thanks for your help, Roger
168 cells in 28 modules 97 Prius (Generation I) Japan Only 00 Prius (Generation II) 04 Prius (Generation III) 2010 Prius (Generation IV) Form Factor Cylindrical Prismatic Prismatic Prismatic Cells (Modules) 240 (40) 228 (38) 168 (28) 168 (28) Nominal Voltage 288.0 V 273.6 V 201.6 V 201.6 V Nominal Capacity 6.0Ah 6.5Ah 6.5Ah 6.5Ah Specific Power 800 W/kg 1000 W/kg 1300 W/kg 1310 W/kg Specific Energy 40 Wh/kg 46 Wh/kg 46 Wh/kg 44 Wh/kg Module Weight 1090g 1050g 1045g 1040g Module Dimensions 35(oc)x384(L) 19.6x106x275 19.6x106x285 19.6x106x285
