OBD 2 - Freematics Arduino I2C Adapter
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Monroe07, Oct 12, 2015.
  1. Monroe07
    Monroe07 Junior Member
    California, United States
    So I've got a 2012 Gen 3 Prius and I've been trying to use the Freematics brand I2C OBD adapter. I've got a few PID's working but my speed is off and I can see the RPM properly, but I can't get a reponse from the Fuel Level or Hybrid battery state of charge PID's. Anyone have any success? What PID's are you using? Side note, I've tried all the usual ones from various sites. Not sure what I'm doing wrong
  2. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    What software are you running?
    The fuel level and hybrid battery state PIDs don't work with Torque and the Prius. Check out this thread for Torque PIDs.
    I know my speedometer reads 2 MPH fast, and Torque displays the correct speed.
  3. Monroe07
    I'm not using a software per se, I'm using an arduino-to-OBD 2 adapter. I stated that above. It's all arduino based, and most (all but 2 useful ones at least) are not responding. What type of network is the fuel state reported on? I know the Prius has at least 2 different types of "computer" networks on it. Anyone know how the sensor in the fuel tank sends out info to the car? Is it a 5v sensor that puts out a voltage relative to the amount of fuel detected much like a photo-resistor does with light level? On a separate note, is the hybrid battery state of charge sensor working on a similar network/principal? The car knows the battery level, with the right info, it should be possible to recieve the same info and process it into a usable value
  4. Monroe07
    On another note @Redpoint5 does your readout show mph natively or does it convert from kph? I've seen mixed info on that
  5. Redpoint5
    1,026
    509
    Portland, OR
    I haven't studied OBDII protocol or the Torque application at all, so I don't know what the OBDII natively sends. I'm merely able to follow instructions found on this site to import PIDs relevant to the Prius, and from my observation have failed to receive data for both the hybrid battery SoC and fuel level. I am able to see individual bank voltages, and having a PiP, also can display the overall battery SoC, but the one labeled hybrid battery SoC doesn't work.
  6. BZzap!
    BZzap! Senior Member
    1,607
    878
    These are the codes I have programmed into my ScanGauge
    1. SOC TDX 07E2015B RXF 0441855B0000 RDX 2808 MTH 03E800FF0000
    2. FLv TDX 07C02129 RFX 046185290000 RDX 2808 MTH 13880EC90000
    These are from the ScaNGauge CANSF guide.
    Try these an see what happens.
  7. Monroe07
    So, BZzap!, The 2 codes you are providing work for you?
    The problem I have with the ones you provided is that I have to decipher what I need to send via the Arduino. The library I'm using to communicate sends a lot of the headers for me, and perhaps I need to delve into it to change some things, but that's for another day. from what i can tell, and if you know more about this than I do, please do tell me,
    SOC should be sent as a mode 2 PID, and the PID itself is 015B
    Fuel Level is also a mode 2 PID and should be 129
    I'll try them and see what I get (or don't)
  8. BZzap!
    1,607
    878
    The 2 code that it sent work perfectly for my ScanGauge. As you stated, the language these two devices use is like Russian vs Latin. The code I supplied are the queries for the CANSF protocol that the Prius ECM understands. I'm not familiar with the FreeMatics. You may have to go to the technical people at FreeMatics.
  9. Monroe07
    So after spending the better part of a day, I'm at my wits end with this adapter. My goal was to be able to take data from the car, like speed, SOC, and fuel level and put it on a heads up display on the dash of my car. My entire project is/was centered around using this adapter. Guess it's getting scraped unless someone out there can figure it out. Thank you for your help, to both of you
  10. Monroe07
    OK, so I got another Arduino CAN Device, from SeeedStudio, which appears to be easier to use provided that one knows exactly what to send, which I don't. BZzap!, do you know what each of the fields means? for example,
    Do you know what the purpose of TDX, RXF, RDX, and MTH Stand for or are doing?
  11. BZzap!
    1,607
    878
    These a acronims are proprietary codes for the Linier Logic (ScanGauge) I.e. TDX: transmit data, RDX: receive data, RXF: receive filter data and so on. Essentially, they are just a way to identify the alfa numeric strands of numbers and letter that the system protocol needs to communicate back and forth. As for figuring out how your Adrurino interprets the necessary codes is way beyond me. Hack your vehicle CAN-BUS with Arduino and Seeed CAN-BUS Shield
    #11 BZzap!, Nov 2, 2015
