Obd 2
Discussion in 'Gen 2 Prius Technical Discussion' started by My08, Jun 10, 2009.
  1. My08
    My08 Junior Member
    NY
    I have a OBD2 reader - will this work with a 2008 Prius and where is the connection point - Thanks !
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Look below the steering column, a standard OBDII port is there. You will be able to access generic mandated OBDII codes, manufacturer-specific may not show up
  3. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The Prius uses the CAN protocol which is not supported in some lower cost OBD2 readers (I have one that doesn't do CAN). If it doesn't sync up, you will need a new one. The AutoGenuity with the Toyota option can read most of the codes:
    AutoEnginuity® - OBD2 Scan Tool - Professional PC and PDA Diagnostics
    but is expensive.
    The ScanGuage:
    ScanGaugeII - Trip Computers + Digital Gauges + Scan Tool
    can read some of the hybrid codes using its "XGauge" feature.
    JeffD
  4. tortus
    tortus New Member
    minnesota, USA
    I have scangauge2 that does not read inverter or traction battery temps with the Xgauge. Will the autoenginuity tool extract these temps from a 2009 Prius C.A.N. potocol?>>>Tortus
  5. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Autoenginuity or any "real" scantool that is Toyota-enhanced
    can read that stuff. The Scangauge cannot because it doesn't
    handle multi-frame responses. See some of the Scangauge / Xgauge
    threads over on CleanMPG for more info, and/or this
    and the "network packet" dump linked therefrom.
    _H*
