odometer reset
Discussion in 'Gen 2 Prius Technical Discussion' started by tfelder, Jun 8, 2006.
  1. tfelder
    tfelder New Member
    If the 12 volt battery is disconnected, is the odometer setting retained in the computer?
    I think I remember reading that the time and radio settings would be lost.
    Thanks
  2. brandon
    brandon Member
    771
    Manhattan, KS
    Not a Prius tech so I can't say for sure, but I suspicion that settings like that are stored in non-volatile memory and would not be affected by disconnecting the power to the 12-volt system. Just a guess, though.
  3. john1701a
    john1701a Prius Guru
    12,793
    5,274
    57
    Much like the memory used in digital cameras, no power is used to retain data.
    So nothing will be lost, even if separated from the hardware it interfaces with.
  4. tfelder
    tfelder New Member
    <div class='quotetop'>QUOTE(john1701a @ Jun 8 2006, 07:21 PM) [snapback]268335[/snapback]</div>
    Thanks to Brandon and John for the replies.
    By the way, John, I have your website bookmarked and have enjoyed it on multiple occasions.
    Skip
  5. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    the only way to change an odo is to have a wrong number mistakenly programmed in at the factory when ordering a new one.
