Odometer Sync?
Discussion in 'Gen 2 Prius Technical Discussion' started by Proco, Feb 27, 2009.
  1. Proco
    Proco Senior Member
    2,570
    172
    28
    The Beautiful NJ Shore
    Is there some way to "sync" one of the trip odometers with the actual mileage on the car? I use Trip-A for my measurements between fill-ups and use Trip-B to confirm actual mileage on the car.
    Unfortunately, I accidentally reset Trip-B a couple fill-ups ago and I'd like to get it back in sync.
    I know I don't need to have my mileage down to the 1/10 of a mile. It's just one of my little quirks.
    If my ODO reads 67600, I'd like Trip-B to read 7599.6 (or whatever).
    Thanks!
  2. dogfriend
    7,512
    1,188
    Carmichael, CA
    Ummm....If your Odo reads 67600 doesn't that mean that your car has 67600 miles? I don't think it is possible to sync the Trip B and the ODO unless you never reset Trip B ever.
    FWIW, I use Trip A to track current tank mileage, Trip B to track mileage since last oil change / service. Odo = mileage on car.
  3. JHSmith
    JHSmith 2020 Avalon Hybrid Owner
    184
    King George, VA
    Not sure about Prius, on my '07 Camry Hybrid, to clear the MAINT RQD light (5,000 Mile Oil Change alert), you need to reset TRIP A. Therefore, I use TRIP A for distance since oil change and TRIP B for distance on the tank.
    Concerning synchronizing the a TRIP readout with the odometer, I would say that it is most likely not possible (at least at the "normal" user level).
  4. dogfriend
    7,512
    1,188
    Carmichael, CA
    I think I finally caught on to what you are asking. I also think that it *may* be possible to sync under special circumstances:
    Wait until you are almost at a round 70000 miles (or whatever the next mileage rounded to the nearest 10,000 miles). Once you reach the rounded mileage, stop the car, and reset Trip B to 0. Now when you have 70,132 (or whatever), Trip B will read 132.0 (or whatever)
  5. avocadoman1
    avocadoman1 Member
    217
    36
    Fallbrook-CA
    2022 Prius
    i do what he said. plus the idiot lite on the dash tells me when i need an oil change as well.
