I've done a search through the forums and my understanding is that some people who have replaced their OEM halogens w/ brighter bulbs (such as PIAA, Philips Vision Plus, etc.) have reported a significantly shorter life span for the new bulbs (in some cases, I've seen indications that the bulbs last less than a year). My prior car had xenon headlights. Making the change from xenons to halogens has been tough, as I appreciated the brighter lights of the xenon headlights in comparison to the halogens. I wanted to see what options I had for my Prius; I am particularly interested to see whether anyone can recommend (a) better, longer-lasting bulbs that will make night-time driving easier, or (b) a retrofit xenon/LED kit. I did run across this thread that seemed interesting: Found an Alternative to Xenon Supply ...CHEAPER TOO (Pics inside...) | PriusChat. $120.00 seems very inexpensive though, which concerned me. Any recommendations would be greatly appreciated!
My personal opinion is to do a retrofit. TRS has made it a lil eaiser thanks to a member here (I forgot who) by fabing up a complete drop in retro. All that is needed is to open the headlights. Check it out: Morimoto Retro-Quik System - Complete Retrofit Kits from The Retrofit Source Inc
Do you know if opening the headlight housing is difficult? I've been looking for a reliable HID kit.. Is the retrofit kit the best there? Thanks
If u have never opened a headlight before, I strongly suggest u buy a used headlight to Try opening 1st. The last thing u want to do is experiment on ur headlights & ruin them. What I normally do is strip the headlight of all bulbs, screws etc. Pre-heat the oven to 200 deg F. I place the headlight in the oven (keep the heat on) for 10 mins. Take it out & pry the lens away from the housing making ur way around the headlight. U may have to put it back in the oven again & repeat.
