# of minutes the A/C will run w/o ICE
Discussion in 'Gen 2 Prius Main Forum' started by Air, Mar 15, 2008.
  1. Air
    Air New Member
    I have google searched and read through this forum for at least two hours. I can't find a single post to answer this question, and I'd go to the dealer to answer my question with a 2008 Prius yet the temperature is near freezing.
    My question is: How many minutes will the Prius keep the cabin cool before it turns the engine on to recharge the batteries while parked YET ignition turned on (if there is an on setting)?
    I realize this will vary depending on the outside temperature and the temperature set on the climate control system. I've been reading about how the 2004+ Prius' have an electric A/C system that will run with the engine turned off, yet it doesn't mention how long.
    So I'm assuming not very long, but I'd like to know actual minutes. Can someone tell me a ballpark number using what the outside temp is and the climate control setting temp?
    Thanks!
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    It varies...
  3. Patrick Wong
    18,200
    6,490
    The amount of time also depends upon the traction battery state-of-charge at the onset of this little exercise. In general, once the Prius gasoline engine has warmed up and then the Prius is placed in Park, the engine will stay off until the SOC drops down to show two pink bars on the MFD SOC indicator. Then the engine will run to bring the SOC up to three blue bars. This cycle will continue indefinitely.
    If the SOC started at eight green bars, the outside temperature was moderate and the inside requested temperature also was moderate, the air conditioning might run on battery power alone for perhaps a half-hour or longer... At some point the gasoline engine might start just to keep the catalytic converter hot, independent of the traction battery SOC.
  4. Air
    Air New Member
    The number of minutes is relative to any number of conditions. The better way to ask this question is how much power the electric A/C motor draws, however that question was asked in this forum before without anybody responding so I suspect it's unknown.
  5. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    my initial results are, and this is no means an official study of the matter is this
    if you turn on AC and leave AUTO OFF, and keep it maybe under 72 or so
    the traction battery might be able to keep the a/c going for 30 minutes
    if you leave it on AUTO ON with the temprature set to 72 or more and
    its kind of cold out, the engine will probably run maybe 10 or so minutes
    out of that 30 minute period
    to get most of the power out of the traction battery and not have to worry about the engine turning over, keep it in "auto ac off" mode
    a/c auto off mode will tend to run the battery towards the low end
    aufo on keeps the battery towards medium - high charge, because it needs to run the engine to HEAT the cabin
  6. richard schumacher
    7,664
    1,042
    United States
    We have to ask in reply, why do you want to know?
    If the engine is not allowed to recharge the main battery the A/C will drain the main battery in (variable) short order. If you want to stay in the car with the A/C running leave the car ON and in Park, and let it run the engine to recharge the battery as needed. If you won't be in the car, or if you are in a place where you must not allow the engine to run, then turn the car OFF and do without A/C.
  7. Air
    Air New Member
    Thanks for the reply.
    Interesting, approximately how long does it take at idle to recharge the batteries from 2 pink to 3 blue? Approx how long does it take to recharge the battery from 3 blue to 8 green on an Interstate highway? From what I can tell the discharge of the battery is rather quick between 3 blue and 2 pink, so the engine would likely be turning itself on and off within a short period of time. I wonder what the reason for the engine turning off after only an increase of one bar would be...using some true SOC information between 3 bars and 2 bars is about 4 percent of the 1.3kilowatt hours which comes to around 52 watt hours...the car would only be able to power the A/C without ICE for about another 4 minutes before reaching the 2 bar status.
    My math may be off but assuming 2 pink is 43 to 47.5% of true SOC from 8 green bars of using that information the watts used by the vehicle to run the A/C when turned off 75 to 81% of true SOC, it seems like the A/C to is between 600 to 750 watts.
    1.3kilowatt hours in the Prius utilizing 77.5% (8 bar)-47.5% (2 bar) = approx 30% of battery of true SOC. 390kwatt hours so the A/C likely uses around 780 watts. I suspect the highlander (if it uses the same system) can go for 45 minutes. Does your 06 Highlander Hybrid last longer since it has the 30 module 9.6 volts @ 6.5 Ah = 288V = 1.87kilowatt hours versus the 28 module 7.2 volt @ 6.5 Ah X 201.6Volts = 1.3 kilowatt hours?
    A little 5500 BTU wall unit that you buy at Circuit City or any other store uses between 450 to 550 watts on high (depending on manufacturer). Basically, I was just wondering if Toyota has created a super efficient A/C system.
  8. Air
    Air New Member
    I've always been interested in air conditioning systems especially for truckers, trailers and other recreational vehicles. I've experimented with various A/C units for boats, even one that converted ice to cold air (which put out about 7000 BTUs but used too much ice to be practical.) Basically, I've never found a good solution for running A/C for long periods of time in a mobile environment without the need for a generator. I was on a car forum and somehow the Prius and Yukon Hybrid (is that a bad word?) was mentioned as using an electric for a/c, so my interest was if they actually had a solution that could be used to cool truck cabins. The current solutions to cool a tractor trailer truck cabin are poor due to the number of watts needed. So that is why I asked.
    I know so little about the Prius, but the A/C seems to consume up to 780 watts. I didn't get much sleep last night, so I may have my calculations wrong.
    While I have you captive, how long does that electric heater stay on...I've read that it puts out about as much heat as a hair dryer (hair dryers use between 600 to 1500 watts). Efficient energy solutions to heat a mobile vehicle/vessel are abundant, yet air conditioning doesn't appear to have much innovation without an electric grid/generator/ICE or abundant cold water source, i.e. an ocean.
  9. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    just about any answer given will be correct. too many variables to consider
    but let me give you a scenario. its rare that i would sit in car with AC on. but there was one time i gave a friend a ride a few years back. temp was mid 80's (very hot for my area), had AC set to 70, but parked in the shade to wait. shade at an angle so it was filtered somewhat, but i say percentage in 90's.
    she had some paperwork to drop off. so i sat in car, turned AC up to 74...when not moving and in shade, a lower temp is tolerable. i sat for 30 minutes before engine kicked on. i know this because i noted that the consumption screen was blank. it might have gone longer, but i checked the battery display and it was down to one bar, so i got nervous (plus had to reposition because my shade had moved so i circled the lot once, and it idled for about another 2-3 minutes, after that, she came out and we left, but i drove another 5 minutes before battery got back to normal
  10. richard schumacher
    7,664
    1,042
    United States
    Ah! For truckers, an electric A/C system (similar to that used in the Prius) is the answer; the option of using shore power should be provided to avoid running the engine at all. Trying to run A/C for hours entirely by battery would require an unreasonably large battery.
  11. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The problem you are dealing with isn't the inefficiency of air conditioners, it's the inherent amount of power needed for cooling. Even running at the theoretical limit of efficiency, an air conditioning system for a boat or RV is going to draw a lot of power. Look at it the other way around and talk about heating. Say you want to heat your boat electrically, so you put in an electrical resistance heater (just a normal space heater). Resistance heaters are 100% efficient in turning electricity into heat. You will loose some power in the supply wires and battery, but that will also be lost as heat, so it's as good as you can get. Now ask yourself how much heat you need. On our boat we use a diesel fired heater that produces 43,000 BTU/Hr; that's 12,602 W, or roughly 12 KW. If you power that from a 12 V source, you need 1,000 Amps. To run that heater for 1 hour, assuming you are willing to completely drain your battery, you need a 1,000 Amp-hour battery. That's 5 big truck sized 12 V batteries, just for one hour! That's why our heater is diesel fired. Heating and cooling takes a lot of power.
    Tom
  12. hill
    8,580
    Hey there fellow O.C.'er !
    Let me tweek / clarify one other important thing, because it may be important. This cycle WON't continue indefinetely. Worst case scenerio, your last pip is blinking. You leave the AC on and go into the house for a qucik phone call, that ends up taking, oh, say 25 minutes, forgetting you left the car on during a 90 degree day. Car runs out of gas, AC hurries the batteries into discharge . . .
    BOOM
    now where are you? Yuck.
    hey, it's still the tail end of winter / early spring ... who's running the AC? :p
  13. Air
    Air New Member
    When you say it was at 1 bar then you had it on idle for 2-3 minutes and drove for 5 minutes and the charge went back to normal...approx how many bars was it? I'm just wondering how fast it recharges.
    30 minutes for 85 +/- outside temp in mostly shade with an inside temp set at 74 degrees from 8 bars to 1. Thanks!
  14. Air
    Air New Member
    There are excellent gasoline and diesel non-electric heating systems, so I wasn't really asking about heat (although I did read the Prius puts out a small amount of heat while turned off which is interesting...I suspect that's a safety feature for defogging the windshield combined with A/C while at stops.).
    I basically wanted to know how efficient the A/C unit was in terms of power consumption in either watts or amps. The other big problem with mobile A/C applications is for vehicles/vessels is that they are like green houses, they absorb heat from the outside very with a significant amount of stored heat in the walls of the vehicle/vessel and are poorly insulated. A high tech insulation in the walls/window tinting/covering may bring that number up to 45 minutes...but basically it's not something I'm interested in doing, I was just wanting to know how much energy the electric A/C unit uses. It's about average to above-average as far as A/C units go, but for the first vehicle with such a system...it's not bad.
    I suspect the Prius may last up to an hour (possibly longer than an hour depending on how many watts/draw it uses at low cooling requirements) without turning the engine on in the morning hours before the sun is out after the absorbed/stored heat is completely out of the vehicle. There really aren't any great solutions for A/C in mobile applications other than boats that use minimal power consumption. Thanks for all the responses.
  15. Air
    Air New Member
    Basically the systems that are used rely on either a gasoline or diesel generator and some LP, there are very pricey battery bank 12v to inverted 120v systems, most of which aren't very efficient using far more amps than what you could make yourself from a $80 5500BTU unit from you local big box store combined with either two 6volt golf cart batteries or a sealed airplane battery/inverter. Although, I'm always looking thinking Europe (where electricity is over a quarter per kilowatt and petrol is three to four times the price we pay) might have a better solution than the U.S. products.
    These are the kind of nonsense products available.
    Dometic Truck Products
    Solar panels don't provide enough electricity to charge battery banks or cool during the day...they supplement a little. There are small onan generators that will power the units during the day allowing you to use battery power at night after the stored/absorb heat has been removed by the cooling effect at night.
    But overall, when you are look at watt usage, it seems the cheap $80 small window units for homes are far more efficient than anything you can buy. Strange. I keep thinking I'll find something better but never do.
  16. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    With a Prius there is little difference in "idle" vs steady cruising recharge rates. The M/G is approx 200 VDC, not at all like a 12 vdc alternator. Stuck in traffic on a hot summer day, I've had the motor cycle to keep within 2 pink to 3 blue within a minute.
    In normal driving the Prius tries to keep the the battery indicated SOC between 3-5 blue. This is indicated, not actual, which usually translates to around 50% for maximum NiMH battery life. There is also a lot of hysteresis in the indicated battery SOC. The indicated battery SOC is for the NiMH "traction" battery, not the 12 vdc battery
    I'm guessing you're thinking of some sort of mobil heat and A/C solution, perhaps for trucking? If that is the case, companies like Teleflex and Carrier already offer a "hybrid" sort of of APU for rail, fixed mobile, and trucking
    The same principle as the APU used on jets. Rather than run the turbofans to keep the Air Cycle packs running, the APU can be started and run most aircraft systems, much more efficiently.
    Rather than idle a large motor, which is very bad for the motor and also very wasteful, you run the tiny APU. The APU has a very small diesel motor which is run near its rated power, for maximum efficiency
    In the case of rail service, the APU allows the operator to shut down the big diesel. Diesel locomotive engines are usually either plugged in to special 3 phase or single phase coolant heaters or left running 24x7 if there is no shore power. Very wasteful
    The APU is started and it keeps the starting batteries charged, and the coolant warm. In hot weather it can run an electric A/C. It can also be programmed to monitor engine temp, battery charge, etc and run according to need
    Teleflex EcoTrans
    Teleflex EcoTrans
    http://www1.eere.energy.gov/vehiclesandfuels/pdfs/success/locomotive_apu.pdf
    For the trucking industry, the APU allows the truck driver to shut down the motor and let the APU charge the batteries, heat/cool the cab, and in cold weather keep the engine warm. The truck APU can also be programmed to monitor battery charge, and engine coolant temp, and run accordingly
    http://www.trucktrailer.carrier.com/Files/TruckTrailer/Local/US-en/trucktrailer/comfortpro.pdf
    Of course, the development work that Toyota and Denso did on the hybrid system and HVAC has application in other industries.
  17. jayman
    13,439
    641
    Winnipeg Manitoba
    The Prius has supplemental PTC electric resistance heaters to aide in defrost at very low temps. A similar system is used in new Ford Super Duty trucks with the PowerStroke diesel, as diesels are coldblooded.
    IMHO the Prius could have incorporated higher output electric heaters, the ones now installed run off 12 vdc. They could have easily incorporated 200 vdc heaters
    Of course, there are probably more Prius sold in LA than all of Canada, so Toyota couldn't offer such a system to satisfy a teeny percentage of Prius drivers. The Ford SuperDuty system is optional, but a contractor I know who has it in his new Ford F-450 swears by it
    Remember the Prius A/C is very efficient, far more so than the average car A/C, as the compressor is variable speed. If you have the hood open on a hot day while the A/C is running, you can hear the compressor vary in pitch as it speeds up or slows down
    Conventional wisdom tells us it's better to put up with a hot car and A/C off to gain 1-2 MPG. With the Prius, if you run the interior hot, the battery pack will "derate" itself to protect itself, and the car will perform like a dog.
    In the Prius, the battery pack is most comfy when we are most comfy. Although bitter cold temps can also somewhat derate the pack, hot temps have a much more immediate effect. So running the Prius A/C is more efficient than keeping the interior hot
  18. Air
    Air New Member
    I've wondered what kind of impact Lithium Ion will have as it becomes more and more common in various products. I mean even power tools at Home Depot now have Lithium Ions 18volt batteries (3.0 Ah) that charge 4 times faster in only 15 minutes with 2.5 more life cycles than the previous Ni-Mah and 5x lower discharge rates. I haven't research Lithium Ion batteries to speak intelligently about them, but there has to be a better solution than the current A/C systems. But it'd take 55 of these batteries to equal one of the batteries in the Prius in terms of 1.3kilowatt hours, but I suspect the number is far lower due to the lithium ion advantage. I know there are different types of lithium ion batteries...some have far more cycles, i.e. 1000 vs. 4000, etc. I mention this because I think it is possible to have A/C in a small vehicle should the battery/charging technology improve, but I suspect it'd have to improve drastically. And I'm not talking about for the Prius, basically in applications such as trucks and recreation vehicles/vessels. Boats have the advantage of water, so the solutions exist for boats for the most part. I know the lithium batteries are lighter so more energy per kg/lb.
    Milwaukee power tools have a 28 Volt Lithium Ion battery at the 18volt weight. 2000 charge cycle. It's funny, I remember when NiCd was a big deal...and those batteries were really weak. I'm not sure how many amp/hrs the Milwaukee is...they don't say.
    It's been a couple of years since I researched air systems for vehicles/vessels. Here's a site for truckers.
    Truck Air Conditioning - Heaters - Truckinfo.net
  19. jayman
    13,439
    641
    Winnipeg Manitoba
    That is not entirely correct. On a SEER basis the little window units are among the most INefficient on the market! This depends on your cooling needs
    For example, with a house you should not have windows facing West, SW at all. When the summer sun is setting, you have enormous solar gain from those windows
    For winter, you want windows that face SE and S, to get "free" heat when its very cold. However, in summer you want a good overhang on the roof to keep direct summer sun off those windows.
    It's fairly easy to design a house to incorporate passive heating, with correct design of the roof overhang to minimise summer solar gain.
    Combine with good attic insulation, and proper attic ventilation, and good home design overall, the cooling need is greatly minimised.
    To cool an entire house, central air is usually more efficient - and cheaper - than running a window A/C. There are modern variable speed air handlers and multi speed A/C condensers that can achieve SEER of +18. I have the Bryant Evolution and am very impressed with the performance and operating cost
    The Evolution Heating and Cooling System - Bryant
    The exception if you only need cooling in just 1-2 rooms. It also depends on where the air supply/return is located
    Air supply and return in the floor is traditional for a cooler climate, otherwise the floor is freezing cold in winter. However, this allows air stratification in summer, since the warm air will collect at the ceiling. Ceiling fans help
    For partial cooling a home, a ductless system is actually the most efficient. The evaporators are located near the ceiling, and the system only runs when need be
    Mitsubishi Electric - HVAC Advanced Products Division
    If you're thinking of an off-grid solution, then you might as well give up on any sort of A/C. Cooling is very expensive no matter which way you look at it.
  20. Air
    Air New Member
    Do you know how many amps they use at 12volts? The Ford SuperDuty also has a 200amp or dual 320amp alternator system, which certainly would help recharging batteries. The Prius certainly charges the batteries quickly. I suppose it's high voltage charging which would be far more efficient than a traditional alternator could ever achieve.
