Oil Change Interval
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by john1701a, Sep 6, 2006.
  1. john1701a
    john1701a Prius Guru
    12,793
    5,275
    57
    When changing oil in on my Classic Prius, I was always impressed by how good condition it was still after 7,500 miles. My pre-hybrid car certainly wasn't that easy on oil; in fact, it looked & felt terrible after just 3,000 miles. So, I wasn't exactly receptive to the idea of a 5,000 mile change interval for my HSD Prius.
    But now that I'm at 60,000 miles and currently have no garage (the foundation is being rebuilt), the consideration of waiting longer is now foremost in my mind... especially since I've been religiously using synthetic.
    What are other owners thoughts on this? How often are they choosing to do changes and when are they breaking from the standard routine?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    We just had a thread discussing this ( http://priuschat.com/index.php?showtopic=2...p;hl=oil+change ).
    Like you, I think that at the 60k mile mark--out of the standard drive train warranty, I'm going to give serious consideration to extending the intervals to at least 7500 miles if not 10k. It certainly seems that there is not that much wear on the oil to start with, then with the ICE running only ~50% of the time that we're driving anyway that such an extended duration is likely to be OK.
    I do think I'll send in the oil for analysis after the first extended change just to be sure that my speculation is confirmed with something more objective.
    I've also thought about moving to one of the extended life Mobil synthetic oils...but I'm not sure that that is even necessary. I'm just hitting 50k myself, so I don't need to worry about it much until next Spring. If someone else decides to do this and get an oil analysis showing it's OK to go 10k, then I probably won't even bother with my own analysis.
  3. tochatihu
    tochatihu Senior Member
    9,457
    3,656
    Kunming Yunnan China
    2001 Prius
    Hi John, synthetic oil has always tested well in Prius for up to 10k miles, by which time its total base number is starting to get low. We have seen *very* little evidence of wear metals accumulating in the oil. I used to change my oil filter at the 'midpoint' but am now letting one filter go the whole way.
    I am also a fan of engine oil analyses, which are really the only way of knowing what is in there. It could be argued that those are particularly important for extended oil intervals, but in fact everybody would be better off knowing what's going on inside. At the same time, in Prius, oil analyses usually are very boring. Whether the engine is simply very accurately machined, or if the 'hybrid lifestyle' really reduces wear during startups, 'lugging', and fuel enrichment during 'high load operation', we really don't know.
    For extended oil change intervals, the possibility of accumulating ingesting dirt in the engine (which can cause abrasive wear) is obviously increased, so it becomes even more important to confirm that the engine air filter is maintained in good condition.
    There are other threads here about 'bypass oil filters' which if I understand them correctly, may allow the Prius to go even longer on one batch of oil. Essentially out to the oil's true lifespan, whatever that might be. That modification will be of interest to some Prius drivers.
  4. john1701a
    12,793
    5,275
    57
    I've been well aware of the growing interest in this topic. The hybrid system is obviously far less demanding on the engine than a traditional vehicle. So there is definitely potential to forge our own routine. Those other message threads discuss WHY.
    On this thread, I specifically would like to know HOW OFTEN.
  5. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(john1701a @ Sep 6 2006, 02:45 PM) [snapback]315427[/snapback]</div>
    Currently I'm going with 5,000 on synthetic.
  6. Frank Hudon
    Frank Hudon Senior Member
    4,147
    for those of you in cold climates in the winter time I think if your an average driver who does 2 15 mile trips per day, to work and back, and the OAT is at or about freezing I think a change in the late fall and again in late spring is probably all that's really needed. 10,000 on a synthetic is probably about as far as I would want to go but a UOA will tell for sure. I just did a holiday trip and in 3000km the ICE only operated 68% of the time, and this was gone over in the thread that I started on it. As far as I'm concerened that works out to 2000 and change Kms I just looked at the oil and it's clean as when I put it in 4 day's before the trip. I'll change it again in the spring unless some extenuating circumstances occure in the meantime.
  7. Sho-Bud
    Sho-Bud Member
    190
    Amsterdam, Netherlands
    In The Netherlands, Toyota recommends oil change every 15,000 km.
  8. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(john1701a @ Sep 6 2006, 04:45 PM) [snapback]315427[/snapback]</div>
    You can only get a legitimate answer to your question by doing a Used Oil Analysis, like I have. Overall, with Mobil 1 and the Toyota filter, putting almost 7,000 miles on Mobil 1 0W-20 over winter short trips, was nothing. Clearly, at least with Mobil 1, the oil is good for much more.
    I would suggest the EU oil change interval of 12 months or 15,000-16,000km should work ok if you use Mobil 1.
    Once you have over 6,000 miles on the oil, a sample every 1,500-2,000 miles would be helpful to establish baselines. The sample is usually less than 80ml, so you're not removing a huge amount of oil. What you want to track are wear metals, TBN, insolubles, etc.
    <div class='quotetop'>QUOTE(Sho-Bud @ Sep 9 2006, 01:02 PM) [snapback]317017[/snapback]</div>
    Believe it or not, here in North America, especially the U.S., there are many folks who believe if they run over 5,000km on the oil, the car will self-destruct
  9. puppetmasta
    puppetmasta New Member
    I would be very interested in some of the oil wear results.
    I definitely agree that the Prius should be able to handle longer wear than most cars especially when you feed it mobil 1 syn :)
    John, btw, just used your oil change guide for my first oil change on my '06, thanks alot for putting that together. Was a piece of cake with your guide :)
  10. MechaJohn
    MechaJohn New Member
    51
    Houston, Tx
    Where does one go to get used oil analyzed?
  11. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    <div class='quotetop'>QUOTE(MechaJohn @ Sep 15 2006, 12:16 PM) [snapback]320125[/snapback]</div>
    http://www.blackstone-labs.com/ is one of the sources.
    I was talking to my co-worker today about the car. He recently purchased an Acura TL. He told me that his oil change interval is 7500 miles with synthetic blend oil. I can't imagine that our car needs to change oil shorter than his car since our ICE is not running all the time. I will definitely change to 10k intervals after the warranty is up. And will do a used oil analysis just to be sure.
  12. john1701a
    12,793
    5,275
    57
    <div class='quotetop'>QUOTE(ScottY @ Sep 15 2006, 09:03 PM) [snapback]320340[/snapback]</div>
    It's not just the much fewer number of piston pumps either.
    The lower RPM and frequent off keeps the engine cooler. Heat is an aging factor for oil. Less of it should mean the oil lasts longer.
  13. Ray Moore
    Ray Moore Active Member
    857
    52
    Texas Hill Country
    I did a used oil analysis on my last oil change. The info was 5w30 for 10,300 miles. mostly hot summer conditions and about 2000 miles per month. I used ANA laboratories for the analysis. Cost was 25$. The results were:
    Severity code 1 (lowest rating) meaning that I could have continued to use the oil. (note said "overall satisfactory conditions")
    Wear metals in ppm by weight showed:
    Titanium <1
    silver<1
    copper 2
    lead 1 tin <1
    aluminum 5
    nickel 1
    iron 28
    chromium <1
    Cd <1
    sodium 9
    boron 108
    silicon 23
    water <.05
    %soot <0.2
    glycol N
    fuel <0.5
    VIS. @ 100 C. Cst 10.18
    additives:
    molybdenum 144
    magnesium 31
    calcium 1960
    barium <1
    phosphorus 496
    zinc 919
    I have decided that 10,000 miles is totally acceptable for our two Prius. We use 3 quarts only per oil change and experienced no detectable reduction in oil level after 10,000 miles. I've been anxious to share this info with all of you.
  14. efusco
    19,891
    1,194
    Nixa, MO
  15. Ray Moore
    857
    52
    Texas Hill Country
    <div class='quotetop'>QUOTE(efusco @ Oct 7 2006, 08:31 PM) [snapback]329640[/snapback]</div>
    You might as well skip the 60k oil change as your drivetrain warranty will have expired anyway.
  16. silentak1
    silentak1 Since 2005
    893
    28
    LA
    I change mine every 12,000 (lots of city driving) to 15,000 miles (if heavy on highway; road trips).
    I do use Redline or Royal Purple full synthethic 5w30 with Mobil1 or K&N filters so the oil does hold up quite well. Even at 15,000 miles the oil does not look as dark as you would imagine. Now i do agree that the interval might vary depending on your driving habits, conditions, and what not but 5,000 is a joke!
    Most people on the forums will probably recommend you something along 7,500 - 10,000 miles which I find perfectly reasonable if you are using full synthetic oils. 7,500 miles for regular or synthetic blend (<--waste of money).
  17. theorist
    theorist Member
    365
    Lexington, MA
    <div class='quotetop'>QUOTE(john1701a @ Sep 15 2006, 11:15 PM) [snapback]320390[/snapback]</div>
    Excellent point. This is one key advantage of synthetic and heavier weight oils in particular that's less valuable here.
    On the other hand some heat is vital to burn off corrosive, acidic combustion byproducts that end up in the oil. In a car that is rarely driven long enough to fully warm up the oil, more frequent oil changes and/or oil with a higher TBN (total base number) can be important to protect the engine from internal corrosion. Again, this is really only a concern for cars in cold climates that are primarily drawn short distances. Of course, there are reports of Priuses taking as much as 10 miles to fully warm up in very cold climates.
  18. tochatihu
    9,457
    3,656
    2001 Prius
    Thanks for posting the UOA Ray, sorry to not have noticed it earlier. Please also say what the ending odometer was on this oil and the brand/type that you are using. There have been a few other recent UOA's posted and it is probably time to put them all together.
  19. Chuck.
    2,766
    1,510
    Lewisville, TX (Dallas area)
    A book in the 1970's titled "Drive it Forever" when into exhausting detail of why regular oil changes is good for your engine:
    - Oil viscosity deteriorates. In other words, 0W-20 won't stay that way. :(
    - Acid builds up in oil and eats on the engine
    - Accumulated sludge. Oil will mix with water under the engine pressures.
    - Dirt gets in the oil, even with good filters.
  20. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(john1701a @ Sep 6 2006, 08:49 AM) [snapback]315186[/snapback]</div>
    This is a very late reply to an ongoing discussion, but I'm putting it in today as I just asked the service department if letting the oil change interval go over 5000 miles would affect my warranty. I was told that even letting it go up to 6000 miles wouldn't affect the warranty, but not to push it much beyond that. I'd been going to great effort to be certain the interval was always less than 5000 miles, but won't worry about the slight overage anymore. I'm coming up on my 35K miles oil change, but only have 34100 miles on it now. This is with normal oil and not synthetic.
    In spite of this, every time I get an oil change they put on a sticker showing the next oil change in 3 months or 3000 miles.
    I'm reasonably certain that (even if the warranty would lose its effectiveness), going 7500 miles wouldn't be harming the engine under normal clean driving conditions. I'm not talking about a lot of dusty or gravel roads though. Probably a lot longer interval with synthetic. When I get up to 60k miles, I'll probably start doing my own oil changes and use synthetic as well.
    Dave M.
