Oil Change Intervals
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KandyRedCoi, Jun 12, 2008.
  1. KandyRedCoi
    KandyRedCoi S is for Super!
    860
    SoCal/AZ/NV
    i purchased my 08 touring brand new, and after a bit over 2months i have managed to rack up 9600+ miles on it already
    my concern is how come my "maint reqd" light turns on quite early, my 5000 mile oil change actually happened at around 4500miles???
    my 10,000mile oil change happened at around 9500miles???
    plus i have not seen much improvements as far as mpg's are concerned
    before 1st oil change around 42mpg
    after first oil change 42.+mpg mobil1 5w30
    after 2nd oil change 41+mpg mobil1 0w30
    currently the tires are set at 42psi all around
    and auto a/c temp set at 73degrees
    car is driven 90+% on the freeways at about 70-75mph
    and i avg 100miles/day worth of driving
    im new to the prius and dont really now why its is acting this way...any info or help would be greatly appreciated
    thank you
  2. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    The light comes on at startup at 4500 miles after the last reset as an early warning system of sorts for your maintenance interval. It stays on at 5000 miles.
    Many things, especially weather, can affect fuel economy even with a consistent route and speed. For example, even minor differences in wind speed and direction can have a significant effect. Your changes are too small to draw any conclusions about, and I wouldn't worry about it.
    Synthetic or lower viscosity oil are reported to offer minor fuel economy advantages (and I use Mobil 1), but the only way to demonstrate them conclusively would be through a controlled test with identical driving conditions, something the average Prius driver would find impractical, if not impossible.
  3. KandyRedCoi
    860
    SoCal/AZ/NV
    thanx for the info
    one of my concerns were the car is only getting 42mpg's after all that said and done, i was just hoping id get closer to 45mpg's
  4. Patrick Wong
    18,200
    6,490
    Considering that most of your driving is at 70 - 75 mph, I would say that you are doing quite well to obtain mpg in the low-40s. If you really want to improve your mpg you would have to reduce your speed, but since you commute 100 miles a day I am sure that you are not interested in further lengthening your commute time.
  5. KandyRedCoi
    860
    SoCal/AZ/NV
    Thanx patrick, no i dont mind slowing down, but i frequently get tail gated and/or cut off abruptly on purpose by other vehicles, u know how road rage drivers are in LA
    also since im on my own schedule i try to drive the freeways when they are not so crowded hence my faster driving habits...
    when i slowed down from 75-70mph...it seemed as if my MPG got worse, or at no improvement at all, lowering my avg speed to 65hwy will be quite a feat, if i ever get down to trying it...ill try to post MPG's
    thanx again for all your inputs, anymore you all would love to share would be greatly appreciated :thumb:
  6. AMG
    AMG New Member
    29
    LA, CA
    try not to exceed 65, I have a 08 touring #6 and I have been getting 50mpg consistently with traffic,
    w/o traffic I can get up to 52-53 +
  7. KandyRedCoi
    860
    SoCal/AZ/NV
    i will try that next time i do a 30+mile trip somewhere on the fwy
  8. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    Yeah. The change from 70 to 60 is quite remarkable. You get some improvement from 60 to 50, but it's probably not worth the headache of tailgating drivers (and is probably unsafe, anyway). However, if you can stay in the 60-65 MPH range and be gentle on the gas and brake, you should be able to get 50 MPG at the very least.
  9. KandyRedCoi
    860
    SoCal/AZ/NV
    sweet i will try to set the CC @ 65mph, and report back asap
    thanx
  10. hiremichaelreid
    hiremichaelreid New Member
    451
    Ottawa/Aylmer, Canada
    I
    The HSD gets more inefficient over 65 MPH, so yeah, my experience is that 60-65 is best and 50 doesn't save much for the hours of you life you lose driving (Unless it's really scenic or you enjoy the relaxed pace.)
  11. KandyRedCoi
    860
    SoCal/AZ/NV
    good to know thanx
    does it also matter that i put 91octane (highest in CA) 100% of the time, and most of that is from shell...if not possible i use chevron, unocal or mobil
    i dont use cheap gas
    or would it be better MPG if i ran 87octane(lowest in CA) or 89octane(middle grade)???
  12. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    You're wasting your money on premium fuel - here's why:
    The octane rating is a measure of how hard it is to ignite the fuel, not a measure of its "quality" or how much energy it contains. High compression engines require high octane fuel because they compress the air-fuel mix to a higher pressure and thus higher temperature. You don't want the mix igniting spontaneously (that is what causes a knock or a ping).
    The Prius engine is designed for regular fuel, so it never compresses the mix that much.
    I would start buying regular fuel, and pocketing the difference. -
    PS - FWIW, I regularly get ~65 MPG on my commute using whatever regular gas I can find.
  13. Patrick Wong
    18,200
    6,490
    OK, it is good that you are buying fuel from mostly top tier vendors. However it is not good that you are using 91 octane. See the bottom of page 4-17 from the Hybrid 04 Engine file that can be found at:
    Automotive Training and Resource Site
    That page specifically warns against using octane greater than 87 as this may cause starting problems, while there is no mpg benefit.
  14. richard schumacher
    7,664
    1,042
    United States
    As Patrick mentions, with 91 octane your engine may be gagging a little every time it starts and thus reducing MPGs. Use 87 octane only, and slow down a little.
  15. AMG
    AMG New Member
    29
    LA, CA
    I use Shell 87 only here is LA
  16. Betelgeuse
    1,460
    24
    New York, NY, USA
    As people have said, you are literally throwing your money away if you get 91 octane. Throwing it away. There is absolutely no benefit to running higher octane gas in a Prius. You should run 87 and, if you can find it, 85 is fine, too.
    The importance of using "Top Tier" gasoline is debated, but probably has some benefit.
  17. KandyRedCoi
    860
    SoCal/AZ/NV
    great to know...i will try 87octane this weekend and report back asap
    thanx everyone, you all have been great help =]
  18. hiremichaelreid
    451
    I
    There was at least one report that using premium lowers MPG, and that using 85 octane gave better MPG than 87.
  19. PRIUS007
    PRIUS007 James Bond -007
    133
    Mundelein, Illinois
    Thanks for the post on this. I just went over the 4500 mile mark and noticed the "Maint Reqd" light as well. Thought it may have something to do with the oil. I was planning on changing it at 5000 miles with Mobil 1 5W30.
    I noticed that your using 0W30 as well. Any difference?
  20. KandyRedCoi
    860
    SoCal/AZ/NV
    not that i haved noticed so far, but will probably put 120miles on my car today and will report back tonight
    your welcome :)
