Oil filter position on 2010
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lm2, May 13, 2009.
  1. lm2
    lm2 New Member
    Los Angeles
    I'm wondering if Toyota was kind enough to design the oil filter on the 2010 Prius in a vertical position so that it can be removed without making a big mess. I understand that the element is replaced inside the filter housing. If anybody has the answer I would appreciate knowing; I do my own oil.
  2. bwilson4web
    15,933
    It is horizontal between and below the drive shaft and to the rear of the engine. We'll have to take a panel off to reach it. It promises to be a bit of a job. We will have to be careful with the fasteners that hold the underbody panel on.
    4 people like this.
  3. Rest
    Rest Active Member
    1,210
    CA
    Are you kidding me!!!!!? I am so sick of auto manufactures making it hard for consumers to do their own freaking oil changes. Pretty soon the only service a consumer will be able to do is put air in the tires.
    Horizontal oil filter placement is messy and doesn't allow for filling of the filter upon doing an oil change so you don't get a dry start up. Not to mention, a horizontal placement usually makes it harder to remove the filter.
  4. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    Amen!
    To give benefit of the doubt to Toyota - the 1.8 is a "standard 4cyl block used in multiple platforms right? Perhaps in other applications it's in a more accessible area (away from hybrid or other Prius-specific mechanics).
    I'd hate to think that mechanical engineers at major auto manufacturers conspire to design difficulty into DIY stuff as this.
    But, if history serves, every Toyota I've owned incl my current Lexus RX...the filter could hardly be in a worse location.
    And Rick, you had mentioned that an underbody panel needs to be removed for oil change. Is there one just under the engine compartment? How many are there under the '10? And finally, can generic oil-change places be trusted with the Prius, esp with the specific syn required now? Planning ahead...
  5. john1701a
    john1701a Prius Guru
    12,793
    5,275
    57
    There's nothing to fill anymore.
    No filter casing. It's just an insert.
    Of course, dry start up was always a non-issue with Prius anyway. MG1 (the smaller electric motor) spins the engine up to idle speed and keeps it there until oil pressure is established... waiting for that before a spark is introduced.
  6. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Slight devil's advocate - but spark or not, there's still friction w/o oil pressure and it's only a matter of time before that thin film of 0W-20 becomes inadequate. Only thing spark adds is combustion and it's associated stress and pressures on cylinder walls, connecting rods and bearings. In the 2010, there's also hyraulic valve lash adjusters to fill. Let's hope that dry spell is short ;)
    To add to the "making it harder", Toyota recommends a special tool to remove the filter cap. Also, in addition to the "disposable" (which to me means reuse a few times) oil plug gasket, there is now a "disposable" rubber o-ring around the oil filter cap.
    As for # of panels, the service manual recommends removing a front spoiler or cover and the #1 engine cover (2 parts). Ideally, most of us will see if we can get away with less, but until we have cars in hand, the repair guidelines are all we have.
    The Owner's Manual does not outline the oil change procedure, only the capacity and required oil type (0W-20 synth, or 5W-20 dino or synth in a pinch).
  7. john1701a
    12,793
    5,275
    57
    Is it anything new or just the need for a standard wrench adapter?
    That's what I use anyway, since other options tried over the years (like the belt) never really worked that well.
  8. HTMLSpinnr
    5,341
    920
    251
    There is a hex head on top of the cap that, with the proper socket, could be wrenched on. There's a risk of stripping though w/o a proper cap wrench.
  9. Patrick Wong
    18,200
    6,490
    My Highlander Hybrid 3.3L V6 engine also has a horizontally-mounted filter (although not a cartridge.) Actually, the oil filter removal can be very neat and tidy if you change the engine oil first thing in the morning before the engine has been started. All of the oil drains out of the filter into the crankcase overnight. So, when you remove the filter nothing drips out. Perhaps the 2010 Prius engine will behave similarly.
    I would disagree with this because of the funny noise that the Prius engine makes for a couple of seconds upon first startup after an oil change, if you do not pour some oil into the filter first. The noise is caused by lack of lubrication, whether or not the engine is producing power.
  10. john1701a
    12,793
    5,275
    57
    That's entirely possible. I've never tried it. But at least there isn't a jolt as harsh as a traditional vehicle.
    When/How does the oil start pumping on the 2010?
  11. Rest
    Rest Active Member
    1,210
    CA
    Are saying they don't use a regular oil filter? Maybe I am not understanding. Are there any pictures?
  12. HTMLSpinnr
    5,341
    920
    251
    2010 Prius uses a cartridge insert for the oil filter. The casing is built into the block w/ a removable cap for replacing the insert.
  13. Rest
    Rest Active Member
    1,210
    CA
    Okay and why couldn't they have done this vertically instead of horizontally?
  14. bwilson4web
    15,933
    Of course and to keep things neat and clean, the cap would have been on the top. <grins>
    No doubt someone is already thinking about an 'adapter' that fits into the recess and provides hoses to a 'standard' spin-on oil filter fitting. As for where the spin-on adapter might be located, that is a separate issue. However, I suspect some place where a round, access hole could be cut in the panels probably makes sense.
  15. Rest
    Rest Active Member
    1,210
    CA
    I still think they could have made it vertical with the cap facing down.
  16. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    seems like it will be easier to just take to dealer or other place for oil change.
    I just changed mine last week out in the garage, sometimes I take it to dealer though.
    it's quite painless with GenII to change the oil, the filter postion is perfect for the oil to drain.
    I imagine it will be a while before aftermarket filters will be made for the new prius. I have never seen a cartridge based filter at Autozone.
    I use the Denso filters from the Dealership, only 4.50
  17. Rest
    Rest Active Member
    1,210
    CA
    This is exactly what they want from consumers!
  18. Barky43
    Barky43 New Member
    Georgia
    Just found someone that details 2010 filter & oil change with photos. Other good stuff too.:) john1701a :) It's a dot com address, no w's
  19. Greysquirrel34
    Greysquirrel34 New Member
    57
    Hendersonville NC USA
    My wife had a 97 Rav4 and the oil filter is at the top of the engine and vertical so Toyota does know how to do this, I have a MB ML and as all MB cars the filter is vertical and on top, it is a cartridge same as the Prius. Both are an easy oil change as I us a vacumn oil extractor that is large enough to hold the 12 quarts of oil from the cars as well as 1 from my lawnmower and 1 from my generator.So not being an engineer I don't see why all cars could not have the filter accessible from the top of the engine. Unless of course they want owners to come into their dealerships and spend too much money on an oil change. You can buy a five quart container of Mobile 1 for $22 and a filter for probably 15 bucks or less, a wrench for the oil filter is not too expensive, unless you buy one from Toyota which has a fitting on top for a socket and other ones you can buy only have a square hole that your socket wrench will fit in.
  20. Hookitlow
    Hookitlow Junior Member
    17
    Highland NY
    I just did the oil change on my 2010 and it was pretty easy and clean. 3 clips to pop out to get the access door to fold out of the way, $4 for the oil filter wrench and one wipe and it was all clean. Even though it is horizontal, it is not messy.
