Oil Filter Questions
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Red Stick, Jul 15, 2009.
  1. Red Stick
    Red Stick New Member
    Baton Rouge
    It seems to be the consensus that we use genuine Toyota oil filters. Any ideas on where to buy them by the case? I paid $6.00 with tax at the dealership today.
    Does everyone here change the oil about every 5K?
    Thanks
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    The forum search feature is a bit wonky at the moment. There are online sources to buy a case of yoda filters, usually works out to under $4.50 a filter that way
    I went 16,000 km - the normal EU oil change interval for a Prius - running the yoda filter and Mobil 1 0W-20. Oil analysis came back fine. Be forewarned that if something should go wrong if you extend intervals, you could enter into a real pissing match with Toyota
  3. topkick
    topkick Member
    166
    Oklahoma City
    You might try metrotpn.com they sell a lot of Toyota parts. I have also found filters and parts at Toyota of Dallas.
  4. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,802
    1,170
    Auburdale FL
    I will check the next time I go to the dealer. $6 is not bad. Ask for a case price as I will. You can get a free Mobil 1 filter at AUTO Zone and Discount with the purchase of an oil change.
  5. Patrick Wong
    18,200
    6,490
  6. ETP
    2,802
    1,170
    Auburdale FL
    2009 same as 2008?
  7. ETP
    2,802
    1,170
    Auburdale FL
    $10 shipping!
  8. jayman
    13,439
    641
    Winnipeg Manitoba
    Should be
  9. jbumps wvu mntrs
    jbumps wvu mntrs PC Superfan
    51
    Morgantown, West Virginia
    I'm using a much larger capacity filter and don't know that I even pay $6 per - name brand too in PureOne.
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    The PureOne is supposed to have a good reputation. I'm sure you're aware that the 2010 requires a cartridge oil filter
  11. SageBrush
    SageBrush Senior Member
    11,627
    2,532
    Southwest Colorado
    It's hard to not get reamed for the gasket. Dealers and stores charge about $1/ring. Mostly out of annoyance, I bought 8 Wix 51394 and 25 gaskets for $56 from rockauto.com. Once I finish the filters I'll go back to purolator or Wix filters that cost about $4 a piece.
    Are you familiar with fatwallet.com/c/12 ?
    I have an automatic notice setup for oil, and usually manage to stockpile enough for around two changes in the future at about $3/qt of a good synthetic.
    There. That should save you a good $20/year, easy. :)
    I want to take this opportunity to thank my local quickLube place for taking my old oil without charge.
    Regarding change intervals: I use spring and fall. Works out to be 7000 - 9000 miles between changes. I also change the transmission fluid about every 50k miles, and the inverter fluid per yoda recc. If I ever hear my inverter pump making noises, it will be exchanged without delay. I could very well be wrong, but if there is any part in the Prius I feel like babying, it is the inverter.
  12. Patrick Wong
    18,200
    6,490
    Yes.
    That is their minimum shipping charge. If you are going to buy just a small qty of parts then you may be better off buying retail.
    If you buy parts in bulk i.e., buy a few cabin and engine air filters as well as the box of 10 engine oil filters, etc. then the shipping charge decreases as a % of the parts price and the net price reflects a big savings.
  13. Old Bald Guy
    Old Bald Guy Old Bald Guy
    89
    Ft. Worth, TX
  14. ETP
    2,802
    1,170
    Auburdale FL
    Ok, I read all of that. Who makes Toyota and MOPAR filters?
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    The Toyota filters used in North America are made by Denso in Thailand. I have no idea who makes Mopar filters
  16. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    ...or use Mobil 1 filter...or use Amsoil amd and Amsoil filter.
  17. jayman
    13,439
    641
    Winnipeg Manitoba
    That works too
  18. ETP
    2,802
    1,170
    Auburdale FL
    So what do you guys suggest? A case for $42 shipped or is there just as good a filter locally for less bucks?
  19. jayman
    13,439
    641
    Winnipeg Manitoba
    Well, how many miles are you putting on? If you're just changing the oil twice a year, I see no sense to get a case of filters. Just get them locally, even at the dealership
    However, if you're really racking up the miles, getting a case of filters would make sense. So would going the Amsoil route
  20. blfuller
    blfuller Junior Member
    25
    Eastern Washington State
    NAPA gold filters are good filters and are available locally, assuming you have a NAPA store in your area. Federated Auto Supplies carries Wix filters. These filters have had good reviews.
