oil filter wrench
Discussion in 'Prius v Technical Discussion' started by easternshore, Nov 16, 2012.
  1. easternshore
    easternshore Junior Member
    Maryland
    In order to change the oil filter element in the 2012 Prius v (lowercase v for the Prius v), folks have told me that I need a 64mm wrench (TOY 640), or a 74 mm wrench (TOY 740), or just a regular socket wrench (maybe 14 mm) to remove the filter casing. So does anyone know which it is?
    I could answer this by diving under the car, removing the snaps for the flap, and just taking a look - but I would prefer to go ahead and buy a decent wrench if that is what is needed. Any help here? And, what does this apply to a 2010 prius
    thanks
  2. Mike500
    Mike500 Senior Member
    2,593
    766
  3. Guill
    Guill Member
    165
    23
    Italy
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    The answer to your questions is that the filter wrench is a 64 mm. The oil pan drain plug is a 14 mm.
  5. CAlbertson
    CAlbertson Member
    99
    24
    Sometimes if you can get a good grip the filter will come off by hands alone, no tools. But that is slightly rare.
    I think a normal "strap wrench" would work fine. You only need to turn a filter about 1/8th turn then it does come off by hand. When I was in high school I used to use a screw driver to remove oil filters. It's really messy but when you work for $2.25 per hour (minimum wage at the time) a $5 strap wrench was to much money. I'd simply hammer the screwdriver into the filter then use it like a lever. Yes, it destroys the filter but it's not like you are going to re-use it. Finally I bought the strap wrench in the 1980's and five cars later, still have it. Here is what you need:
    Oil Filter Wrench L53900
    It would not pay Toyota's asking price for the filter wrench. Here is one for under $4.
    End Cap Filter Wrench for Toyota L54930
  6. n0na
    n0na Junior Member
    88
    WA
    A strap wrench may damage the filter housing. (I know, I've done it to regular filters.) Then you have to make a trip to the dealer and hope they have a replacement housing in stock. I'd recommend using the proper tools. (But the screwdirver method does work when you crush the filter with a strap wrench.)
    There are two general types of filter wrenches (end fitting type) you can use. Those made from metal and those made from plastic or fiberglass. I've cracked a fair number of the fiberglass ones. The metal ones are much better and in the long run are probably worth the higher price.
