Oil overfilled by the dealer
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by web1b, Nov 4, 2010.
  1. web1b
    web1b Active Member
    817
    52
    I have been at home for about an hour after getting the 10K service done and decided to check the level.
    It is about an inch over the top mark.
    Do they need to drain it out?
  2. PriusCrazy
    PriusCrazy Blizzard Pearl for Me
    213
    28
    Triad, NC
    It looks like there's an awful lot of oil above the 2nd mark. Are you sure you wiped the stick good then checked your oil?
    If you're still getting an inch above the top mark, I would definitely take it back and have them drain (completely) and refill. My mechanic friend explained to me that too much oil is not good for the engine and can impact mpg.
    Even though the manual calls for 4.4 quarts with filter, I ask for only 4.0 quarts. It works out to just a little bit below the full mark. Anything between the first and second mark is good as far as the warranty is concerned.
    Hope you get this resolved quickly.
  3. web1b
    web1b Active Member
    817
    52
    Of course, I wiped the dipstick.
    took it back and they adjusted the oil level.
    The paperwork says 5w30, but they said it was a clerical error and the really used 0w20 and he can tell by looking at and feeling the oil.
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    0w20 is correct for the car, and overfilling happens all the time. The Prius has an akwardly sized resevoir for some reason and "normal" is just too much. I doubt anyone looks at the paperwork in the back, they just hook up their funnel and away they go. Computer spits out paperwork based on what should have been done, not what was done.
    If you want to save a trip back the next time you can use some aquarium air tubing and stick it down the dipstick opening. Siphon out oil (slowly) into an awaiting bucket. In an hour or two your oil should be between the lines and you didnt have to drive back and forth... Save up enough oil and get a free oil change! :)
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Roughly a 10 degree temperature difference can make 30 weight as thin as 20 weight or v versa. He's blowing smoke and trying to cover up for a bad job.
  6. web1b
    web1b Active Member
    817
    52
    The service writer says the clerks that enter the info in the computers made the errors because the haven't gotten used to inputting 0w20 on the invoices.
  7. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Yet you believe the oil changers were used to using the right oil when they don't even get the amount close to correct?
  8. web1b
    web1b Active Member
    817
    52
    Should I be able to tell if the wrong oil is in by lower MPG? Oil analysis?
  9. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Oil analysis will tell you whether it's an xW-20 or xW-30.
    Unless you are tracking your MPG under highly controlled conditions, MPPG won't tell you.
  10. web1b
    web1b Active Member
    817
    52
    Is oil analysis of used oil so accurate in determining the difference between 30w and 20w that it can really be considered "proof" either way?
  11. bisco
    50,820
    an inch?!? how much extra oil is that? they aleays overfill mine by a quarter inch, i thought that was the difference between the spec and the correct amount.:confused:
  12. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Yes, it will tell you that actual 100C viscosity and that determines whether is is a 20 weight, 30 weight or something else.
    Oil viscosity can change after it is used a long time, but you will get a good reading if you do it within the first couple thousand miles.
  13. pulse
    pulse New Member
    23
    Vermont
    Dealer overfilled mine too - they're surprisingly accurate on the work ticket - I have had 3 oil changes there and the last two said 4 qts (first one said 5w30 because the dealership didn't have any 0w-20 yet. . This ticket was the first one that said 5 quarts. I wrote it up for the shop manager but didn't ask for an explanation. I wish I had - I just siphoned it out with a pump.
  14. web1b
    web1b Active Member
    817
    52
    Do any of the dipstick oil change pumps work on the 2010 Prius?
    I'd like to get a 3 oz sample out for oil analysis without risking inhaling oil through aquarium tubing.
  15. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    I only use 4 qts. per oil and filer change. That way I never have this problem.H
  16. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    I had a similar situation with what I thought was a dealership overfill. I measured my oil and found it to be over, but the oil was "streaking" on the dipstick. I park on an incline. The next day, I drove down the hill and parked in a flat area and saw the same thing. Had a neighbor watch me measure the oil and it was still over.
    Called the dealership and drove down (35 miles) to have them correct it. When they checked it, it was right at the mark. I had them show me, and sure enough, it was spot on the dot. They said something about having to twist the dipstick a little as you pull it out. That was a new one to me.
    I hope that this is all that is wrong with yours.
    Preeeus and LoveMyPriusIII like this.
  17. web1b
    web1b Active Member
    817
    52
    When I took mine to the dealer and the tech pulled out the dipstick, it was still over the line, but it didn't look as far over the line as it did when I checked the level at home on a flat surface and took the photos. So, maybe you do have to use a special technique to check the level.
    I still had them drain it since it was still over the max level even by their technique.
  18. PriusCrazy
    213
    28
    Triad, NC
    Glad you got it straightened out. Hope I didn't insult you by asking about wiping the dipstick. There was just so much oil above the full mark it was disconcerting. You would like to think a "trained" technician wouldn't make such a mistake.
    Quick Story: When the dealer overfilled mine last time, I took it back and asked the service assistant if I could watch. They didn't mind, and it gave me confidence that everything was right. I noticed that the technician had a handwritten "cheat sheet" at his station that had the 2010 Prius listed at 4.5 quarts. So technically, he is overfilling every 2010 he services. Just thinking about it, I think I'm going to watch all of my oil changes from now on. ;)
  19. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    145
    Fort Worth, TX
    I gave up a long time ago and started changing the oil myself. It actually only takes about 20 minutes on a Prius and can be done faster than driving the car down to an oil-change place and waiting. That way, I make sure it doesn't get overfilled. I also wrote an article on the topic:
    http://www.evtalk.org/201/overfilled-oil-in-a-toyota-prius/
  20. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    When I change the oil in our
    prius I only put in 4 quarts.
    After 10,000 miles nearly
    4 quarts comes out.
    I use Mobil One 0 x 20 full
    synthetic.
    There is no need to put in
    anything over 4 quarts.
    alfon
