Ok, so I may have buggered things up slightly - trouble code help!
Discussion in 'Gen 2 Prius Technical Discussion' started by PLB-389, Jan 12, 2011.
  1. PLB-389
    PLB-389 New Member
    Sydney, Australia
    So I've been fooling around with our school's Prius trying to map out how it splits regenerative and friction braking, and I've hooked all my equipment up to it only to turn it on and have it scream at me for touching its insides.
    The P3000 code comes up as soon as I hit the power button, and then less than a minute after that, the C1259 code (HV regenerative system malfunction) comes up, followed by the C1310/156 code (HV system malfunction). At the same time, the radiator fan turns on and stays on until I power the car off. I've checked the reported SOC of the HV battery, which starts at 10% when I turn the car on, and I can watch it drop to 8% in a matter of a couple of minutes or so.
    What says the brain trust on this? Do you guys think that C1259 and C1310 are also because the SOC is so low as to not enable to engine to turn over, or are they unrelated?
  2. Patrick Wong
    18,200
    6,490
    I suggest that you disconnect all of your monitoring equipment, then see whether the car will start. If it won't, then disconnect the 12V battery negative terminal for 5 minutes in an attempt to clear existing DTC, then reconnect the battery and try to start the car. If it won't start, retrieve the new DTC and let us know if they differ from your first list.
  3. PLB-389
    PLB-389 New Member
    Sydney, Australia
    Thanks Patrick, that was my first step. Disconnecting the monitoring equipment cleared a few other DTC's (relating to brake pressure signals I was monitoring) but the ones I mentioned above are the remaining ones. I also installed a fresh 12V battery yesterday, as at an earlier point the car wasn't even reaching the ready state (the fresh battery solved that problem, and now it's just these 3 DTC's that I need to figure out how to get rid of). These DTC's are persistent and repeatable.
  4. Patrick Wong
    18,200
    6,490
    DTC P3000 "Battery Control System Malfunction". This is logged by the hybrid vehicle ECU. Depending upon the three-digit info code, the traction battery, the traction battery ECU, the hybrid vehicle ECU or an out-of-gas situation are suspects.
    The other two DTC are logged by the skid control ECU and indicate a problem with the hybrid vehicle ECU.
    Was the car working properly prior to your efforts to add instrumentation? If so, I suggest that you check the wiring harness associated with the hybrid vehicle ECU as there may be a bad or intermittent connection somewhere.
    Also check the orange traction battery interlock switch (if you had removed it when working on the car) and make sure the lever was pivoted 90 degrees, then slid to lock into place.
  5. PLB-389
    PLB-389 New Member
    Sydney, Australia
    Update: I gave the traction battery a quick (and dirty) charge out of the car just to get its SOC up to engine starting range. After this charge I put the battery back in the car and started it - it seems there are no error codes (I didn't have time to hook the scangauge up to it to double check, but no dash lights turn on), but the engine refuses to start at all. You can hear (and feel) the computer trying to fire it, but it refuses to take hold. The car moves under electric power just fine though.
    In answer to your questions - the car was working fine prior to instrumenting, but was last started some six months ago. I didn't add anything to the hybrid vehicle ECU loom - the only loom I spliced into was the skid control ECU - and I successfully road-tested the vehicle after splicing into this loom. Interlock is always engaged.
  6. GigaTigga
    GigaTigga New Member
    84
    Nebraska
    Yikes I thought this required a special charger from Toyota... anyone else scared by this statement? Lol.
    SCH-I800 ?
  7. PLB-389
    PLB-389 New Member
    Sydney, Australia
    ideally - yeah a specialised NiMH charger would be the way to go. The Toyota charger is special because it has preloaded charging profiles for the NiMH cells, and plugs into the battery computer to monitor temperature change over time and voltage change over time.
    If you've got nothing to lose, connecting the battery to a garden variety high voltage power supply is an effective way to resurrect a dead traction battery. You have to monitor dV/dt and dT/dt manually, and adjust charging current to suit, and if you don't know what you're doing (and even if you do) there's every chance you'll blow up your battery. But if you're otherwise staring at a $2000 paperweight anyway, there's not a lot of reasons why you shouldn't.
    For reference, I used a charging currents varying between 0.9A and 1.5A for a total of 3.5hrs charging time, and had a blower fan situated next to the battery at all times. I relied on dV/dt to adjust charge current as casing temp changes were negligible. Battery voltage started at 197V, peaked at 214V, and the charging process was turned off when dV/dT went negative (final reading 212V). In total, I added about 0.85kWh minus battery losses (which I guesstimated were around 20%).
    Anyway...I still have no idea why the engine isn't starting...though it might be because I need to take the fuel rail off and give the injectors a good cleanout. It has fresh fuel, but I'm not sure if thats getting to the fuel rail, because it's a returnless system.
  8. pEEf
    pEEf Engineer - EV nut
    720
    579
    Berkeley, CA
    Seems like if the engine failed to fire, you'd definitely have some codes! Do you have a mongoose or tactrix interface and techstream? If not, I highly recommend it, as your research would be well-served just by the data provided by it alone.
    The best (and sometimes only) way to troubleshoot the Prius is by having the full DTC info available. A generic OBD2 reader will not be able to get all the codes, only the generic ones.
  9. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Maybe a bit OT but I'm interested the voltage requirements for charging the traction battery and was surprised by the low peak voltage (214) reported here. That's only about 1.27 volts per cell right?
    I know from charging small NiMH batteries that even at a slow charge rate the final voltage is usually 1.4 volts or more per cell. So for the Prius battery that's 168 * 1.4 so I thought it would be something more like 235 volts. ???
    Also the negative dV/dt thing. I thought that only happened right at the very end of charging, almost really when you're starting to overcharge a bit. So I didn't think the Prius battery would normally be charged to the point where you get negative dV/dt and even if you did I would have expect it to happen a significantly higher voltage than 1.27 volts per cell.
    Can anyone help me understand this.
  10. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,515
    38
    Santa Fe, NM
    Something is not right. dV/dt would happen in the neighborhood of 9V per module at a low charging rate -- 252V. With cells near complete discharge, and charging at less than 1C rate, it is common to see false dV/dt signals. And then after pumping in around 3-4 amp hours, the terminal voltage at the end of charging was only 214V? How much did the voltage drop several hours after the charger was disconnected? I think you need to get the terminal voltage up to 230V in order to eliminate the traction battery as a source of trouble. The numbers that were posted are inconsistent with my experience.
    You should get some kind of no start check engine light. Also, do the usual no start checklist, like having too much or too heavy oil installed, lack of fuel pressure, no spark, etc. Perhaps some wires leading to the ECU were cut in the instrumentation process as well, so check wiring harnesses for end-to-end continuity.
  11. PLB-389
    PLB-389 New Member
    Sydney, Australia
    Yeah I bought the mongoose interface and the techstream software seems to have somehow made itself available to me. The only DTC's it comes up with at the moment are an airbag one (because I have no passenger seat installed), and an air conditioning one (because a temp/light sensor (I forget which) is defective).
    I took off the fuel rail just now and evacuated all the old fuel that was in it then put it back together. No change, no engine firing, and no DTC's!! :(
    Just a thought - in the process of instrumenting the car I took apart the large orange 3-phase conductors that run from the inverter to MG1 and MG2 (to slip current transducers over each phase). Supposing when I was putting the conductors back together for MG1 (i.e. the one that isn't the traction one) I accidentally swapped around two of the phases...would that cause a non-starting engine, electric only running, but no DTC's? I have a sneaking suspicion that I might have done just that, but I'm really not keen on taking that plug apart again.
  12. PLB-389
    PLB-389 New Member
    Sydney, Australia
    Seilierts might be right. I was only using a small analogue voltmeter to measure terminal voltage and graduations are at 5V increments, so it's entirely possible that I misread a negative dV/dt when there was none. Also, it was 6:45pm on a friday night and I was itching to get the hell out of here, so I'm inclined to think I didn't charge it a helluva lot. That said, I did charge it enough to drive the car around the parking lot at up to 40km/h, so instinct tells me if it can move a car at 40km/h it can sure as hell start a weeny little 1.5 4cyl.
    Seilierts - oil is fine, ECU wires are fine (checked these). Don't have a fuel pressure gauge to check fuel pressure but the pump is easily flowing enough (did a flow check), and not sure how to check spark on these things (I'll have a look thru the manual). I might pop the traction battery on charge a little longer (it's dropped down to two bars on the MFD because of all the driving I've done engineless). But I'm inclined to think my problem is either fuel-related or possibly because I swapped a couple of wires around the MG1 power cable.
    If anyone can tell me how the wires are ordered between the inverter and transaxle I can double check this, as I can't find a line drawing or exploded diagram of it anywhere in the workshop manual.
    Thanks everyone for your very helpful discussion so far!
  13. seilerts
    3,326
    1,515
    38
    Santa Fe, NM
    You know, I don't think the car would move if it thought the HV SoC was so low that it would not be able to start the engine.
    How it is that you do NOT get DTC P3191 is beyond me. Do you get any fire at all, or just cranking for a few seconds until it quits? There is a signal sent to the ECM for it to turn on the fuel pump when the engine is being cranked by MG1. Offhand I don't know if that signal is from the crankshaft position sensor or something from MG1 directly. Perhaps these are the potentially reversed wires near MG1 that you are talking about?
    You should be able to operate the fuel pump and crank the engine using your scan tool in inspection mode. It would be a good test of Tactrix + Techstream also. Checking fuel pressure and spark are the first two steps in the troubleshooting guide. If you suspect bad gas, manually operating the fuel pump it is an easy way to empty out the tank. If you can get fuel to flow into a container, then you probably don't have a fuel pressure problem. Beyond that, you have checking the ECM for +12V, check voltage, resistance, connections for throttle body, crankshaft position, camshaft position, MAF, clogged air cleaner, etc. The final option is replacing the ECM.
  14. pEEf
    720
    579
    Berkeley, CA
    I've *never* seen a problem like a nostart fail to generate a DTC, and I've done a lot of experimentation myself.
    This is not possible, if the wires were not connected properly, the relevant motor would fail instantly, as the motor would either be rotating backwards or out of phase with the resolver which essentially functions as the commutator.
    When the car is cold and you go ready, after about 7 seconds it should try to start the engine. Does this happen? Does it crank the motor and then stop?
    If you've charged the battery (regardless of method) so you see at least a bar on the MFD, then it should be more than adequate to crank. Especially telling is the fact that it has enough power to move electrically.
    Just in case the HV ECU is confused, have you disconnected the 12v battery for a few minutes to reset everything?
  15. PLB-389
    PLB-389 New Member
    Sydney, Australia
    pEEf - The car doesn't try to crank the engine at all when cold. When I drive electrically, I get smooth acceleration going forward, with sometimes a small hesitation here and there (the same sort of hesitation you get when it fires the engine up, but alas - no engine) but interestingly in reverse the movement is extremely jerky. All this, and no fault codes.
  16. seilerts
    3,326
    1,515
    38
    Santa Fe, NM
    Are you sure that you have Techstream working on the Tactrix? Might it be acting as a generic OBD II scanner and thus missing the e.g. P3191 code? I can't speak for the reverse jerkiness, but what you are describing otherwise is what happens when the car is out of gas.
  17. PLB-389
    PLB-389 New Member
    Sydney, Australia
    Seilerts, Techstream is definitely working fully (not in generic mode), I just double checked. I've charged the traction battery again, this time terminal voltage was 237V. This didn't change the car's behaviour, but I know there's definitely no P3191 code there. I did notice though that even while the car is in park, the front of the transaxle casing, the inverter casing, and the big orange power wire that runs between the two (at the front right hand corner of the inverter) got quite warm to the touch. The battery also dropped SOC quite quickly even though no accesories were on. The plot seems to have thickened...
    PS - pEEf - I leave the 12V battery disconnected normally, and only connect it when I'm troubleshooting again.
  18. drew_flux
    drew_flux Junior Member
    73
    22
    sydney australia
    just wondering 1 what school is leting you play with this prius... tafe? 2 if you have techstream, i would go to active test a do a engine run test and see what happens. if your local i wouldnt say no to a demo of techstream.
  19. pEEf
    720
    579
    Berkeley, CA
    Can you open the "Hybrid Control" ECU and start a log file as soon as you put the car in ready? Record at least 30 seconds of the default data set then save the parameters. Techstream will create a .TSE file that can be played back. If you send me this, I'll take a look and see if I can't figure it out.
  20. PLB-389
    PLB-389 New Member
    Sydney, Australia
    Does anyone know which ECU I need to access to find the engine crank active test? I looked through all the active tests I could find in techstream and couldn't find that particular one at all. Is the test actually listed as "Engine crank"?
    Drew, I'm at UTS. Are you nearby? I'd be happy to give you a demo of techstream (though I don't think I've really played with half the stuff it does) - once I have this damn car working!
    Thanks pEEf, very much appreciated - I'll record the file and send it to you tomorrow when I'm back at work.
