Okay, maybe my car's starting to fall apart.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hobbit, Apr 3, 2010.
  1. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    While underneath for an oil change yesterday I noticed something
    back near where the engine/trans torque arm connects into the
    subframe, sticking up at a somewhat odd angle:
    http://techno-fandom.org/~hobbit/cars/tdamp-in.jpg
    I snaked my hand in there to investigate, and whatever it was
    felt loose and wobbly, but in a both "rubbery" and "crunchy"
    way at the same time. I also realized as I bent it around that
    whatever held it on was completely rusted out and already breaking
    away as I moved it, and wasn't at all securely mounted in that spot.
    I worked at it a little more and broke it completely free, removing
    the item. A surprisingly heavy little thing, half of which is a
    big rubber gasket. Upon feeling around in the void where it had
    just been, a whole lot of rust fell out the hole underneath.
    http://techno-fandom.org/~hobbit/cars/tdamp-out.jpg
    But finally I could figure out what it is -- another one of
    the funny little vibration dampers that show up in weird places
    all through the car. Just screwed in there to change resonance
    characteristics of some part or other. There are a couple on
    the other engine mounts, and I had found an odd one in the
    hatch door during earlier disassembly of that. But this is
    the first part that's simply rusted off the chassis -- now its
    inner piece that kept it threaded on had disintegrated. The car
    doesn't feel any different without this widget...
    I keep expecting half the exhaust system to fall out any day
    now, particularly the rear muffler and its brackets, but somehow
    it keeps hangin' in. On the bright side, the wheels and doors
    still seem firmly affixed, so it hasn't pulled a Bluesmobile...
    _H*
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Do you notice any change in vibration or sound when the engine runs or when moving with that thing off?
  3. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    DH says those bolts that hold those on are the some of the dinkiest bolts on the car.
  4. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    I'm reminded of this classic song by da Yoopers (sung to the tune Jingle Bells)
    "Oh, rust and smoke, da heater's broke, da door just blew away,
    I light a match to see the dash and then I start to pray-ay
    The frame is bent, the muffler went, the radio it's okay,
    Oh what fun it is to drive this rusty chevrolet"
    So you're not at the Chevrolet level yet, that's good to know.
  5. Patrick Wong
    18,200
    6,490
    Fascinating.
    Hobbit: can a replacement bolt secure that part back to the chassis; or does it screw into a threaded hole that also rusted out?
  6. hobbit
    4,089
    468
    Bahstahn
    It used to mount on a stud that sticks up at an angle from some
    completely hidden surface above where the torque arm ties into
    the crossmember. I can feel the remains of the small stud, which
    seems to be captive-staked into part of the frame from the other
    side, but the internals of the iron donut itself are completely
    gone and thus likely not even worth bothering with anymore. It
    doesn't change the feel of the car/engine at all if it's missing,
    not that I can notice, anyway.
    Next time I have the cowl out I *might* be able to see down to the
    top of the area. I went and looked to see if any of my shots from
    Steve's yard in '07 might show the area, but I couldn't find anything.
    _H*
  7. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    If you live in an area where salt is used to deice roads in winter, that should come as no surprise. Especially after 5-6 years
    Unless you are willing to apply a rust proofing agent like Fluid Film
    Fluid Film® | Corrosion Preventative, Lubricant and Rust Inhibitor
    on a regular basis, corrosion has to be expected. A co-worker used to have a 1992 Honda Accord, purchased new. He never rust proofed it, or even hosed it off underneath.
    In 2001 he hit a pretty huge pothole on Fermor just east of the Lag intersection, past the Mint, and the right front of the car dropped around 4 inches. The subframe itself had simply rotted away, the the huge jar from the impact broke everything. The car was in decent shape otherwise, but he had to junk it
    Here is my FJ two years after spraying on the Fluid Film
    Otherwise, the FJ's around here are already rust-red underneath after two years
  8. dogfriend
    7,512
    1,188
    Carmichael, CA
    Its an environmental problem. Your environment is too nasty for steel. :madgrin:
  9. Patrick Wong
    18,200
    6,490
    Pls check the years cited above? There must be a mistake?
  10. bisco
    50,813
    maybe that's the problem i'm having with my 04 after driving the 08. my daughter doesn't notice the low rumbling noise, but to me, it sounds like a freight train.:eek: don't get in a newer prius and it won't matter?
  11. Flying White Dutchman
    4,374
    313
    damm that a lott of rust you got there
    is this not something covered under warranty?
  12. Patrick Wong
    18,200
    6,490
    My 2004 was becoming very unenjoyable to ride in. I replaced the struts / shocks and the tires (which had ~50% tread left, but apparently were out-of-round.)
    Now the car rides great again. My wife provided an unsolicited comment to that effect during her latest (500 miles one-way) trip to southern CA.
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    Sorry you are correct, he had a 1992 Honda, not a 2002
    There are many exclusions to such corrosion "warranty" programs. Some, such as those of Dodge, are only 3 years!
  14. jayman
    13,439
    641
    Winnipeg Manitoba
    Of that I have no doubt!
    Friends of mine in St George Utah have a 2003 Ford F-250 SuperDuty diesel that used to be used to pull a camper. They sold the camper several years ago, but since the truck only has 42,000 miles on it and is paid for, it just sits in their garage
    At the CTIA convention in Vegas a couple of weeks ago, I visited with them and happened to peek underneath that truck. It looks like it just rolled off the assembly line!
    Got to love semi-arid environments. Similar vintage trucks around here look like Swiss Cheese
  15. dogfriend
    7,512
    1,188
    Carmichael, CA
    Sacramento is almost an ideal climate for car longevity. I see daily drivers that are 30 and 40 years old every day. They are usually 60's and 70's pickup trucks although you also see the classic American land yachts too.
    My GF had a 93 Toyota pickup that we sold in 2007 after I bought the Prius. It had no rust at all, the undercarriage looked new including the exhaust system. Her brother who lives in Western NY had a similar pickup, although it was a 91 model. In 2003, it was sitting in a field with holes in the body large enough to put your hand through.
  16. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    yep, salt is a killer. in SE MI (which sits on top of one of the largest salt deposits in the world) it was typical to see holes rusted into cars 3 years old. (most only lasted that long if washed twice a week all winter long!!)
  17. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Nerfer,
    Well, ya know der, da finish-american Yooper sports car is dat Imp-ala , Ha! Lived in Calumet for a good part of my childhood.
  18. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Welcome to my world.
    Tom
  19. jayman
    13,439
    641
    Winnipeg Manitoba
    Ya, you betcha!
  20. dogfriend
    7,512
    1,188
    Carmichael, CA
    Do the Nordic people naturally gravitate to the rust belt? Lewis Black postulates a theory that they were migrating west, but under the influence of heavy drinking they veered to the right and only made it as far as Wisconsin. :madgrin:
