One year mileage
Discussion in 'Gen 3 Prius Fuel Economy' started by shankyyy, Dec 29, 2010.
  1. shankyyy
    shankyyy Member
    172
    Charlotte, NC
    Let me know your thoughts. The last tank was really poor (OATs 20-30F). Most driving in ECO mode. Freeway mileage 45-50. Other figures.
    Total gas cost $635.47
    Total gallons 228.649
    Total miles 10462
    Gallons/mile 0.021855
    Cost per mile $0.060741
  2. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I'd cry if I had your numbers. I'm bummed because my last two tanks (covering this month) were 50.2 & 51.2. When I burned 232.322 gallons I went 12401 miles. Grill blocked? What's your tire pressure?
  3. shankyyy
    shankyyy Member
    172
    Charlotte, NC
    Thx. No grill blocking. Tire Pressure about 40 after my first oil change in July. Park outside; so lately the chill has taken a toll on mileage. In summer, the AC takes a toll. It appears spring and fall with no heater/ac provide greater than 50 mpg. What do you do differently?
  4. Much More Better
    Much More Better Active Member
    655
    163
    I'd jump for joy if I had your last two tanks. My December should be avg 42mpg. My best summer tank was 58mpg hand calc'ed. It's tough on cars to be north of 49.
  5. JimN
    7,028
    1,116
    South Jersey
    Route management. Avoid congested or high speed roads in favor of more moderate & steady speeds. I now take a county road that runs roughly parallel to the US highway & has 2 less stops. It's zoned 35-45mph while US130 is zoned 50. Almost always I have the road to myself compared to lots of traffic.
    Block the grill. Tony started the definitive thread.
    Tire pressure is max sidewall. Improves handling, wear, & fuel economy.
    Buy a ScanGauge so you can see what's happening.
    The heated seats don't seem to affect FE. I keep the temp at 72 or 73 with the fan on the lowest settings.
    For quick stops (5-10 minutes) I park the car & leave it on. manually lock the door.
    My commute is ~35miles. Now what I lose in the AM I can pretty much get back in the PM & usually a bit more.
    My car also lives outside. Recent takes have gone from 56 (November) to 53 (early December).
  6. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    Take a look at the "sticky" thread on Full Year Fuel Economy in this thread (and post your numbers there too).
    You will see that I'm about where you are, and we are both somewhat below average in this group of Prius nuts. But we're not at the bottom.
    Plus, this is by far the best mileage I've ever gotten.
    All of the advice you've gotten is good for improving mileage. You won't be surprised to find I don't take a lot of it because I don't like going that much slower.
    (I do take some of the non-speed advice, especially about tires. And I've slowed down about 1 or 2 mph on freeways on average.)
    Overall, I'm not crying.
  7. hill
    8,562
    My hydroedges are rated for 44lbs, and I don't run 'em any lower ;)
    of course, when the Gen II is driving in Montana winters, that knocks about 30mpg off the top. All that said ... practice practice practice ... and grill block ... and EBH.
    You're off to a good start!
  8. sunvia
    sunvia Junior Member
    67
    palm springs,ca
    what is grill block????
  9. hill
    8,562
    It's a bit different on the Gen III ... but on Gen II's you simply buy a few feet of 3/4" copper water line foam insulation and stuff it in between the grill slits ... effectively stopping cold air from entering the radiator. This quickens/helps the ICE maintain temps on cold days ... even on cold palm springs winter mornings. Your very worst MPG's happen within the 1st 5-10 minutes of driving. The quicker/easier the Prius warms up (and stays warm) the better your mpg's.
