Only cell phone use while driving?
Discussion in 'Gen 3 Prius Audio and Electronics' started by shankyyy, Oct 23, 2010.
  1. shankyyy
    shankyyy Member
    172
    Charlotte, NC
    If a call comes in/goes out, is there a simple way to switch to phone only mode so that only that person can talk without the rest of the passengers having to listen to the conversation? I have a flip phone, and even with the handset open, I cannot hear any noise thru' it but onyl thru' the car audio. I know one can do it by disabling bluetooth but it is a pain everytime to go thru the set-up.
    Also, if I am using the phone before I get in the car, the call gets disconnected as soon as the engine is turned on even if I keep my handset on. Same happens when getting out of the car. Same bluetooth issue, i guess. Any way to avoid this??
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    legally?? no there is not, at least not here
    physically, simply hit the button on the display to switch to the phone.
  3. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    this only happens if your BT on the phone is powered on and it should not disconnect you. it should transfer audio to the car.
  4. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    As Dave has answered, there is a button on the nav screen when on the phone screen to transfer the call to the handset. Also, when the car is powered off even if on a call it will just send the call to the phone. I usually just do like mentioned above, send the call over before shutting the car off if I am on a call.
  5. shankyyy
    shankyyy Member
    172
    Charlotte, NC
    i'm not sure which button are you referring to..anyways, i'll check it out.
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    While the phone screen is up showing connection, volume, etc. it should be in the middle of the screen on the right. It is labeled
    TRANSFER CALL.
