Opinion on KYB struts
Discussion in 'Generation 1 Prius Discussion' started by kmc6566, Oct 18, 2010.
  1. kmc6566
    kmc6566 Junior Member
    61
    England, AR
    I need to replace the struts on my 2002. KYB Struts seem to be the cheapest. I'm always looking to save money. But are they worth it or am I better off getting Monroes? Thanks.
  2. Patrick Wong
    18,200
    6,490
    KYB is the original equipment strut/shock manufacturer. It's not clear whether their branded parts are better or worse than the original equipment parts.
    I didn't know that Monroe made suitable parts that fit Prius.
  3. freidawg
    freidawg Prius Recycler
    111
    35
    Denver, CO
    2003 Prius
    I can not claim direct experience with KYB's for the Prius. I have not been happy in the past with KYB aftermarket parts for other cars I have put them on. (I have put them on a few different ones over the years) They don't seem to last very long....
    Eric
  4. kmc6566
    61
    England, AR
  5. BigMiles
    BigMiles New Member
    I'm trying to decide between Monroe and KYB now. What did you end up buying and why? Are you happy with your choice?
  6. kmc6566
    61
    England, AR
    I went with Monroe struts because I couldn't find anyone to say anything positive about the KYB struts. And since I plan on keeping the car for a few years I wanted something that lasted. Also, I found them on Ebay for just a little bit more than the KYB struts. Made since to get them. Hope that answers the questions.
  7. dabard051
    dabard051 Tinkerer-in-Charge
    251
    93
    Rochester, NY USA
    2002 Prius
    What a coincidence, I just replaced the struts on both my 2002 Priuses (Pri-i?).
    Here are some hints:
    Ask the local dealer to print out the parts list and a picture of the strut assembly.
    --purchase new boots to go with; mine were totally rotted away.
    --purchase new strut bearing assemblies (which attach the strut to the car body).
    Mine were either badly worn or corroded (the cars had very different histories)
    --purchase new lower insulators (US$20 each, from Toyota; no aftermarket available)
    --prepare to reuse the insulator portion of the upper OEM combo insulator/boot. News are $$
    --purchase new "dust seals" (look like fiber washers of some sort)
    which go on the strut piston at the bearing interface.
    The procedure starts with removing the wiper arms (!),
    the black cover over the wiper assembly, and the
    wiper motor assembly. Yes, it needs to be done...
    the wiper assembly blocks access the the strut bearing bolts on the top.
    You will need 2 jacks: one to lift the car (or then place it on jackstand) and then later use the other jack to compress the springs while you attach the coil spring compressor bolts for the move of the spring from the old strut to the new.
    Carefully observe how the strut comes apart; you need to replace the components in the same order AND alignment, otherwise you will experience clunks from the front when you finish.
    Look for alignment features like arrows (on the top bearing plate of the strut) and dots of paint.
    Once I got the process figured out, it was about 2 hours per side, including freeing up rusted hardware from salt and corrosion.
    Needed an alignment afterwards.
    Good luck!
