Osram Drl Led Light@Day
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Gaulois_, Apr 30, 2013.
  1. Gaulois_
    Gaulois_ Junior Member
    Hi all,
    I don't know if you have this model in us and if someones tried to fit in a prius gen 3-2010 but here is the result.
    You can see 2 holes upper of the drl, it was a previous mount with daylight 8 and daylight guide by philips.
    But i have some trouble with philips ones even if it was compatible first with zwv30 in the philips drl leaflet for the daylight 8 12824wledx1 and after "Start & stop / hybrid cars compatible" for the daylight guide 12825wledx1 as the packing says.
    The first 3 wires module (red +12vdc battery, black 0vdc, orange +12vdc light position) and the second 4 wires modules (red +12vdc battery, black 0vdc, orange +12vdc light position, blue +12vdc ignition) have nearly the same working.
    Troubles i have with my prius model :
    1st after opening the door with smart (without key and after the car was stopped a night long for example), philips drl lights 7seconds.
    2st after take place at the conductor seat without power on or accessories on, pushing the stop pedal lights the drl during 7seconds, off and 7 seconds more, off ... etc.
    3rd after powering down the power, closing the doors, locking the doors with the smart (without key) 1minutes and about 20seconds later the drl lights 7 seconds.
    The only solution philips gave me was to connect the red wire to +12vdc ingition but in this way the position light in power off don't work (in europe we can't have 4 position lights).
    So i have founded Osram Drl Led Light@day. In the osram leaflet the zwv30 isn't compatible with drl + position due to 350mm height according to ECE.
    But i have decided to try to fit this model anyway with the best car mounting possibility even if it was more difficult than the philips ones due to the osram design.
    3 pictures more than a speech.
    Regards.
    Bullet Salvador likes this.
  2. Gaulois_
    Hi there,
    here is some mesures pics and a pic for the mounting on the grill (dremel and other tools out).
    Regards.
  3. xliderider
    xliderider Senior Member
    8,016
    3,198
    Honolulu, HI
    Can you post some pictures of them illuminated? Night and day shots if possible. Do they dim at night when low beams are turned on, or do they turn off when low beams are turned on?
    zhutton and Bullet Salvador like this.
  4. Gaulois_
    All illuminated.
    Dipped/Low Beam OSRAM Night Breaker Plus H11
    Main/High Beam OSRAM Night Breaker Plus HB3 9005
    Front Fog Lamp OSRAM Night Breaker Plus H11
    See what u want.
    Sorry for the quality of my old panasonic fx01 with automatic mode by a rainy day.
    Regards.
  5. xliderider
    8,016
    3,198
    Honolulu, HI
    Looks good, thanks for the pictures. :)
    You might have to adjust your left side headlights, they look like they're high.
