out of gas , getting out of safe mode
Discussion in 'Gen 2 Prius Technical Discussion' started by Ray Moore, Jan 8, 2008.
  1. Ray Moore
    Ray Moore Active Member
    857
    52
    Texas Hill Country
    Well after running out of gas a few times and driving to the station, it finally happened. My 2004 Prius refused to start. Oh whoa is me, all the dire warnings I've read here filled my head. Somebody is going to come from the region with the dreadfully expensive traction battery boost thingamabob. Drats. (insert Calvin and Hobbs emoticon here)
    What really happened is this. I ran out of gas with the with the miles driven divided by the current mileage at around 11. As I fill it to the top or close to it each time, this was odd until I remembered that in past instances of running out the car cut out while on a long gradual uphill. Aparently the pickup in the tank is affected by driving up a long uphill grade. OK lesson learned.
    Unfortunately the first gas station was closed for repairs so I had to drive to the further one. I filled up and turned the car on. It would not go into ready mode. I tried about 50-70 times to restart the car, hoping to clear the codes that were keeping the car from going into ready mode. No dice. Oh no, more dire warnings running through my head. What an idiot. ( Homer Simpson emoticon here)
    I towed the car to the dealership. They cleared the codes.(p3191, p3193, and poaof) The car started right up. The car had entered safe mode to protect the battery from further discharge in order to prevent damage. Note to self. Car is smarter than you which is as it should be.
    Charge was 25 for the tow and 98.95 for clearing the codes. It took them a few minutes.
    I asked the tech how many times I would have had to restart the car to clear the codes myself. He told me it takes 100 times. This is one of the rare instances when I wasn't stubborn enough.
    The car has 87,600 miles on it. I love it. I just wished to share this info with ya'll as an extensive search did not turn up what I needed to know. I did find some discussion of the traction battery booster at the regional office. I had forgotten reading about safe mode somewhere here in the past.
  2. bwilson4web
    16,215
    Thanks for the report!
    When I am planning to run out of gas, I put a 1 gallon spare can in the back so all I have to do is reach a safe area to refuel. Typically, I find a safe place to refuel within a quarter mile and slow down so the battery is not stressed. Then I drive directly to the test gasoline station for a full tank and refill the spare can. I've run out of gas about three dozen times in my gasoline studies.
    Speculation now, I wonder if the battery might have gotten a little too warm. Also, disconnecting the 12 VDC battery for a minute is another 'reset' approach that might have cleared the problem. However, it would not have cooled the battery, only time can do that.
  3. Ray Moore
    857
    52
    Texas Hill Country
    I let it sit over the weekend and retried before towing it in. I drove at 45mph or less after I ran out and nursed it as gently as I could to minimize both wind resistance and heating of the battery and motor and inverter.
  4. PrematurelyGray
    PrematurelyGray Junior Member
    62
    Pittsburgh
    Interesting! Not that I ever plan to run out of gas, but it's good to know that I may only suffer a repetitive stress injury from pressing the power button, instead of more dire consequences.
  5. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    umm...seem to remember that you can start it in safe mode by unplugging one of the modules under dash, power it up... unplugging module prevents you from shutting it off in normal manner. so you have to hold power button for 7-10 seconds to power it off. then plug module back in, power up. codes cleared.
    the module was same one you unplugged for EV switch.
    not sure of ramifications of this. i did it on my Prius by accident (forgot to plug it back in...Duh!!) but no ill effects i could determine. that happened about 19,500 miles ago... got 20,000 now....nothing but oil changes to keep her going
    now dont know if it clears all codes, but i did generate a few of them by starting it up with module unplugged.
  6. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    I have a really hard time believing that one of the ECUs has
    a counter that keeps track of *100* restarts. That sounds more
    like the width in millimeters of the tech's BS howitzer. Some
    other condition was probably slowly coming back into an acceptable
    range while you were trying.
    _H*
  7. icarus
    icarus Senior Member
    4,884
    976
    earth
    Will a scan gauge code reset, reset the code? If so the scan gauge @~$150 would be cheap insurance even if you didn't use it for a running gauge.
    Icarus
  8. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    scangauge is supposed to be able to reset codes... to be honest with ya, dont know, never had to try it...
    funny thing how keeping gas in the car is so difficult. seems counterintuitive for a car that gets better gas mileage
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    It's similar to when I used to drive a Jeep C-J5: That vehicle could go through almost anything, and I was never stuck more in my life. You just have to try harder.
    Tom
  10. patsparks
    10,664
    567
    Adelaide South Australia
    What is wrong with people?
    I am doing a casual survey, did you have 2 bars on the fuel gauge?
  11. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    I would speculate that running out of gas should indicate no bars. :rolleyes: Not a good idea to let that tank go dry. Unfortunately, we cannot really push it like a stick shift. :D
  12. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Not entirely true. The gas engine provides lubrication for the synergy drive, so driving for extended periods without the gas engine is not recommendeed by Toyota.
  13. Dozzer
    Dozzer Prius Noob
    189
    Swansea, UK
    So what happens if I have a Hymotion extra battery and run in EV mode for 30/40 miles ? Can't be good for the PSD.
  14. Ogo
    Ogo Prius Owner since 2008
    220
    44
    Ilirska Bistrica, Slovenia
    If you have enough fuel in the tank, no problem. You can go electric and petrol will still be cooling some parts down. ;)
  15. D K
    D K New Member
    LA
    I drove 45 miles after the gas gauge started blinking. Not sure how much more I could have gone...
  16. Redzeroseven
    Redzeroseven New Member
    I have run out of gas twice. Once by accident and once on purpose.
    I have kept close track of my gas mileage. My gas mileage indicator is about 1.5% high. I was under the belief that my usable gas was 11.9 gallons (like it says in the manual).
    The first time I ran out of gas I was driving up a grade and I thought I had a gallon left. I was not far from the gas station and I was easily able to get there (I kept the acceleration light to be safe). I filled the tank from empty and it took 10.95 gallons.
    I wondered if the car ran out because I was on a hill. I then planned to run out of gas on flat ground. It again ran out at with what should have been about .9 gallons left. I refilled the tank and again it took just under 11 gallons.
    Perhaps my fuel pick up is not set in the bottom of tank.
    For my car I have just slightly over a gallon when the last gas bar starts to blink. If you were averaging about 50 miles a gallon, you were probably very close.
  17. MikeMc
    MikeMc Junior Member
    So, what are the options if you should happen to run out of gas with the Prius? Are you able to drive from battery power? How far can you go at about what speed? Is there a warning to let you know when to stop driving on batter power?
  18. patsparks
    10,664
    567
    A tow truck to bring fuel is cheaper than a new traction battery. Better still, don't run out. I struggle to see the logic in running out of petrol. I fill up when the gauge gets down to 2 bars, why go lower than that?
  19. qbee42
    18,058
    3,079
    Northern Michigan
    A Prius with a nominally charged battery might make it about half a mile, but don't do it. Drive only far enough to get safely off the road. In general, treat an out of fuel situation in a Prius just as you would with any normal car.
    Tom
  20. grand total
    grand total Member
    154
    ON, Canada
    I think it depends on your fuel gauge. I'm quite comfortable with driving until the gauge is on one flashing pip before looking for petrol. In winter I will fill up on reaching one steady pip because the consequences of running out of petrol in winter may be so much more serious.
