Outside temperature sensor
Discussion in 'Gen 2 Prius Technical Discussion' started by pks4000, Mar 12, 2007.
  1. pks4000
    pks4000 Junior Member
    The outside temp sensor on my 2006 Prius reads 2-3 degrees higher than true outside temp on my mileage display screen.Sounds like a small thing but it bugs me and in the NE US it's a good tool in the winter.
    Can it be adjusted? replaced
    Where is the lttle bugger located?
    Thank you,
    John
  2. John in LB
    John in LB Life is good
    399
    27
    Orange County
    <div class='quotetop'>QUOTE(pks4000 @ Mar 12 2007, 03:50 AM) [snapback]404134[/snapback]</div>
    In the front grill, lower part - I think.
    I would try claiming it under warranty.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    It requires the service dept. scan tool to adjust. If you're still within your 12mo/12k mile "adjustment period" they should do it for free. If you're outside that, cute, blond and wear short skirts you might still be able to get it free....ok, maybe even if you're fat and ugly but ask nicely. Otherwise they could insist on charging you for the service.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    <div class='quotetop'>QUOTE(efusco @ Mar 12 2007, 08:04 AM) [snapback]404155[/snapback]</div>
    I'm still stuck on the "cute, blond and wear short skirts" part. :)
    Tom
  5. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(pks4000 @ Mar 12 2007, 07:50 AM) [snapback]404134[/snapback]</div>
    I am confused. I'll agree that the temp sensor is located in the lower right grill and that it reports through the MFD. Where are you getting the 2nd reading from and how do you know the second device is accurate?
    With my grills mostly blocked the temp reported on the MFD is within a degree or two of what is reported on the radio and time/temp signs.
  6. pks4000
    2 digital thermometers and trained observation say its 2-3 degree off.
    <div class='quotetop'>QUOTE(JimN @ Mar 12 2007, 10:32 PM) [snapback]404525[/snapback]</div>
  7. John in LB
    399
    27
    Orange County
    <div class='quotetop'>QUOTE(efusco @ Mar 12 2007, 06:04 AM) [snapback]404155[/snapback]</div>
    Is that right? Its adjustable in an '06? Can it be done through the diagnostic menus or do you really have to go back to toyota dealer to do it?
    Let me know... I will have to check the accuracy of mine and then tweak it as needed... based on what you tell me.
  8. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    What does that mean??? Lower right grill?? Is that passenger side, or driver side???? "right" could be either depending on whether you're looking at the car or sitting in it........... HELP!! where is this sensor?
  9. TheAnnoyingOne
    TheAnnoyingOne New Member
    318
    -118.15476, 34.112134
    <div class='quotetop'>QUOTE(Rangerdavid @ Mar 16 2007, 05:58 PM) [snapback]407096[/snapback]</div>
    In front and a bit to the left of the front right wheel.
  10. Rangerdavid
    1,362
    52
    Three Touring
    <div class='quotetop'>QUOTE(The Annoying One @ Mar 16 2007, 09:23 PM) [snapback]407107[/snapback]</div>
    :lol: :lol: Well,,,,, that certainly cleared it up...... :lol: :lol: :lol: clear as mud......
    passenger or driver? or by right wheel, do you mean the "correct" wheel? or was it the wrong wheel?
  11. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    Passenger side (in North America). No end to confusion...
