Overheating?
Discussion in 'Gen 2 Prius Technical Discussion' started by hornda, Feb 11, 2011.
  1. hornda
    hornda New Member
    Houston
    I was driving on the freeway in houston yesterday and it was about 30 degrees. The low temperature light was on... Does it make a difference when it is cold? Why would there be a light to tell u that it is cold outside?
    Anyways as I was driving on the freeway the red triangle with an exclamation mark came on and disappeared. Then a minute later it went on again and on the navi screen shows high coolant temperature symbol on it. But then it would turn off right away too so is this normal because I was kind of slowing down on the freeway and the book did say something but I don't think it was an excessive speed or anything.
  2. Patrick Wong
    18,200
    6,490
    The amber snowflake light is there to warn you that outside air temp is <=37 degrees F, and that the pavement may be icy as a result.
    If you saw the high coolant temp symbol on the MFD, that should not be ignored. Have you had the inverter coolant pump replaced, under the limited service campaign that is currently underway? Failure of the inverter coolant pump is the most likely reason for you to see that warning.
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,515
    38
    Santa Fe, NM
    Definitely check that inverter pump -- you can tell if it is working correctly when the car is in Ready and you can see turbulence in the IC pump reservoir. On the other hand, once set, a temperature warning for the IC pump usually does not go away on its own.
    You may have a problem with your engine cooling system. Check your coolant reservoir. If empty, consider that it had to leave the cooling loop somehow, most likely via the water pump seal. If it is the water pump, your dealer will be extremely happy to replace it for you when you go in for the IC pump recall, since they frequently suggest that repair anyway whether or not the car needs it.
  4. cvec7
    cvec7 New Member
    Anchorage, Alaska
    Are issues with overheating and heat transfer common with the Gen II Prius? I tow a 1500 lb trailer each weekend in the winter, and haven't had any issues. Should I look into beefing up the cooling system?
  5. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    As I am sure you are aware, that is 1500 pounds more than Toyota recommends. I would consider getting a ScanGauge II or a similar meter so you can know your coolant temps, not guess about them.
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    1500 pounds is only 1500 pounds over what Toyota recommends. ;)
    Tom
  7. seilerts
    3,326
    1,515
    38
    Santa Fe, NM
    Have you made any suspension modifications to handle the tongue weight? I put rubber donuts in the rear springs to maintain ground clearance in light of extra weight as a short term solution but still have not found a practical long term solution.
    Also, do you notice a wider range in your main battery level when you are towing, such as dropping down to 1 bar or going up to 8 bars? I would suggest using B for engine braking if you are at 6 or more bars.
    +1 on the ScanGauge idea for monitoring coolant temps, especially if you do any towing in the summer. It would also be good to keep an eye on the main battery temperature -- cycling under heat is the most damaging to them.
    Modifying the engine cooling system would be complicated. But the engine is a very robust/reliable component, so that would be the least worrisome. The inverter cooling system also cools the transaxle. That loop would be easier to modify, if you can figure out how to mount another cooler and have an AirLift for bleeding. The transaxle is a little more fragile -- how often do you change your ATF?
  8. GoMetricToday
    GoMetricToday 42 is the answer to the ultimate question.
    64
    Erwin, TN
    The snow flake symbol must be a Gen II feature. I don't believe I have that in my Gen III.
  9. uart
    uart Senior Member
    4,220
    1,209
    Australia
    I think it may even be only a 2004/2005 year model feature and they removed it on later Gen2's. I've got it on my 2005 model.
    Apparently it's just a nuisance for people in colder climates where that "warning" light is basically a permanent fixture for about 6 months at a time. For me however it's actually useful because freezing conditions are quite infrequent here. To be warned of the possibility of ice is not such a bad thing for me. Interestingly, in the 20 months that I've owned the car I've only seen the snowflake on about two or three occasion. :)
  10. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    u need additional cooling if you're going to be pulling a trailer that often.
    i've done this.. you're probably burning oil in the process too. if you watch clostly you'll probably see your inverter fluid level slightly drop too. ( i saw a difference only after towing )
    don't tell toyota you tow... ever... check to see if you qualify for the inverter pump recall.
    i would add cooling systems to your oil, PSD fluid and inverter fluid.. but it should probably be custom.. and on some sort of a switch so you can open or close the loops. you don't want additional cooling while not towing or else mpg drops will be expected...
  11. V8Cobrakid
    3,790
    152
    btw.. that light is there as a travelers warning. it to tell you that it's 37 degrees outside, and at that temperature, overpasses (windchill) and shady roads can start to freeze.. and black ice can be kept frozen.
  12. hornda
    hornda New Member
    Houston
    dammit there is a invertor pump recall? I just bought the car from the auction and i had to replace the whole invertor because of the wreck.
    So I am really new at this.... turbulence in the pump resevoir is a good thing or bad thing?
  13. richard schumacher
    7,664
    1,042
    United States
    Good thing. It shows that the pump is running as it should. No turbulence = no pump = impending inverter overheating = bad thing.
  14. jdenenberg
    jdenenberg EE Professor
    3,910
    1,908
    Trumbull, CT
    2020 Prius
    LE AWD-e
    It shows that the pump is working - a good thing.
    JeffD
  15. GoMetricToday
    64
    Erwin, TN
    I just traded my 2010 Gen II Insight for my 2010 Prius. My Insight had a similar light on the dash. Honda said that it was to remind the person that when the light is on not to push the engine too hard until the light goes off. I know it is a simplistic explanation. LOL. I can see the logic in the light, but when I see a warning light come on I assume there is something wrong, not to remind me not to do something.
