Overpriced 30k Service
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by icarus, Apr 22, 2009.
  1. icarus
    icarus Senior Member
    4,884
    976
    earth
    Does anybody think that $279 for 30K service is too expensive,,,besides me? All that is involved is lube oil and filter, check fluids, cabin air filter and tire rotation.
    This is the only time the car has seen the dealer except for the first "free" oil change. When mentioned that I ran synthetic oil,,, they said,, oh,,,that is $89 more! I said $89 more or $89? She "corrected herself and said,, oh just $89. $89 for an oil change!
    I had them do the service since I was there,, except the cabin air which I had already done. (Cabin air filter service was $50! The filter cost me ~$15 from the same dealer,,, and it takes what,, 30 seconds to do?)
    They did find a nail in a tire that they fixed, for $20,, not to bad considering the cost of everything else!
    The bottom line is,, this is the last time this car will see the dealer unless it needs warrantee service. I will continue to do LOF every 5k and will take it to my trusted independent so that they can begin to learn on them. I understand that dealers need to make a profit,, but when you drive into a covered heated reception area, with 6 "service advisors" sitting around trying to lever more money out of people you realize that it aint coming out of my pocket again!
    Icarus
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Is there even a Toyota dealer in that part of Ontario? Or are you talking about Thunder Bay?
    Yeah, that is highway robbery, to be sure. Just getting the quotes, I would have drove off
  3. NavyScotty
    NavyScotty New Member
    Southeast Georgia
    good advice. Thanks for the warning.
  4. icarus
    4,884
    976
    earth
    Wilson Motors,,, Bellingham, WA We are in the our in between season.
    Icarus
  5. jayman
    13,439
    641
    Winnipeg Manitoba
    Gotcha
    Seriously though, a quote like that I would have had a comment that rhymes with "duck shoe" and drove off.
  6. boppo
    boppo Active Member
    799
    138
    Owego, NY
    I think most/all dealers try to clean out your wallet when you take it in for any thing. I have a 88 camry with 235k on it and it's been to the dealer only 6 times and all of those times they tried to take advantage of me saying you need this and you need that, case in point they said I needed a new water pump because it was leaking a little and 5 years later I changed it.
  7. SureValla
    SureValla Member
    590
    Shelton, CT
    I'd say that price is average. Here in the NYC/Westchester area they charge 450 for that service so consider yourself lucky
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    When I had my 30k service done, the service writer quoted a fairly expensive price for the 30k service package. I asked him what they did at 30k for that price, and he handed me a generic sheet for 30k. I looked at it and said "Let's see, the Prius doesn't have one of those; you don't need to do that, there isn't anything to check here; normally you don't change that fluid until 100k..." He looked a little sheepish and said "Well, yea, that's a generic form. So shall we do it piecemeal?" The final cost was one-third the package cost.
    Moral: Always take your service schedule with you when you talk to the service writer. It keeps them honest.
    Tom
  9. icarus
    4,884
    976
    earth
    We picked up the car tonight,,,the tab was $281 before taxes.
    Here is the breakdown Labor for 30 k service,, $180
    Included, lof, tire rotation, replaced engine air filtrer, torqued steering and suspension components (really?) Inspect, ball joints, bake lines, exhaust system, fuel lines, tank band, fuel tank vapor vent fuel cap gasket (really?) radiator core and condeser, coolant, steering gear linkage and boots, cleaned (really?) and inspect brakes linings/pads.
    Parts,,, engine air filter $20.44
    w/w solve (whats this?) 2.50
    Oil filter (Not too bad!) 6.48
    gasket (drain plug?) 1.26 (copper washers sure are expensive)
    oil (synthetic) 6.25 25.00
    Total parts 55.68
    Tire repair (nail) 19.95
    Now the really interesting parts,,
    Hazardous waste fee $1.11 (I have no problem with this)
    MISC SHOP SUPPLIES 12.00 This is listed as everything from hacksaw blades to carb cleaner. (in fact carb cleaner is listed twice on their misc list,,, clearly people have complained about this before! Carb cleaner, choke cleaner, and carb SOLVENT! who knows what the difference is,, not to mention the fact that no Toyota that I know of has had a choke or a carb in 20 years!)
    So we dropped the car off at 8:50 am,, at 9:45 they called to say it was done except for repairing the tire (they wanted to authorize the repair) So the way I figure it, they worked on the car for about 1 hour,, plus taking the tire to the tire shop. So the shop rate is ~$180 an hour?
    Now I am not naive, in fact I know about flat rate tables and I understand that shops need to cover their overhead. I also realize that times are tough in the car biz these days,, but I think that trying to make it all up on the backs of potentially unsuspecting customers is un ethical if not criminal. In defense of the dealer,, they did give us an estimate before we started,, but I think that they bounce the number up high enough to make some real money,, but not high enough to get people pissed off.
    I can take my car to Jiffy lube and have a LOF for ~$30,,, tire rotate from the tire store ~$20 Les Schwab will do it for nothing even if you haven't bought the tires there! For $100 I can get a soup to nuts inspection by a GOOD independent garage. As a matter of course, my normal shop, that does German, Swedish, and Japanese cars does a pretty complete inspection with routine LOF service for ~$50.
    I think this is the last time the car will see the dealer,, unless some warrantee issue comes up. (They are scheduled to to the TSB on the Aux input audio system,,, the one that makes the I-pod squeal. I had to request that,, they weren't offering)
    Icarus
  10. icarus
    4,884
    976
    earth
    You're getting ripped off quicker than I. Why don't you take the car elsewhere?
    Icarus
    PS Too many people have been BS'ed into thinking that the dealer has to do the routine service to keep the warrantee valid,,, not so!
    T
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    I think I've seen those generic 30K sheets:
    1: Lube driveshafts
    2. Change front and rear axle fluid
    3. Lube chassis
    etc
    Amazing how fast the bill goes down when you bring up the inconsistencies
  12. jayman
    13,439
    641
    Winnipeg Manitoba
    No, not really
    Yeah I bet.
    To have fun, you could have put "witness marks" on the parts in question before you took it in. I can almost guarantee the witness marks would still be there
    Windshield Washer solvent. Fancy-schmancy name for windshield washer fluid. I can buy a whole gallon of good -45 rated stuff for what they dinged you to top it off
    That's in Canadian dollars, right??
    Maybe they were taking a collection for an office retirement party. Beats me
    Temporally, it's highly improbable they could have done all the work they claimed to have done.
    Not criminal. But unethical
    I would use caution with Iffy Boob. There are real horror stories out there
  13. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    On my previous car, a 2001 Ford Focus, they told me for something like four years in a row that the power steering pump was leaking. "How much is it leaking?" "Erm, well, not very much."
    I never saw the power steering fluid reservoir level change, and I don't recall seeing a charge for it to be topped up.
    They did get me for a rear brake cylinder at something like £300. I'm a bit more wise to it now, though.
  14. SureValla
    SureValla Member
    590
    Shelton, CT
    Believe me after paying a 450 once I do go somewhere else every 15k and I've always done my own oil change(~35$) at non-15k intervals so the 450 was a bit easier to take.
  15. icarus
    4,884
    976
    earth
    I don't take the Prius to Jiffy lube,, or any other car for that matter. The best purchase I made in the last few years was a hand operated vacuum pump. I was very skeptical until I spoke to my European car guru. He said that is all they use in their high end shop.
    Stick the hose in the dipstick hole,, pump the handle a few times and in about 5 minutes ALL the oil has been sucked out. Spin off the filter, spin on a new one,,, pour in the new oil and you are done. You never even have to get your hands dirty.
    As a test,,, the first time, I pulled the drain plug to see how much oil was left. Not one drop came out after I pulled the plug! I'm sold. Never worry about stripping a drain plug thread or being caught without a new gasket.
    Icarus
    PS Jay,,, that was US $$!.
  16. Patrick Wong
    18,200
    6,490
    Windshield wiper fluid (or solvent) - the blue liquid located in the translucent plastic container near the RF fender. Considering that price I hope it is the methanol solution that doesn't freeze.
    Hi Icarus,
    Very interesting. How many feet of hose do you need to insert into the dipstick hole? Why bother to use Jiffy Lube or the dealer since you are equipped to DIY so easily?
  17. jayman
    13,439
    641
    Winnipeg Manitoba
    I have a 2 gallon Mityvac model that I use for servicing older automatic transmissions without a drainplug on the pan. Remove dipstick, stick tube down hole, give a few pumps, no cascade of hot ATF when I remove the pan
    However, I find the Prius oil change easy enough that I just go ahead and do it on level ground. For a drain pan I use a large but shallow Tupperware container.
    :faint2:
    Holy .... s***
  18. icarus
    4,884
    976
    earth
    Patrick,,
    I don't use jiffy lube,,, I don't trust them except for detroit iron. I do it myself,, except when I am travelling. The hose that comes with the vacuum pump,, (brand name escapes me now,, but you can find them at most marine dealers) is ~1/4 diameter,,, and goes in as far as it can go,,, into the bottom of the pan. You can feel when it bottoms out. After it has sucked the bulk of the oil out,, you can move it around to find and vacuum any residue. Really does work great.
    The washer fluid thing is complete BS! I keep mine full,, if it was down more than 1/2 cup it would have been a lot. As I suggest,, It is not going to darken the door of the dealer again.
    Tony
  19. hill
    8,564
    Soooo, I take it you haven't read Galaxee's stickey (directly above this thread) before going in? or all the posts under it?
  20. ceric
    ceric New Member
    1,114
    Fremont, CA
    Why do the 30K?
    Just
    - ask for oil change (+27 points inspection for $29.50 around here)
    - buy air filter and cabin air filter and install them in 1 minute yourself
    - rotate tires yourself
    The total cost will be less than $80.
    If you don't like rotating tires, that is another $20 for them to do it. Still under $100.
