P0351 permanent code
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by L8ter, Oct 27, 2024.
  1. L8ter
    L8ter New Member
    Missouri
    This code came up car has slight miss when you first start out and gets worse as it warms up I know it says coil code I changed coils plugs I took a light tester and coil is firing wondering if a fuel injector could cause this
  2. L8ter
    L8ter New Member
    Missouri
    it is a 14 Prius 2
  3. Brian1954
    Brian1954 Senior Member
    1,563
    606
    South Central PA, USA
    If the P0351 is a permanent code, it will eventually clear after driving the car for a while. As long as the code is not an active, pending, or current code, you probably fixed the problem already. Drive the car for a week or two and then check for codes again.
  4. L8ter
    L8ter New Member
    Missouri
    The car is still misfiring while driving
  5. SFO
    SFO Senior Member
    5,302
    4,244
    Northern California
    Welcome to PriusChat!!
    How many miles on this gen3?
    Do you have coolant in the radiator overflow tank?
    Does the engine 'rattle'' for a few seconds when started from cold?
    Wondering if it could also be a bad head gasket. Did the misfiring plug look any cleaner than the other three?
    FYI: you're moderated until you've posted 5 times.
