1. Bruce h baker
    Bruce h baker New Member
    Mesa az
    Engine code p3190 i replaced the mass air flow sensor with no luck still has the same issue no engine power it's acting like it's out of gas so i went and got 6 gallons of gas to put in it still the same problem any suggestions
  2. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Fuel pump?
    How many miles on your Prius?
    SFO likes this.
  3. Sauceee
    Sauceee New Member
    North Carolina
    2003 Prius
    Did you ever figure out the problem? I'm having the same code, engine shakes/jerks when I crank it up. It shows I have a quart of gas I will try and put more in and see if that fixes the problem.
