Paint chipped touch up ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Superdrol, Oct 17, 2010.
  1. Superdrol
    Superdrol Member
    399
    32
    I recently got a few stone chips on my hood which are relatively deep. Do you just put touch up paint or do you put several layers ? Sometimes a botched touch up job can be just as bad as the chip itself whic is what I am afraid of.
    I used a toothpick and just put a thin coat over it. Just one coat. Is this adequate ?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yeah, it seems many thin layers are better than one thick blob. As the blob drys it leaves an indentation. If you build up thin layers it won't.
  3. Superdrol
    Superdrol Member
    399
    32
    Is there a better way to blend it ? I can still tell where the chips are and it does not look 100% blended. I try to put 1 or 2 layers max on as multiple layers makes it noticeable. Then I just waited and waxed it later on in the week but I can still tell where it was put.
    Didn't know if there was a better way to blend it.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    What color do you have? My white makes blending easy...
  5. Superdrol
    Superdrol Member
    399
    32
    Mine is silver. I like white though. Would have bougt one if they had one in stock when I purchased.
    Can you take a pic of a spot you touched up? Maybe I am as good as it will get with it.
  6. jayrider
    jayrider Member
    163
    17
    southwest illinois
    Google youtube for chip repair. Doing it right takes time and technique. Then new chips appear. Every couple of years take it to a body shop and have them all fixed right.
