Paint Damage
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ilenemac, Oct 18, 2010.
  1. Ilenemac
    Ilenemac Junior Member
    Sunset Beach
    Hi I have had my prius IV for 3 weeks. I went to wash it and noticed a lot of swirl marks in the paint. I called my dealer do you think they will anything. Has anyone had this problem.:mad:
  2. rpeek2
    rpeek2 Dry Ice Juggler
    149
    MidwayUSA
    The new light-weight (weight and durability) paint/clear coat that is used doesn't seem to be very enduring. My blue IV has the ghosts of alot of bug splats etched into the bumper's clear coat. Waxing didn't seem to assist in enhancing the durability of the paint job. May help in masking swirl marks tho. What else can you do? At the rate the clear coat is disappearing this thing is going to weigh next to nothing ultimately. :(
  3. docsnavely
    docsnavely Insert Custom Title Here
    66
    Ocoee, FL
    When I bought mine (and joined the forum) a couple weeks ago, I had this problem too with my blue. I first looked up on the top right of the priuschat.com page and searched "swirl marks" in the search box. Lots of results came up.
    My solution was to use the toyoguard paint sealant that came with the car. Worked great. Try and get two coats on in the first application if you have time. Worked great for me.
  4. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Yep--this has been well-discussed. Search is your (his) friend! ;)
