paint problem and baking worry
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by priuscritter, Feb 5, 2011.
  1. priuscritter
    priuscritter I am the Stig.
    1,525
    199
    Indiana
    I have found a paint defect on the upper door frame of my Prius. There is a small amount of exposed metal that has started to rust. The body shop that Toyota contracts with said it will need to be sanded, primed, painted, and baked at 160 degrees. They are not taking the door off, but rather putting the entire car in the paint stall for baking.
    While I know that the normal car components can handle that, I'm worried about the traction battery. This battery has to have it's own special vent, and somehow heating that battery up to 160 degrees for an hour doesn't feel like a good idea. Does anyone have any experience with this, or have any knowledge that would be useful? Should I demand the door be taken off and baked on it's own?
    Thanks.
  2. BrettS
    BrettS Active Member
    290
    137
    Orlando
    You might want to push a little and see if they'll take the door off, but I wouldn't worry about it too much. I live in FL and I imagine that if my car is left out in the sun on a hot day that it would be possible for the traction battery to get up to (or even above) 160 degrees. Plus, since it is buried under the seat on the interior of the car I wouldn't think that it would make it all the way up to 160 after only an hour in the booth.
  3. Mendel Leisk
    41,486
    I can't believe the baking is necessary. We've had lots of body work on lots of cars over the years, never heard of that.
  4. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    if the car is in a stall at 160 i would think it would takes over 4-5 hours before the heat would rise that much inside of the car.
  5. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    70C is hot, but not that hot. someone could work out how long it would take to heat the mass of the traction battery up to a dangerous level, whatever that may be.
    in short, don't worry about it.
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    The last car I had painted they just used heat lamps on the area that was painted instead of heating up the entire car.
    When they build the car they use an oven but they do that before they install any of the electrical or electronic components.
    If you do decide to let them heat the entire car up I would make sure the 12 Volt battery is disconnected so there is no chance of turning anything on while it is hot.
  7. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    My car had to be partially re-painted twice from being involved in a couple of accidents and I don't know what the body shop did, but isn't the paint they use for repainting designed to be quick-drying, which is why it's never as durable as factory paint?
  8. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Sounds to me like they're taking a short cut to save time/money. It's not that big a deal to remove the door, so I'd request they do so. I had a front bumper repaired years ago, and they removed the piece so they didn't have to put the entire car in the hot booth.
  9. bisco
    51,969
    i don't like it, but i have no facts to go on. the problem is, every problem down the road will make you wonder. and, of course, the dealership will say it had nothing to do with it. i don't see why they can't take the door off, strip it down completely and then put it all together. it's a factory defect after all, and in the factory, they paint it before adding any components.
  10. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Dealers always want to go the cheapest route, so call up a reputable body shop and ask what they'd do then demand that the dealer does the same.
  11. priuscritter
    1,525
    199
    Indiana
    well actually, the dealer first suggested touch up paint, but wanted me to have the body shop give their opinion because they wanted me to be satisfied. odds are, this isn't going to be a big deal, but i would like to talk to to a toyota tech or someone who has had the whole car painted, like a customized paint job, to see what they think. this is all just very frustrating for a 1/8 of an inch bare metal spot.
  12. macmaster05
    macmaster05 Senor Member
    4,050
    730
    If you're under 36k/3 years I would definitely get it fixed. It's a factory defect.
  13. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    So did this body shop actually suggest that the door not be removed? Is it a reputable, insurance company-approved body shop?
  14. stream
    2,977
    452
    Long Island, NY
    For a 1/8 inch spot, depending on where it was located, I'd consider having it spot sanded and touched up by hand. The alternative might well leave you with a door that doesn't match the rest of the car, particularly with metallic paint.
  15. priuscritter
    1,525
    199
    Indiana
    i'll have to take a picture of it to show you. it's all inside, not visible from the outside. it's like a metal rail that runs the perimeter of the window.
    they didn't suggest on purpose the idea of not taking off the door. he just said they would put the whole car in the paint heater.
  16. adamace1
    1,403
    193
    Charlotte, NC
    Alot of times if they are painting a door, they will aslo paint other areas around the door to blend in the new paint. And the body shops i have seen do use the heated booths to paint in.
  17. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Cars are very commonly baked in the paint booth when body repairs are done. Its not a big deal.
