Parasitic 12v Battery Drain - ECU B fuse?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PerdidoPrius, Jun 13, 2016.
  1. PerdidoPrius
    PerdidoPrius New Member
    Perdido Key, FL
    I just purchased a 2011 Prius with 67,000 miles and I'm looking forward to a good decade of service. However, right out of the gate I am having trouble with a parasitic 12v battery drain. When the car is not driven for a few days, the battery is going completely dead. There were no lights on or doors open. The battery it came with was over three years old and even though AutoZone told me it was still good, after I experienced a 2nd completely dead battery after a few days of no use, I decided to replace it with a Optima. I was hoping to get lucky but the problem continued.
    I researched using a voltmeter to determine the parasitic drain source and hooked up the voltmeter in line with the 12v battery in the trunk. The voltmeter was showing a draw of 6 to 7 amps (or VoLTs?). I then started pulling fuses, looking for that number to drop. Eventually I landed on the ECU B - 7.5 fuse and when pulled, the 6 to 7 dropped to 0.1 or less.
    So, if you can't tell, I barely know what I'm doing to this point and don't know what to do next. I have no independent local garage that I trust and would love to learn more. Any help is appreciated.
    Thanks,
    Dale
    Marty Lee likes this.
    50,804
    welcome! are you sure it's not under warranty?
    can you give us the stone cold battery voltages on the new battery, starting with pre install and as you tested it?
  3. PerdidoPrius
    Perdido Key, FL
    Thanks. The new battery started at just under 13v and dropped to 12.7 over the first night, 12.5v by the end of the next day and 12.3 the 2nd morning. Once it hit 12.1v later that 2nd day, I decided to take it for a drive to make sure it didn't run too low.
    I didn't have a voltmeter on the original (Toyota 2014) battery, but now I'm sure that it wasn't the culprit. Autozone charged it for me the first time it went dead, saying it was still good, and it was dead after a weekend of sitting. Since it was too dead for my charger, I decided to just grab a new battery, rather than a new charger. Like I said, hoping to get lucky.
    50,804
    looks like you need a schematic to see what the ecu feeds. hopefully, someone here can help. all the best!(y)
  5. ChapmanF
    16,948
    Well, as you mention it, I did notice you seemed unsure whether what you had measured were amps or volts. :)
    That would be worth going back over to make sure you're sure. I assume that when you talk about your 'voltmeter', you really have a multimeter that lets you measure more than just volts. (A typical multimeter lets you choose at least volts, amps, or ohms, and often several other things.) There should be some kind of selector on the front. You might want to repeat your measurement, but double-checking to make sure your selector was on amps.
    If you did happen to measure in-circuit like that, but set on volts, you would get some sort of voltage reading, but it wouldn't be anything easy to interpret (it would be a mathematical combination of the car's leakage and your meter's impedance, and that's more complicated than we want to get).
    If you were really set for amps and reading 6 or 7, that is a really high leakage current. How high? Well, I think a Gen 3 aux battery is rated about 46 amp-hours, so a drain of 6 or 7 amps would be enough to fully discharge it in under eight hours. That sounds more severe than what you were reporting.
    If you did have the meter set on volts by mistake, and you were reading 6 or 7 (that is, about half normal voltage), that would tend to suggest the car's sleeping loads are roughly equal to your meter's impedance, and therefore a lot smaller than you were thinking. So it's worth measuring again to be sure what you measured.
    If you do end up having to chase circuits to track down a problem, your wiring diagram online at techinfo.toyota.com makes that really convenient, because it is pretty interactive, you can click on wires and terminals and components and follow them around the car, switching between the schematic views and the ones that show where things physically are, etc. Way faster than trying to keep eight of your fingers stuck between different pages of the paper wiring book. :)
    There is something interesting about the way Toyota builds their wiring, there are these things called 'junction connectors' scattered around here and there. Instead of building lots of wire splices into the wire harness, they'll bring a bunch of wires out to the same sort of multipin connector that's used for connecting to regular stuff, only what plugs into it is just a mating connector manufactured with a bunch of the pins shorted together. The wiring diagram shows where all of these are, and which pins are connected to which.
    I'm not sure exactly why Toyota builds the stuff this way, but a nice consequence (even if it's not the reason they do it) is that each one of these junction connectors can give you another place you can disconnect something and have access to measure different sections of a circuit in isolation from each other.
    -Chap
  6. CR94
    CR94 Senior Member
    2,658
    1,147
    Northwestern S.C.
    Be sure the hatch is fully latched, too. If it's only half-latched (one click instead of two), you'll have a parasitic drain of about 0.7 amperes, even if the associated lights are off. (That will kill the battery within 3 days.) Another possibility is a defective or misadjusted switch there.
    Check to be sure the interior lights are off when the doors are closed and the 3-position switch on the "personal" light fixture is in its center "door" position. If not, a door switch is probably misadjusted and you'll get the same 0.7-ampere drain
    For whatever it's worth, normal parasitic drain with everything off and closed is about 0.02 amperes (20 mA). At that rate, draining a healthy battery would take several weeks.
    #6 CR94, Jun 14, 2016
    greasemonkey007 likes this.
  7. lyoncf
    lyoncf Junior Member
    Midwest
  8. lyoncf
    Midwest
    Did you ever figure out this problem? I am having the same issue on my 2012 Gen 3 Prius. When I pull the ECU-B (7.5 amp) fuse my current drain drops from 1.5 amps (way too high) to about 150 mA. I assume something connected to the ECU-B is causing this parasitic drain. I have waited 15 minutes after I turn off the car and it is still sitting at 1.5 to 2.0 amps. Looking for some suggestions of common components connected to the ECU-B that might be causing this. Anyone have ECU-B schematics / wiring diagrams for a Gen 3? That would be a place for me to start with a hall effect sensor to see if I can track it down.
  9. MAX2
    MAX2 Senior Member
    1,343
    421
    101
    Third planet from the Sun
    How do you check? Is the machine closed, open? Is the fuse removed, inserted?
