Part Check 2005 Hood and Fender work on 2008?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rafikiro, Dec 12, 2017.
  1. Rafikiro
    Rafikiro Mockba
    50
    Pflugerville, TX
    Part Check 2005 Hood and Fender work on 2008? Local wrecking yard just got a blue 2005 Prius in. The hood and side driver fender will work on my 2008 right? Just missing the hybrid badge I think. Dummy check me before I run down there at the break of day so my car doesnt look like a mess anymore!
  2. JC91006
    16,632
    8,492
    Yes same part....interchangeable.
    How much is the hood? That's aluminum
    M in KC likes this.
  3. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Take a magnet with you if you want. The OEM hood is aluminum as JC says. Rebuilders typically save a few bucks and install carbon steel replacements. But yes all parts cross. You should be able to lift your hybrid emblem off your quarter panel with some heavier fishing line and reattach with an appropriate 3M adhesive.
  4. Rafikiro
    Rafikiro Mockba
    50
    Pflugerville, TX
    Thanks! Unfortunately the junked car was already harvested by the time we go there. Ah well, got an inner fender I needed at least.
