Patent 6,936,371 - Recycling Battery Pack
Discussion in 'Gen 2 Prius Technical Discussion' started by bwilson4web, Jan 26, 2008.
  1. bwilson4web
    15,934
    I would recommend using Google patent search to get a copy. The overall process is well defined. It is not a trivial process since it required a vacuum, plastic welding, and handling KOH while not absorbing CO_{2}. Still, it means it should be possible to refurbish our NHW11 and NHW20 batteries and keep them rolling until 'the wheels fall off.'
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,000
    Fort Lee, NJ
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
  4. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    The real question is whether the patent sees commercialization. Since a battery company owns the patent, I am not terribly optimistic. Afterall, their objective is to sell more batteries, not extend the life of present batteries.
  5. efusco
    19,891
    1,194
    Nixa, MO
    This is not something for the average Joe to do..you're gonna end up seeing me in the ER with a nasty alkali burn or worse IF you can even get your hands on the KOH and such. I'm not saying it can't be done, but it's not like we're all gonna be sitting around refreshing our battery chemistry...or at least I hope not.
  6. bwilson4web
    15,934
    Not to trivialize the risks and technical challenges, it also makes sense to share what is known so we can conduct informed investigation. Trying to replicate this process is not trivial and anyone wishing to commercialize this process will have to deal with royalties. Worse, I think this patent is a dead-end approach and reveals a major problem with current traction battery design.
    Personally, I think the idea of plastic welding is nuts. It requires using the same plastic forming method used to manufacture the battery. This can be done but it is not trivial and quality control of each plastic weld becomes a major challenge. After the first time, it becomes less and less likely to succeed (ever try to re-weld an existing weld?)
    It makes more sense to modify the battery once so water replacement is both practical and safe. This is an engineering challenge but no worse than many other engineering problems. There is data that Prius traction batteries at 'like new' Ahr capacities improves Prius performance. IMHO, the loss of traction battery capacity should be treated like any other operating fluid loss or wear.
    I have one NHW20 battery module and 79 test NHW11 battery modules not counting the 38 in my 2003 Prius. I'm measuring the capacity of the weakest modules and finding:
    Ahr
    0.5 - from failed, replaced traction battery
    2.0
    2.2
    2.2
    2.2
    2.3
    4.4 - from salvage
    5.0
    5.5
    I am looking at how to refurbish the cell assemblies with the lowest Ahr capacity and return them to 'like new' capacity. This patent shows one of several approaches.
  7. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    What exactly is patentable about this? All I see is a description of an industrial process. How is it different than refilling water in a lead acid battery other than the vacuum step?
    Thanks for the info. I read it since there may be a day when this is useful.
  8. bwilson4web
    15,934
    Patents are a funny thing. If you use it for your personal use, an experiment, no problem. But if you try to sell something based on the patent, then there comes the risk of patent infringement. The solution is to apply for royalties and come to terms with the patent holder.
    The key is to do it for your own benefit and don't offer someone else's hard work as your own. Of course, if you come up with a different process that accomplishes the same goal, electrolyte replacement, so much the better.
    Now if someone comes up with a kit that might be used for some alternate approach, well again, no harm done. If this kit avoids dealing with a saturated KOH solution, I know some folks would be relieved.
  9. hill
    8,571
    I have an old poloroid picture of my face and scalp ... after battery burns had healed for about a month, if you wana be grossed out. It happend at Disney around 1987 ... the 3rd or 4th year I'd worked there. Even after obeying all the rules, and being properly trained, working around batteries can go wrong. Our 16" party boat is electric, and when I do maintenance on its batteries, I still have flashbacks from that hospital stay. Nope. don't even think about fiddling w/ batteries IMO.
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Bob, you're wrong on this one. No one is legally allowed patent use without permission, even for their own non-commercial use. There is a generally accepted, but not legally defined, exemption for *limited* use for experimental purposes. For example, you can replicate a patent to better understand how the patent works, but that's it. You can't use it on a routine basis, even for yourself.
    On the other hand, not many companies are going to sue you for private use of their patent, and remember, a patent has to be enforced by its owner. The government does nothing to track down and prosecute patent violators. You don't have much to worry about messing around in your own garage, but it's still patent infringement.
    Tom
  11. bwilson4web
    15,934
    Thanks Tom,
    I've been pretty much following standard practice and realized that like speeding 5 mph over the limit, in the USA there is a separate problem of enforcement. But first, I need experimental data that shows an alternate or better approach and that is what I'm working on.
  12. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    My original point was to show that it is a clear case of not meeting the requirements for a patent....but awarded anyway. The patent system is now fully preverted. It allows companies to patent DNA and routine processes as "novel inventions". (DNA?!?-That's a novel invention, but not by man.)
  13. bwilson4web
    15,934
    Hi folks,
    I bought a worn out battery pack from an NHW11 because I knew it had at least one failed cell. The following shows the voltage as function of time as my MRC 989 battery charger tried to go through a refurbishment cycle after adding distilled water:
    The proof is how quickly the voltage jumps up during the charge and later drops as soon as the discharge cycle begins. But worse, during discharge the dead cell began working like an electrolysis cell, generating hydrogen and oxygen gas that bubbled out of a small leak in one of access holes that failed to seal with JB Weld epoxy:
    One problem with the epoxy sealed hole is the original hole is covered up preventing drill-out and resealing. So instead, I decided to try using stainless steel tee nuts, stainless steel screws and rubber gaskets. This will allow easy electrolyte replacement in the future:
    The tee nuts were installed using a soldering iron and pre-drilled, access hole. These are test samples that I'll use for stress testing as well as 'blue printing' the battery module.
    The epoxy-hole method failed because when I tried to close the hole, the cell assembly was still out-gassing. This meant the epoxy at one end failed to flow into the hole and set:
    [​IMG][​IMG]
    You'll notice the hole on the right, next to the B+ terminal is not filled with epoxy.
    Going from left to right, the first cell has a fully closed epoxy hole; the over pressure valve, the temperature probe cup, the first tee nut, second tee nut, and the last cell with the incompletely sealed, epoxy hole:
    There are dimension and process issues to test as well as pressure testing. But if the system works as expected, we may be able to return used NHW11 cells (and possibly NHW20) to like new.
    BTW, the electrolyte, KOH, is a very powerful, caustic lye solution that will dissolve organic material like skin, eyes and clothing. It is risky to take a battery apart and requires: (1) eye protection, (2) face and breathing protection, and (3) skin protection. Treat the guts as if they are burning hot, lava and you'll have the right attitude:
    I don't recommend repeating this experiment but I figured posting some of the results is better than ignorance. Toyota has a patent on how to refurbish a Prius battery and my experiments are aimed at understanding how well it works. But I also realize how dangerous this is and would recommend those who have some interest understand what has been accomplished and what remains.
    So far, I have yet to 'recover' a cell. These initial experiments are aimed at the mechanical aspects of the problem. Soon enough, I'll get a chance to test the rest and then environmental regression testing. This means I need to make sure it works from below freezing to nearly boiling.
    Toyota has a battery refurbishment patent but the method I'm following differs in these aspects:
    • plastic welding vs. permanent, stainless steel ports
    • KOH electrolyte vs degassed distilled water
    • weight electrolyte vs. level measurement
    Otherwise, we are after the same end result, returning a battery module to a significant part of the initial capacity.
  14. bwilson4web
    15,934
    The first recovered battery:
    I'm running another series to see how high the efficiency will go. But as far as capacity is concerned, this one is just a little over 6.5 Ahr.
  15. Panicos
    Panicos Junior Member
    38
    16
    Cyprus
    did you do the vacuum process?
  16. bwilson4web
    15,934
    Lessons learned:
    • plastic welding is more difficult than my skills
    • failed to figure out how to seal terminals
    • water replacement and charge-discharge cycles brought battery modules to more than new spec
  17. Panicos
    38
    16
    Cyprus
    I took an old and useless module from a prius 1. Rehydrated it and put it in a vacuum chamber for 24 hours.
    I'm taking it out today or tomorrow and check if there's any improvements
