PC challenge of the week!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ultanium, Mar 19, 2016.
  1. Ultanium
    Ultanium Junior Member
    51
    49
    Houston
    I picked up a (barely) running 2007 today, fully loaded, for $750. The PO said he was driving down the highway, it ran hot, and he had the car towed to a dealer. The PO decided to buy another car, and I picked it up. The car sounded like a can of bolts when I started it, and drove it onto my car dolly, but it ran. Once home, I put it on TIS and have never saw so many codes...
    Hybrid Control
    P0A0F * (engine failed to start)
    P3108 (Lost communication with A/C system control module)
    U0100 (Lost communication with engine control module)
    U0111 (Lost communication with battery control module)
    U0129 (Lost communication with brake system control module)
    U0146
    Engine & ECT
    P0117 (Engine coolant temperature circuit, low input)
    P0300 * (random misfires)
    P0301 * (misfire on cylinder 1)
    P0303 * (misfire on cylinder 3)
    P1150 (coolant temperature sensor?)
    P3190 * (poor engine performance)
    P3193 (out of gas?)
    U0293 (Lost communication with HV engine control module)
    HV Battery
    U0100 (Lost communication with engine control module A)
    Cruise Control
    ABS/VSC/TRAC
    C0200 (front speed sensor RH circuit)
    C0205 (front speed sensor LH circuit)
    C1241 (low supply voltage 12v)
    C1311 (Brake inhibit Relay Circuit/open circuit relay 1)
    C1377 (Brake control power supply)
    C1378 (Brake capacitor circuit malfunction)
    U0073 (Control module communication bus off)
    U0123 (Lost communication with yaw rate sensor module)
    U0124 (Lost communication with lateral acceleration sensor module)
    U0126 (Lost communication with steering angle sensor module)
    EMPS
    C1554 (Electric Motor Power Steering)
    U0121 (Lost communication with ABS)
    Air Conditioner
    B1412 *
    B1413
    B1421 *
    Occupant Detection
    B1790
    B1794
    SRS Airbag
    B1650
    B1801 *
    B1803
    B1810
    B1811 *
    B1812
    B1813
    B1901 *
    B1902
    B1271
    I cleared the DTC's, had the ICE idling on about 2 cylinders, and something in the transmission made the car jump, even though it was in park. From this point on, the car will only move a few feet in gear, then goes into neutral by itself, and it acts like the gas pedal is not connected anymore. Some of the DTC's returned too, I have marked them with an * above, and there were some new ones.
    Hybrid Control
    P3000
    Engine & ECT
    P1116
    HV Battery
    P0A80
    The car has a lot of miles, 260k, but it is pretty clean, with JBL & SAT, and the AC blew cold for the short time I had it on. Is this car just cursed, or is there a chance at getting a little more life out of her? I thought for sure, that the car had bad plugs causing the misfire, but after the trans started acting up, the engine ran a little better, but by then the main battery alert came on, and I shut her down. Where do I even start on this, or should I start stripping the goodies off of her, for one of my other 2 base models? Appreciate any guidance!
    Tj
    #1 Ultanium, Mar 19, 2016
  2. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    I love a challenge and I like to logic things out. If I had that challenge in front of me I would focus on the engine and go from there. I had a 02, and it had a bad fuel pump, nothing worked because the engine would not run and charge the main battery. Find people you trust, to help you. On the other side of things if you are scrapping parts, I'm really looking for a luggage cover, I'm willing to pay.
    Ultanium likes this.
  3. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    True, I did replace the 12v on my 02 on the way to my fuel problem deduction :)
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Do you really want or need 3 Prius?
    If you could get this one running "well" at 260K is it likely to be better than either of your other 2 Prius?
    If the answer is no to either or both of those questions then I think the easiest answer is to look at this purchase as a $750 investment into a donor parts car. Which really might not be a bad investment in it's own right.
    BUT....
    If you're looking for a rebuilding challenge regardless of the reality?
    Well good luck.
    With the description you give, coupled with the plethora of codes it is throwing, it could be the PC challenge of the year.
  5. ozmatt
    ozmatt Active Member
    630
    259
    Australia
    nice collection of codes you got there Tj lol hopefully a new 12v eliminates a few of the above, good luck
    (y)
  6. Sillywizard
    Sillywizard Junior Member
    Sweden
    The first thing I would do is check the tire pressure!
    It's going to be fascinating to follow this saga, I can only hope this goes well!
    #6 Sillywizard, Mar 19, 2016
  7. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
  8. Ultanium
    51
    49
    Houston
    I bought the car hoping to resolve the cooling issue, and have another 50mpg car in our driveway (large family). But this may be one of those times where it is more practical to just use what we can and sell or scrap the rest. I'll swap a good 12v in and see what she does, but I'm not holding my breath. Swapping all the good stuff over to one of my other cars is going to be a lot of work. Oh well, no pain no gain!
    Tj
  9. exstudent
    2,214
    905
    Torrance, CA
    Assuming the body is good and you can install a used engine & transaxle, that might take care of a lot of known issues.
    A used steering motor might be needed too.
    How much would a used engine, transaxle, & steering unit cost?
    I wonder why there would be air bag codes? Was the car in an accident?
