PIP with aftermarket wheels
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by joey185, Sep 1, 2012.
  1. joey185
    joey185 Junior Member
    24
    Oregon
    Four Touring
    Has anyone done it yet? I was thinking about 17 inch axis five wheels with ep422 tires. Just concerned about mpgs of course. Not sure if they would go down, as these are very light wheels. Dont want 18's, had them on my mini and was a little to rough.
  2. Dark_Prius
    Dark_Prius Member
    146
    23
    LA
    I added spacers on my stock PIP wheels, looks great and maintain factory mpg. Can't be happier with the cost and result.
    LT26i ? 2
  3. joey185
    24
    Oregon
    Four Touring
    Got any photos?
  4. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Yes you mpg will go down. Wheel weight plays a very small part in fuel efficiency although it does play a bigger part in stop and go driving. I would expect about 3mpg loss with that setup.
  5. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    The wheels may be lighter but i think the narrowest tire they make for 17's is 215 which is wider than 195. The fact that they're also LRR will help but there still more contact patch (i.e. friction)
  6. Dark_Prius
    Dark_Prius Member
    146
    23
    LA
    Here
    LT26i ? 2
  7. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    The correct size 17" tire for a PIP would be a 205/50/17. While this is better than a 215/45/17 you will still suffer a loss. :(
    If you don't drive many miles per year then I wouldn't worry about it.
  8. sdtundra
    1,314
    193
    Sacramento, CA
    What size are those? I've been thinking about running either a 5mm or 10mm to get rid of the tucked look after lowering
  9. Dark_Prius
    Dark_Prius Member
    146
    23
    LA
    5 mm front, 22 mm rear.
    LT26i ? 2
  10. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    I was thinking 25mm rears and 10mm fronts to get them more flush..man i hate how sunken the rears are.
    the thing i dont like about the 10mm is they dont come in the version 2 which have separate lugs so you dont have to remove the stock ones. But i need to look at my stock wheel to see if there is a space for the lug to sink into on backside of wheels.
    do you have anymore pics more from the back to show the flush,ness? which brand did you go with?
    Here is the ones Ive been looking at: Prius 04+
    thanks!
    Dan
  11. Dark_Prius
    Dark_Prius Member
    146
    23
    LA
    I feel 5mm 22mm are perfect.
    I dont recommend any higher, in fact I would recommend 20mm for the rear.
    Hope this helps.
    LT26i ? 2
  12. rockerdan
    427
    83
    Wheatfield NY
    looks great! thanks!
    what brand did you use? do the 5mm fronts vibrate at all? Id like to keep hubcentric up front so they remain smooth not vibrating.
    dan
  13. Dark_Prius
    Dark_Prius Member
    146
    23
    LA
    My front is hubcentric, rear is Ichiba.
    And no vibration
    LT26i ? 2
  14. ultraturtle
    108
    81
    Peachtree City, GA
    If you do get new wheels, I hope you post the old ones for sale on this forum. Many of us would like a full size, matching spare at a reasonable price.
    DianneWhitmire likes this.
  15. Dark_Prius
    Dark_Prius Member
    146
    23
    LA
    Me2
    LT26i ? 2
  16. Potorap
    Potorap Active Member
    345
    148
    Pahrump, Nv
    Hello I just posted in private sales a set of 2011 gen 3 factory wheels covers and lug nuts.
  17. Dark_Prius
    Dark_Prius Member
    146
    23
    LA
    We want PIP oem wheels as a spare
    LT26i ? 2
  18. ultraturtle
    108
    81
    Peachtree City, GA
    For anyone confused by this exchange, Toyota chose to make the PiP wheel unique to the PiP. Both base and advanced models have wheels that are not available (in the USA) on other Prius models. Don't know why, it just is what it is.
  19. joey185
    24
    Oregon
    Four Touring
    I like that, I can see the difference.
  20. joey185
    24
    Oregon
    Four Touring
    You wouldn't have a pic from a little farther back? I see the difference, just hard to tell what it makes the car look like when so close.
    Thanks, I just might go this route and have the wheels painted gun metal grey.
